HOAT Coolant, where is it? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 14 Old 10-28-2005, 11:38 AM Thread Starter
WkndDrnk
They bend 'em, I mend 'em
WkndDrnk's Avatar
Alright, Ive been trying to find this stuff and its just not happening. Ive been to my local parts stores and they all look at me funny when I tell them what I need. So I stopped by the dealership to see how much it is. The dealership wants $14 a gallon and Ill need 2 gallons. I can suck it up and pay the $30 for it but I'm frugal, not cheap, and want to save a few bucks. Does anyone know of any place that may carry it besides biggies like Advance, AutoZone, or Pepboys? Has anyone else had a hard time finding this stuff? I'm sure more that likely Ill be buying it from the dealership from what Ive been reading in past threads.
'02 Ram 1500 QC SB 4.7L V8
MODS SO FAR:
OUTSIDE
Tinted All Around - Diamond Cut Altezza Tail Lights
PERFORMANCE
Glasspack (dumped)- Homebrew CAI w/ K&N Filter - 68mm SQC T-Body - Relocated IAT w/Powerwire - Superchips Tuner - Gibson Headers - 180* T-stat
MODS TO COME:
Line-X Bedliner
WkndDrnk is offline
post #2 of 14 Old 10-28-2005, 09:24 PM
claybaker
claybaker's Avatar
I was curious because I figured you could get it so I did a web search and all I came up with was LAWSUITS against GM over Dex-Cool. I found a quote (and then lost it, sorry) that said that the parts stores had pulled it off the shelves because it caused corrosion. YIKES! Most of the stories were from 2003-2004. Does anybody know if this has been resolved?
Clay
2005 "Big Horn" 5.7 Hemi
3.92 Axle LSD / 20" Chrome Clad Wheels
Power Sunroof
Hella 500s behind the grill
Added Stock Tow Mirrors
Swapped 6 CD in-dash for RB1 with 6 CD Changer under the seat
SuperChips FlashPaq
claybaker is offline
post #3 of 14 Old 10-28-2005, 09:39 PM
RumbleRam2481
I'm Losed ! LOL
corrision happens when idiots mix two different coolant ! the two react and cause corrision for example mix dexcool with green and you get brown and problems.
Visit Me :
http://www.geocities.com/miraclestripmoparclub
RumbleRam2481 is offline
post #4 of 14 Old 10-29-2005, 12:27 AM
claybaker
claybaker's Avatar
Actually, GM claims it was because the owners didn't keep the radiator full and it basically boiled down to sludge. The suits claim that GM said it was good for 150k miles so the owners shouldn't of had to worry about it.
Power Sunroof
SuperChips FlashPaq
post #5 of 14 Old 10-29-2005, 01:40 AM Thread Starter
WkndDrnk
WkndDrnk's Avatar
Zerex makes a HOAT coolant but I cant seem to find anywhere that sells it. But your right about the corrosion. Mixing coolants will do that to a system. Bad juju there. Anymore info guys?
MODS SO FAR:
OUTSIDE
PERFORMANCE
MODS TO COME:
Line-X Bedliner
WkndDrnk is offline
post #6 of 14 Old 10-29-2005, 08:19 AM
jordanp123
Sleeper in The Making
jordanp123's Avatar
Hey My Truck came from the dealer a little low on antifreeze so i Put in some "Orange" coolant (The 150,000 mile Prestone stuff). I dont need to drain my entire radiator do I. Will it hurt it. Sorry to Hijack your thread readingt stuff like this always makes me think Ive done something wrong
jordanp123 is offline
post #7 of 14 Old 10-29-2005, 09:33 AM
dodge3471
Dodge Fanatic!
I nicked my radiator core with the cooling fan while removing it far a dragstrip day and had to have the core fixed. I needed some antifreeze and I asked the owner of the radiator shop where to get it from. He said he also had a 2004 Ram and suggested that I get it from the dealer as it's almost impossible to find else where. Sorry, think of the $30.00 as cheap insurance. That's what I did.
dodge3471 is offline
post #8 of 14 Old 10-29-2005, 09:34 AM Thread Starter
WkndDrnk
WkndDrnk's Avatar
I asked the mechanic at the dealership about adding the long life coolant that some brands put out besides the DEX-COOL. He was very adiment about NOT adding any other coolant besides the HOAT coolant to a HOAT coolant filled system. If I were you, Id talk to a mechanic at the dealership where you bought it. From everything Ive been told and reading about, its not good.
MODS SO FAR:
OUTSIDE
PERFORMANCE
MODS TO COME:
Line-X Bedliner
WkndDrnk is offline
post #9 of 14 Old 10-29-2005, 11:10 AM
claybaker
claybaker's Avatar
According to the Prestone site:
Prestone® Extended Life 5/150 Antifreeze/Coolant is recommended and formulated for use in all GM vehicles that require a GM DEX-COOL® approved formula coolant, as well as all other cars and light-duty trucks with aluminum radiators. This patented formula has a concentrated blend of premium, long-lasting inhibitors for extended performance, protecting against temperature extremes and the ravages of rust and corrosion for 5 years or 150,000 miles.
Mixing them is probably not the best idea, but none of the lawsuits where they had problems mentioned anything about mixing, only that the owner had let the coolant level drop. I wouldn't lose sleep over it if you keep it topped off.
Clay
Power Sunroof
SuperChips FlashPaq
post #10 of 14 Old 10-29-2005, 11:50 AM
jordanp123
jordanp123's Avatar
hmm I added only to the Resevoir about 4 weeks ago. I think ill just drain the resovoir and put the HOAT coolant in. I just added about a quart of prestone So im hoping it hasnt hurt it.
post #11 of 14 Old 10-29-2005, 01:36 PM Thread Starter
WkndDrnk
WkndDrnk's Avatar
I wasnt tryin to scare anyone. Just passing along what I was told by the mechanic there at the dealership. Personally, I like to change out my coolant every 2-3 years to keep it fresh and the system in shape. But as always, if you notice a color change or a smell, play it safe and change it out. $30 isnt that bad to prolong the life of the system.
MODS SO FAR:
OUTSIDE
PERFORMANCE
MODS TO COME:
Line-X Bedliner
WkndDrnk is offline
post #12 of 14 Old 10-29-2005, 02:34 PM
jordanp123
jordanp123's Avatar
No no. I dint mean to give that impression. Thanks for telling me that way next time ill put the correct stuff in.
post #13 of 14 Old 10-29-2005, 06:38 PM
Dodge_Tomahawk
Ultimate Design
Dodge_Tomahawk's Avatar
http://www.valvoline.com/pages/produ...asp?product=10
What is a HOAT coolant and why is it different from conventional and extended life coolants?
An HOAT coolant uses both inorganic and organic inhibitors. HOAT coolants offer the best of all technologies for both immediate and long lasting protection. Inorganic inhibitors provide fast acting aluminum engine protection from boiling and erosion while the organic materials offer non-depleting, long term protection.
What vehicles use Zerex G-05 in the factory fill and what is the dye color?
1984 Mercedes and beyond (light yellow)
1990 Deere and Company vehicles and beyond (green)
2001 Chrysler, Dodge, and Jeep and beyond (orange)
2002 Ford, Lincoln and Mercury trucks and SUVS and beyond (yellow)
2003 Ford, Lincoln, and Mercury automobiles and beyond (yellow)
Dodge_Tomahawk is offline
post #14 of 14 Old 10-29-2005, 06:48 PM Thread Starter
WkndDrnk
WkndDrnk's Avatar
Yeah, thats one of the websites Ive found on my quest for information on this stuff. Thanks for posting Dodge_Tomahawk.
MODS SO FAR:
OUTSIDE
PERFORMANCE
MODS TO COME:
Line-X Bedliner
WkndDrnk is offline
    Coolant - newest carpet shampoo?? AKDingo Dodge Dakota 1st Gen (87 -96) Forum 1 08-08-2005 01:44 PM
    Towing and Coolant Temperature Modain47 2G Dodge Dakota Performance Talk 7 06-14-2005 06:11 PM
    Coolant reservoir? RyanG1 2G Dodge RAM - General Talk 5 03-31-2005 05:01 PM
    Coolant Leak Evill 3G Dodge RAM - General Talk 1 11-10-2004 09:37 PM
    2001 Durango Engine Coolant Question KARNY 1G Dodge Durango - Drivetrain Talk 7 08-01-2004 10:59 AM
