Go Back   Dodge Talk Community Forum > Dodge Vehicle Forums > Caravan Talk
rickloni
  Unhappy alternator problem - Posted: 01-18-2003, 06:15 PM
State: OTHER
Post #1
Can anyone help?
I had a bad alternator and after I changed it every time I start my van the console lights flash on and off. After I drive awhile they go out. I'm wondering if I have to reset something or maybe my battery is gone. Suggestions Please.
six pack
 Posted: 01-19-2003, 07:20 PM
six pack's Avatar
State: AB
Post #2
You haven't said what year your van is so I am going to assume it is a 96-2000 model. If this is the case you will have to perform a quick learn procedure of the heater controls. I would stop by your friendly dealer to ask to use his service manual, or if you can't do that I can try to find time to look it up for you. But can't promise a speedy response.
Hope this helps
1970 Challenger R/T convertible
1972 383 Swinger
Cummins 6.7L MegaCab owner member#1.
See Pics Here!
My Challenger
My Gallery
Don't forget to nominate and vote for the vehicle of the month categories, it couldn't be any easier with the following links.Vote Here
Nominate Here
Car of the Month Award!:  - Issue reason: Jan 04 Car of the Month Winner!Car of the Month Award!:  - Issue reason: Dec 04 Car of the Month Winner!Vintage Mopar of the Month Award!:  - Issue reason: Mar 07 Vintage Mopar of the Month Winner!
rickloni
 Posted: 01-19-2003, 08:19 PM
State: OTHER
Post #3
Thanks for your help. Its a 1998 dodge caravan its the buttons for the back wipers and air conditioner that are flashing. I will try and get an owners manual but bought used so i did't get one.
six pack
 Posted: 01-19-2003, 08:38 PM
six pack's Avatar
State: AB
Post #4
You need to get the service manualto get the procedures for recalibrating the heater controls.
This is why your lights are flashing.
1972 383 Swinger
See Pics Here!
My Challenger
My Gallery
Nominate Here
ddg
 Posted: 03-03-2003, 12:02 PM
State: CA
Post #5
I have the same problem after the battery died. My friendly Dodge dealer wants to "perform a diagnostic check" on the van. No price quote given, but it will not be free.
They did the same thing in June of 2000 when the original battery died. Cost was $50 for the recalibration. I stood there and tried to see what order they pressed the heater/ac buttons. Unfortunately, I don't remember all they did.
I greatly appreciate any information given. I have never owned a vehicle that was such a PIA and costly to replace a battery.
DDG
FYI - 1998 Grand Caravan SE
ddg
  Blinking Lights fix - Posted: 03-10-2003, 12:20 PM
State: CA
Post #6
Listed below is the procedure I found to fix the blinking heater control lights.
With engine on set blower motor to high, set mode position knob to panel (i.e. full left), open all A/C outlets, set temperature to cold (both levers if so equipped). Now press the wash and rear wiper buttons on the A/C panel simultaneously for 5 seconds (until all LED's light). This should get the test started. Assorted lights on this panel will flash as different tests are run.
Eventually, if the tests are passed the rear wiper LED should be the only light flashing. Push the rear wiper button to exit test mode and you should be home free.
In my case, after about 15 minutes, all lights went off, and everything worked properly after that. I did this while driving.
