Transmission fluid type - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 12 Old 08-13-2005, 07:32 PM Thread Starter
1BadRam
ATF III was put in my transmission accidentally anr run for about 75 miles. I have drained it and put in AFT IV. The tranny slipped like hell w/ the ATF III, does anyone know if it would do any serious damage internally?
2002 Dodge Ram 1500 SLT 4X4
3" Flowmaster DeltaForce 40 dual exhaust
2" front leveling
Xenon Custom front bumber cover
Color-coded body mouldings
Throttle Body spacer
Fastman Over-bored throttle body
K&N Cold Air Kit
Under-Drive Pullies
Heads ported & polished
Hypertech Power-Programed
315/70 R17 BFG All Terrains
Tow package w/ 3.92 gears & limited-slip diff
Custom grill inserts
Color Coded Wiper cowl
X3 Carbon Fiber Tailights
Flashed PCM
DeBadged
Color Coded door handles, mirrors & tailgate handle soon to come...
1995 Dodge Ram 2500 SLT 4X4
All heavy duty options available
360 heavy duty
K&N filter
Amsoil lubes through-out
Electric brake control
Detroit Locker in rear
9' Diamond plow
2001 Dodge Intrepid R/T Motorsport Edition
No mods yet, but soon to come....
1BadRam is offline
post #2 of 12 Old 08-13-2005, 09:41 PM
v10sport
Built Not Bought
v10sport's Avatar
What year truck? The 95?
My 00 required only plus 3. So the +3 would work in the 95
I run dexron/mercron now
2000 Dodge 2500 Quad Cab LB V10 with many many mods.
7500 pounds
1/8th 10.193
67MPH
1/4 16.024
84.01 MPH
05 610 CTD QC 4x4 Needs some mods
02 Jeep Grand Cherokee 4x4
v10sport is offline
post #3 of 12 Old 08-13-2005, 10:01 PM
racerX_244
Seriously.
racerX_244's Avatar
hows that? is it cuz of your rebuild?
"Spitfire"
2002 Dodge Dakota
Ext.Cab Sport 2WD Auto 3.9L V6, "239ci Super-Smallblock."
COIN HOLDER ASSOC. MEMBER #244
18's, 2" drop, cowl hood, 'cuda stripes, street scene grill, clear corners, bed cover, tint, stereo, interior trim painted, gauges, intake, fastman tb, 1.7 HS RR's, summit exhaust, 4.10's, transgo & powertrax, plenty more & more to come
racerX_244 is offline
post #4 of 12 Old 08-13-2005, 10:03 PM
poliojoe
poliojoe's Avatar
I don't know if it hurt it, however, I know that TSB 21-006-01 says that ATF4 should be used in 1994-2002 Ram trucks.
poliojoe is offline
post #5 of 12 Old 08-14-2005, 08:47 AM
v10sport
Built Not Bought
v10sport's Avatar
Yeah,
As to the ATF plus 4, I wouldnt run it unless your truck came from the factory with it. It has a friction modifer in it to help clutch chatter. Friction modifier creates a bit of slippage. No thanks.
The Dexron may cause a bit clutch chatter, but it doesnt run friction modifier in it.
7500 pounds
1/8th 10.193
67MPH
1/4 16.024
84.01 MPH
v10sport is offline
post #6 of 12 Old 08-14-2005, 03:27 PM
racerX_244
Seriously.
racerX_244's Avatar
i heard from a local shop that they use dexron/mercon with lubegard tranny additive in all their transmissions, including chrysler. read up on lubegard and says that adding it makes fluid compatable to the atf4 standards.
"Spitfire"
2002 Dodge Dakota
post #7 of 12 Old 08-14-2005, 08:58 PM
Mathes79Z
Mathes79Z's Avatar
transgo ( very knowledgable) says to add life to your transmission to run synthetic fluid (such as amsoil) (but not mobil, though i know many people who havent had trouble with mobil synthetic tranny fluid, i do know of some people who did, but NOBODY ever said they had tranny failure due to amsoil!!)
anyhow, back at the ranch.
TransGo says to run synthetic, but if you want to keep costs down, run 8 quarts synethic and fill the rest of the way with dexron!!
Many, and i mean more than 20, many transmission "specialists" have told me to run dexron in these transmissions, the only reason to run ATF+ is because its mopar fluid, mopar gets a cut.
I used to run Amsoil but one day my tranny cooler line blew off (quick connect coupler wasnt on all the way when i installed the new cooler) and emptied out my tranny quick, so i had to refill with atf+3, but soon im getting ready to put the shift kit in (which ive owned new in the box now for about 2 years, lazy) and switch back to all amsoil, i loved it, the tranny shifted MUCH better, ran WAY cooler and over all performed better.
From every ounce of breath i have, it is worth every penny you need to save up to get the AmsOil ATF!!! do it and you will NEVER regret it for a second. its well worth the price, it does cost about $80 just to do a filter change, but more than likley it will be your last filter change for at least a loooooong time, my amsoil stayed nice and pink for 30,000 miles before the line blew, atf+ used to turn crappy after about 2,000 miles. Ask around the board and check some posts doing a search, you will see many happy people running amsoil. I know i was.
oh, and no i dont sell the stuff, and i even actually use mobil one oils in my ram in every other place except the transmission and transfer case.
speaking of which, my transfer case used to make a whining noise when in 4wd, when i switched to amsoil in my transmission i did the same for my transfer case, no noise! not then, and not now with 50,000 more miles, used to shift shitty into gears (transfer case) now i can go from 2H-4H and back and speed (up to 50 like recommended) VERY smoothly, i have many people ride with me who have said to me "shouldnt you put it in 4WD?" and i say "already did" its that smooth and quick. now, results may vary but it did make a huge differance for me.
goodluck.
2000 Dodge Ram 1500 5.2L (318ci) 4X4
46RE
4.56 gears with richmond locker in rear.
Single 3" exaust through Magnaflow cat and Hooker Aerochamber muffler.
Ngk V-groove plugs
Fastman 50mm TB
Hypertech PPIII
Accell supercoil
Dakota air hat with Large K&N diesel filter.
Underdrive crank pulley.
*DodgeTalk.com 318 Enthusiast Member #(13)*
*DodgeTalk.com Silver Truck Club Member #(90)*
Mathes79Z is offline
post #8 of 12 Old 08-14-2005, 10:15 PM
DODGEIT
DODGEIT's Avatar
Quoted: 1 Post(s)
I have run the Amsoil Universal ATF since 60,000 miles I now have over 90,000 miles and it still looks nice and red and shifts fine. The tranny shop I use doesn't use Amsoil. He uses ATF+3 and adds an additive to it. But I got a torque converter shudder in it after about 3000 miles so I had it flushed out and Amsoil put in. Well worth the price of it.
2012 Dodge Ram 1500 Big Horn QC 4x4
DODGEIT is offline
post #9 of 12 Old 08-14-2005, 10:25 PM
Mathes79Z
Mathes79Z's Avatar
I cant get any shop anywhere to flush my tranny out and add amsoil, they will not do it unless they can add their fluid (atf+3), which would just be tossing my $100 down the crapper.
I could do it myself, but the cost and waste would be rediculous to me.
46RE
Ngk V-groove plugs
Fastman 50mm TB
Hypertech PPIII
Accell supercoil
post #10 of 12 Old 08-15-2005, 03:30 AM
racerX_244
Seriously.
racerX_244's Avatar
see, i figured i'd say that a local shop told me about the dexron and additive, cuz that's whats in my tranny now. 13 quarts of it. i just didn't want to post that and see NOOO DON'T USE DEXRON lol
i had my transgo kit put in at aamco in late july. got home after i dropped it off and forgot to double check with their tech to see what fluid they use, just to be safe. i was gonna ask him when we were talking over the kit options and setup, and forgot. called them up and he says
"we use dexron/mercon v with an additive in our chryslers. yes, all of them. even the ones that say they require +4. they only say that to make sure you get the right viscosity of oil in there to provide the correct lubrication. been doing it this way for years."
i was a little freaked, but i just kinda said alright then. i mean, only things i've read about tranny fluids is on message boards, and this guy is a tranny tech.
after i hung up with him, i called three other shops in the area, two transmission specialties (cottman and economy transmission). same answer. dexron with lubegard.
went and got my truck at their closing time, and it was shifting like a CHAMP. and, i've found with slight adjustments of the tv cable now, i can really control the firmness and points, to whether i feel like barking into second (yes, a v6 will chirp second. hard. 4.10s and a locker don't hurt though)
then the next week, my girlfriend and i took a 1500 mile road trip from Boise, ID to Santa Barbara, CA and back. super hot outside, and it shifted like a pro the whole way there. hell, when we got there after a final 6hr freeway jaunt and rolled into santa barbara and drove downtown, 1-2 shift was banging just like it had when we left that morning, and grabbing into 3rd super quick too without any slip or chatter.
so my guess is, they sure were right. its just a matter of having that right viscosity to get a new chrysler to shift the way it was meant to and without harming the tranny. having the shift kit in there sure makes me feel better about longevity as well. i will be going back to all amsoil in the future however, since i'm sure it is superior to what is in there now, but thats not to say that dexron and additive won't work at all. in fact, its working quite well.
"Spitfire"
2002 Dodge Dakota
post #11 of 12 Old 08-15-2005, 01:15 PM
Hieneken49
Jake The Snake
Hieneken49's Avatar
i just had my trans rebuilt and the guy told me not to pour in any additive like lucas, now i think its running like shit, when its cold its hessitant and other shit. the trnas shop says its fine (offcourse) what do you guys think should i pour in a quart of lucas?
2009 GMC Sierra 1500 4x4
Stock and not a dodge
Hieneken49 is offline
post #12 of 12 Old 08-15-2005, 11:10 PM
o2man98
Official DT Amsoil Dealer
o2man98's Avatar
I would not use the Lucas. The lube guard additive that is being talked about is completely differnt than this.
It is nice to see people having good experiences using an ATF offer than the Chrysler +4
Ken
o2man98 is offline
    What type of fluid ?? SNOWTHROWER Dodge Dakota 1st Gen (87 -96) Forum 18 07-17-2005 09:25 PM
    Power Steering Fluid Almond Pale Ale 1G Dodge Durango General Talk 17 03-28-2005 10:01 PM
    Tranny fluid type? Hot Rod35 2G Dodge RAM - Drivetrain Talk 3 12-18-2004 10:07 PM
    05 Chrysler and Dodge Minivan Specifications RAM MAN Rumor Mill & Gossip Talk 0 12-12-2003 08:37 AM
    Mopar ATF +3 type 7176 tranny fluid Bryanh23 2G Dodge RAM - Drivetrain Talk 5 05-07-2003 09:51 AM
