Go Back   Dodge Talk Community Forum > Dodge Vehicle Forums > Stratus Talk > Stratus 2nd Gen (01 - 06) > 2G Stratus - Performance Talk
stratusguy
  rough idle good accellaration after warm up - Posted: 10-24-2005, 11:22 AM
Post #1
i have a 97 dodge stratus 2.4 L DOHC . have replaced plugs, wires,power pak,regular oil changes 4 k , tranny filter&oil every yr. i have 134,000 need some direction where to go now ???
dodgefan360
 Posted: 01-07-2006, 08:33 PM
dodgefan360's Avatar
Platinum 2K R/T
City: Kitchener
State: ON
Post #2
Before filling up next time, at 1/3 tank of fuel or less throw in a couple GOOD fuel injector cleaners and drive around 50 miles. I used one every tank of fuel with my 2.5L TBI spirit and it lasted 261 000miles before I sold it for parts! The fuel management's different with the stratus 2.5L since they're DOHC engines, but the FI cleaners helped my idle quite a bit. If that doesn't work or help (give it a couple weeks), take it to the dealer and they should be able to do something to help your rough idle problem out. I'm not sure if your engine has a TPS and/or IAC or not (throttle position/idle sensors), but if it does replace those sensors (runs about $25-35 each), it should help the idle quality.
2000 5.9 R/T - Platinum
106,812m (172,000kms)
Amsoil in the diffs, transfer case and engine - Hughes Plenum - Fastman 52mm TB - K&N FIPK - Superchips (91 octane, performance) - Taylor wires
My 2000 R/T
LB3711
 Posted: 01-12-2006, 10:50 PM
LB3711's Avatar
>> Moose <<
City: Trumbull
State: CT
Post #3
change the fuel filter. are you getting a check engine light?
2001 Dodge Stratus ES 4Dr. 2.7L Magnum DOHC V6.
http://pages.cthome.net/lb3711 :: http://www.cardomain.com/id/lb3711 :: http://www.msnusers.com/LB3711Stratus
2002 Dodge Durango SLT 4Dr. 4.7L Magnum V8.
http://www.cardomain.com/id/lb3712
http://www.myspace.com/lb3711
Proud Member of The Original WCPW
HID CLUB #13
Click HERE to view the complete signature...
Car of the Month Award!:  - Issue reason: Dec 03 Car of the Month Winner!Car of the Month Award!:  - Issue reason: Sep 05 Car of the Month Winner!
Rough idle at start 98rango 1G Durango Performance Talk 1 09-28-2005 05:32 PM
4.7 rough idle blackice85 1G Durango Performance Talk 9 08-26-2005 10:32 PM
Rough Idle w5blt Magnum - General Talk 20 03-22-2005 03:15 PM
Target idle/rough idle ss62 3G RAM - General Talk 13 06-30-2003 10:29 PM
Rough Idle - Check Engine Light Jeff Jatich 3G RAM - Drivetrain Talk 5 06-12-2003 01:07 PM
