1986 Dodge Ram 150 with V8 318 2bl carb - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 08-09-2005, 09:21 PM Thread Starter
Viperk
1986 Dodge Ram 150 with V8 318 2bl carb.......lacks power??
hey i have a 1986 Dodge Ram 150 with V8 318 2bl carb.......... it all of a sudden lost power after changing pickup, cap, wires, plugs ........ it starts ok and sounds ok but if you go to speed up it hesitates ...... so you can only speed up very slow..... but once your up to speed it seems to run fine just lacks power.......
anyone know what could be causing this??
Viperk is offline
post #2 of 6 Old 08-09-2005, 09:28 PM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
Did you remove the distributor when you changed the pickup?
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #3 of 6 Old 08-09-2005, 09:30 PM Thread Starter
Viperk
nope distributor stayed in place
Viperk is offline
post #4 of 6 Old 08-09-2005, 10:47 PM
dodge_sst1
dodge_sst1's Avatar
check the pick up clearance, check vac advance hook up operation,
05 -2500 heavy duty quad cab st.
4x4 ho ctd 610#tq,hd 6speed man.
4.10 antispin
predator 2019
putco ss wheel trim
putco boss locker bed rails
mopar fog light kit
atlas wheels & 285/70 bfg AT
brake controller.
2" front leveling kit
past mopars
65 fury sport indy pace car 383 mag
68 charger 318 3 speed man
77 aspen R/T 360 4BBL
78 lebaron 318 leanburn
87 lebaron 2.5 5speed
97 dodge sst black
98 dodge sst black ordered from factory
99 dodge ram sport white 4x4 quad cab
03 dodge ram quad cab offroad 4x4 HEMI
dodge_sst1 is offline
post #5 of 6 Old 10-02-2005, 02:03 PM
lobo2013
Post
I know this is an old post, but if you have not yet found the problem, try this, check your coil, do an Ohm test. I recently bought the same truck, it had no power, the fellow selling it said there was no compression in #3 cyl. After I did a compression test, which resulted in good compression through-out all cylinders, I started looking elsewhere, and found the coil resistance was higher than specified. After a $15 replacement, I had all the power I should, with what had been done to the vehilce. It had an 8 inch lift, 35" tires when I bought it. I'm in the process of re-gearing it to compensate for the tall tires, in order to bring back "stock" performance in the power band. Hope this helps anyone having similar issues.
lobo2013 is offline
post #6 of 6 Old 10-02-2005, 03:17 PM
Hemi Pete
The Legendary Cross Ram
Hemi Pete's Avatar
Welcome to DodgeTalk.com, and good information too.
*DodgeTalk.com
President*
In Rememberance Of The Vehicles I Have Once Owned:
1986 Toyota Tercel DX-"Puddle Jumper"-29,911.0 total miles-18 months/23 days owned...recieved August 9th, 2004.
1993 Dodge Intrepid SE-"Candy Girl"-3,050 total miles-1 month/15 days owned...bought November 22nd, 2005.
"DO A DANCE!"
Hi, my name is Peter: DT member # 26,805.
"Hold on Luke, it's time to Yeeehaaaw!!!"
Hemi Pete is offline
    Dodge in Hot Pursuit of Police Car Market with HEMI®-powered 2006 Dodge Charger FreeLantz Rumor Mill & Gossip Talk 42 06-04-2006 05:22 PM
    2006 Ram 1500 Info FreeLantz 3G Dodge RAM - General Talk 120 02-20-2006 01:09 AM
    2006 Dodge Ram 1500, What's New for '06 RAM MAN Rumor Mill & Gossip Talk 4 07-19-2005 10:31 AM
    2006 Dodge Magnum, What's New for '06 RAM MAN Rumor Mill & Gossip Talk 1 07-13-2005 10:21 AM
    Trucks: “grab Life” Attitude And “burn Rubber” Performance RAM MAN Rumor Mill & Gossip Talk 0 08-01-2003 03:41 PM
