inertia switch - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 09-28-2005, 06:05 PM Thread Starter
longball
inertia switch
Can someone tell me where to find the inertia switch on a 96 dakota 2 wheel, 3.9, auto. Also, does the switch shut off the fuel and the spark or just one of them.
thanks, Joe
longball is offline
post #2 of 6 Old 09-28-2005, 07:41 PM
mr.nobody
mr.nobody's Avatar
Quoted: 3 Post(s)
i don't think that dodge has them, did you check all your fuses and relays??
CHRIS
mr.nobody is offline
post #3 of 6 Old 09-28-2005, 07:46 PM Thread Starter
longball
inertia switch or something else????
Someone told me to check the inertia switch. I'm not sure if they have them either. I wouldn't know what or where to look for with the fuses and relays. Do you mean the under dash fuses or under the hood? It appears I don't have fuel or spark.
Thanks, Joe
longball is offline
post #4 of 6 Old 09-28-2005, 07:57 PM
mr.nobody
mr.nobody's Avatar
Quoted: 3 Post(s)
do you have an owners manual?? you can check the fuel pump, open the fuel cap have someone turn the key on and off a couple of times you should hear the pump cycle, check under the hood fuse panel should be relay for the pump, you can take a wire off of the cap or coil pak(not sure what you have) and turn it over and see if you have spark!
CHRIS
post #5 of 6 Old 09-28-2005, 11:37 PM
hemi_dakota94
hemi_dakota94's Avatar
Never heard of one on our trucks. Not saying there isn't one, but FORD used to put them on everything, and may still. I had problems with that on my 90 Tempo (Not proud of the car, but it was my 1st car...) it was just a trip switch in the trunk..
I'd say check the coil for spark, and check your fuel delivery.
-Jeff DeLorenzo
4.7, 4x4, 3.55's,
Mods: Remote Start, debadged, 2" T/S w/ Belltech 6400s, JVC KD-PDR30, Goodyear Silent Armor 265/75-16's
2005 Stratus SXT - Special Edition
2.4 auto
"The runabout"
Have you voted for DodgeTalk's Vehicle of the month awards yet ?
hemi_dakota94 is offline
post #6 of 6 Old 10-02-2005, 08:18 PM Thread Starter
longball
inertia switch on Dodge Dakota
Thanks to those who helped with my question about an inertia switch. I had no spark and no fuel. Somebody said to check the relays. I found an auto shut down relay under the hood. I figured that was it but I switched one in place of it and it made no difference. I still thought the relay made sense, so I traced the wire harness going into it. I found a completely corroded wire. I spiced it and the truck started right up. Thanks to all those that helped.
Joe
longball is offline
    HELP!!! Code P0132 SHADOW QUAD CAB 2G Dodge Dakota General Talk 4 04-30-2005 10:00 PM
    Problem code baseball401 1G Dodge Durango General Talk 2 04-17-2005 12:56 AM
    Door lock prob's anyone? Compstall 1G Dodge Durango General Talk 9 01-16-2005 12:47 AM
    P0601 Error jgonick 1G Dodge Durango Performance Talk 7 06-11-2004 01:33 AM
