Thoughts on increasing torque on Magnum 318... - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Truck Engine Technical Forums > 2.5L, 3.9L, 5.2L, 5.9L, V10 Tech
Dirt_devil
  Thoughts on increasing torque on Magnum 318... - Posted: 10-26-2005, 08:28 PM
Dirt_devil's Avatar
State: MI
Post #1
Just kicking around an idea here... In the search for more low-end torque from a Magnum 5.2, and knowing that a smaller bore on the throttle body= higher intake air velocity and therefore better low end torque and throttle response, could a 3.9 throttle body (bored to smooth airflow as thefastman does) provide better low end torque? Has anyone tried anything like this? I am wondering if there is a point of diminishing return on the small end of the bore size. Could there be a sweet spot that is lower than the 50mm bore that most of us are currently running? If anyone had a 3.9 TB sitting around that they would be willing to give up for cheap I would be interested in testing this out. ...... I do imagine that top end power would be lower, but how low?? Your thoughts on this can make for some interesting conversation in the least!
Volphin
  More Torque? - Posted: 10-26-2005, 10:05 PM
Volphin's Avatar
Post #2
Interesting! Can you imagine the velocity of gasses through that TB? The PCM would freak and work like heck to lean you out...
What you need is a towing cam, roller rockers and hardened pushrods from Fastman. Yes it is "going deep". But hey, you wanted torque?!
Also, how about changing your gearset?
HTH
ASE Certified Master Tech, MoTech Class of '85
2001 D+ Platinum
5.9L, 4x4, 46RE, 9.25 Axle w/3:55, Speed Prop Tow Pkg, Kleen Wheels, IP Stage II, 52mm FMTB, PPH Headers with Jet Hot Sterling, Mopar M1, 1.7RRs and Magnum VCs, Smith Bros. Hardened Pushrods, B&G M1 Flash, Go Rhino! Sumatra 3000 Brush Guards, PIAA 580s, Optima Red Top, Mag-Hytec Diff Cover, Mag-Hytec Trans Pan. I'll bore you .060 over if you stroke my crank.
zerko
 Posted: 10-26-2005, 11:05 PM
zerko's Avatar
City: Sudbury ,Ontario
Post #3
I agree with Volphin. Would look at cam, computer, exhaust,gearing,etc. I think that your computer would be so confused, the engine wouldn't run
at-all. Tried swapping computer from a one-year older truck, and nothing!
If I could buy My truck as a Brand New unit today, I definately would!
Dirt_devil
 Posted: 10-27-2005, 09:46 PM
Dirt_devil's Avatar
State: MI
Post #4
Well, a cam, computer, exhaust, etc. are deffinitely things I intend to do in the future to achieve the performance I am looking for, and I am not intending that this would be a replacement mod for any of those. I am just pondering the idea as to what results you would get.
Now as far as the computer goes... correct me if I am wrong, but the Magnum engines are tuned by a "speed density" system, which means that the fueling (based on airflow) and timing are determined based on load and engine RPM. The load is calculated using inputs from the manifold absolute pressure (MAP) sensor, throttle position sensor (TPS), while the airflow is calculated based on these two sensors and the IAT sensor (for air density). Between these inputs and the values in the VE (volumetric efficiency) table, the required fuel can be calculated. The O2 sensor checks to make sure the calculations are correct, and corrects the fuelling if needed. When corrections are made the computer "remembers" the changes, and eventually "learns" what changes need to be made in the VE table.
So... the volumetric efficiency would be decreased slightly by the smaller throttle body, but the computer would still be reading off of the same VE table (thinking the engine has a greater VE than it actually does) and it would tend to run rich... I would think anyway. The computer would learn these changes to the VE table anyway though, via the O2 sensor.
I think that someone needs to try this... Anyone have a 3.9 TB sitting around???
zerko
 Posted: 10-27-2005, 11:12 PM
zerko's Avatar
Post #5
you've put wat too much thought into this, to not do it would be Wrong!
Let us know how it turns out.
Volphin
  Do it. - Posted: 10-28-2005, 08:21 AM
Volphin's Avatar
Post #6
Get a wrench. hahaha. I concur, try it. But the PCM is still a simple block learn system. There's more HP in a pda.
2001 D+ Platinum
Almond Pale Ale
 Posted: 10-29-2005, 07:31 AM
Almond Pale Ale's Avatar
Patriot....
City: Miami, 'the 305'
State: FL
View This User's Dyno Entries
Post #7
I had a 95 Dakota 5.2L with the 5 speed and 3.91 rear end - though I never dyno'd it, it was pretty quick off the block.
My 99 Durango however has been dyno'd and put out 282ft/lbs at the rear wheels (all mods below EXCEPT the Hypertech). From that, I can extrapolate that good air in and a good flow out (headers, Y pipe and exhaust) alone will produce an increase in torque. 1.7RRs or good 1.6 and a cam will do even more.
2004 Ram 2500 4x4 SLT, 305/555 CTD, 48RE, QC, LB
Intake: aFe Stage I intake, aFe Torque Tube Exhuast: IMCO HD performance muffler Drivetrain: PML rear diff cover, PML Tranny cover, Bilstein shocks Power: Diablosport Power Puck set on 60hp/100tq Fluids: AMSOIL front to back
CTD Enthusiast Club Member #47
Freddy
 Posted: 11-02-2005, 09:48 PM
Post #8
I thought I remember reading some on here, that helped flat lined the torque curve. I can't remember what its called. They had an article about it, it was on a well built 454 chevy engine. I think it had something to do with increasing the vacuum line pressure. But I can't remember
lbeenken
 Posted: 11-03-2005, 12:21 AM
City: Mason City
State: IA
Post #9
Get a Comp Extreme Energy 4x4 cam. They have all sorts of bottom end torque.
2001 Quadcab 4x4 HO Cummins & 6 spd 80hp BD injectors, Edge EZ, Banks power elbow with 4" straight pipe into 5" stacks, Autometer boost and pyro gauges in the pillar, Southbend metallic CON FE clutch, Banks High Ram Intake
dyno'd at 300HP and 810TQ at the rears
360HP and 970TQ at the crank
BVRmonger
 Posted: 11-03-2005, 12:55 AM
State: GA
Post #10
Yeah. I don't believe a smaller throttle would net you any torque.
more compression would.
HankL
 Posted: 11-05-2005, 07:48 AM
City: Central NC
State: OTHER
Post #11
Nonsense!
A smaller throttle body
is just like a large throttle body
with the throttle blades partially closed - no torque advantage.
charlie1935
 Posted: 11-05-2005, 08:21 AM
charlie1935's Avatar
City: DuQuoin
State: IL
Post #12
supercharger!!supercharger
87DakBuilder
 Posted: 11-05-2005, 08:28 AM
87DakBuilder's Avatar
Stroked & TKO'd
City: Waldorf
State: MD
Post #13
I'm not sure about the torque possibilities, but a guy on one of my other forums modded a v6 tb, and was able to get just about as much horse power and torque from it as he did from his stock v8 tb. He did it to show that the V8 tb swap wasn't really worth doing if you knew how to port tb's with a dremel. In fact I think it is still up on Dakotausa.com. Not sure though.
Jay
bocephus
 Posted: 11-05-2005, 08:06 PM
Post #14
Change the cam profile.....
2006 Magnum SRT-8 Photos Here! FreeLantz Dodge Magnum SRT-8 Talk 25 08-01-2005 07:11 PM
2006 Dodge Magnum, What's New for '06 RAM MAN Rumor Mill & Gossip Talk 1 07-13-2005 09:21 AM
2006 Dodge Magnum SRT8: Beefed-up American Muscle RAM MAN Rumor Mill & Gossip Talk 2 01-08-2005 03:52 PM
Press Release: All-New 2006 Magnum SRT-8 FreeLantz Rumor Mill & Gossip Talk 2 01-05-2005 07:15 PM
2005 Dodge Magnum Engineering Press Releases RAM MAN Rumor Mill & Gossip Talk 0 03-03-2004 08:55 AM
