Button to turn off traction control? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 07-24-2005, 05:45 PM Thread Starter
'03 MOPAR R/T
'03 MOPAR R/T's Avatar
Is it true that the Charger has a button to disable the traction control and stability control programs? If so, this would make modding the Charger quite a bit easier than the trucks so far huh?!
If it is true, then that is the best of both worlds, it's there if you want it, disableable if you don't! I love control/choices!
2005 Rumble Bee truck__________2010 Charger Rallye
Previous beloved Mopars: 2008 Avenger R/T, 2005 Neon SXT, 2003 Stratus Sedan R/T
'03 MOPAR R/T is offline
post #2 of 9 Old 07-24-2005, 06:28 PM
Ram3500Dually
Ram3500Dually's Avatar
Quoted: 38 Post(s)
The 300c has a button on the dash, don't know about the Charger
2013 Ram 3500 CTD 6.7L 6 Speed Aisin, 4:10 LSD
2005 Jeep Liberty Sport
1991 Shadow ES Turbo Convertible
1984 Mini-Ram Van (Show Van) **TOTM April 2007** In museum now
73 Pro Street Duster.**VOTM July 2008/ April 2011**
1951 Dodge 3 Window Business Coupe **VOTM Feb 2011**
1992 Custom Built Harley FXSTC Show Bike
2008 Harley FLHTCU Ultra Classic
DodgeTalk Administrator
Names Carl, if you cut me I bleed Mopar Blue
Past Trucks: 90 CC Dually CTD, 94 RC LB CTD, 95 CC SB 5.2L gas, 98 QC Dually CTD, 00 QC Dually CTD, 01 QC Off Road, 03 QC Dually CTD, 05 QC Dually CTD, 08 Dually CTD **ROTM April 2008**,10 CC Dually CTD,
Ram3500Dually is offline
post #3 of 9 Old 07-24-2005, 08:21 PM
2k2_AtlanticBlu
287 cu inches of pain
2k2_AtlanticBlu's Avatar
Traction control and stability control aren't even on Rams, torque management on the other hand is and I am sure it can't be turned off on any of the cars or trucks. So it wouldn't affect how you mod them at all.
Andrew
2002 Atlantic Blue Dodge Dakota 4X4 Club Cab 4.7 Auto
Dodgetalk.com 287 Enthusiast Member #32
COIN HOLDERS ASSN #287 The H.O.
2k2_AtlanticBlu is offline
post #4 of 9 Old 07-24-2005, 11:45 PM Thread Starter
'03 MOPAR R/T
Other than name, is there any real difference to what happens when either "Electronic Stability Program" engages as opposed to what happens when "Torque Management" engages other than "Shit Happens"?
Take a look at the Specifications page for Charger at Dodge.com and then go to "Additional Options" to see what it says about ESP.
I'm in no way saying this is true, but my speculation on how both the trucks and cars EFFECTIVELY "de-tune" the motor (a term I'm using rather than any other catch-22 popular phrase to avoid knee-jerk reactions due to terminology discrepancies) is that the computer senses wheel spin via abs brake sensors and when out of parameters sends a signal to the electronic throttle to close the throttle blade and effectively reduce power from the motor.
Whatever you or Dodge wants to call it, does the Charger have the ability to KEEP ALL ITS MOTOR'S POTENTIAL POWER UNHINDERED by pushing a button?
If the answer is true, then the Charger by DESIGN would take to engine related modifications (for the purpose of power output increase) BETTER than the trucks because inherently the Charger wouldn't have to resort to black magic spells and voodoo rituals to GET RID of "Torque Reduction"; all that would be required would be a simple touch of a button and VIOLA, instant FULL POWER OUTPUT!
A simple button push, much to George Jetson's objection, sounds A HELL OF A LOT EASIER (TO MOD) than voodoo sacrafices and endless speculative posts on the matter of bypassing the TRUCKS "Torque Management"!
WOW! Sounds kinda like "If so, this would make modding the Charger quite a bit easier than the trucks so far huh?!"....hummm...
I don't care how you get there or what you call it, but it sounds like the cars MAY (italicized for an indication of voice inflection, specifically to indicate an opinion or an uncertainty) be easier to mod than trucks. Sounds like POTENTIALLY good news!!!
File Type: jpg Charger Electronic Stability Program.jpg (67.1 KB, 4 views)
post #5 of 9 Old 07-25-2005, 06:12 PM
chargin06
Yes - ESP can be controlled on the dash of a Charger...
chargin06 is offline
post #6 of 9 Old 07-26-2005, 10:47 AM Thread Starter
'03 MOPAR R/T
Well, I recently read somewhere that the button does not totally deactivate ESP, it only changes it to a more aggressive setting. Can anyone confirm or deny this?
post #7 of 9 Old 07-26-2005, 10:55 AM
Ram3500Dually
Quoted: 38 Post(s)
You are exactly right. I was out in my fathers 300C with him a couple of weeks ago. I pressed the ESP button on the dash at a stop, dropped the slap stick into first and did a little brake torque and released and the car went sideways 2 gears and had a real nice tail spin going when all of a sudden the ESP kicked in and the car went straight and took off. I thought it must have just been a kink in his system but maybe that is the way it is supposed to be
post #8 of 9 Old 07-26-2005, 01:13 PM
done
AWD is the right way
done's Avatar
That is correct. You really have to work to get it out of shape enough to activate the ESP when the button is "off".
By all acounts that I have read, it is more difficult to "mod" the Hemi LX cars for performance than the Hemi trucks.
Black Magnum RT AWD
done is offline
post #9 of 9 Old 07-26-2005, 01:46 PM
COCharger
MOPAR Fan Forever
COCharger's Avatar
From everything I've read on the LXForum, turning on the button (shutting off ESP) only deactivates the throttle control. The traction control using the ABS brakes is still active. That gives you the ability to do burn outs if you are so inclined. But only so far until the traction control kicks in to regain traction. I have seen 30 to 40 foot burn out videos, so it can still be fun.
Another thing I have read is that if you remove fuse #17, you shut down the entire system. However, you'll end up with peg-leg one tire burn outs because the traction control is not trying to keep both wheels turning. Power dumps to the lose tire and it spins like crazy. Remember they do not have LSD.
2006 Charger Daytona R/T -+- #1740 of 4000
COCharger is offline
    Computer Codes 2nd Gen OBDII Afterfx Dodge Neon - General Talk 2 08-14-2005 07:58 PM
    Code P0203-HELP rudegirl 1G Dodge Durango General Talk 3 03-31-2005 12:07 PM
    00-02 Codes dvgRT Dodge Neon - General Talk 0 06-13-2004 01:25 PM
    P0601 Error jgonick 1G Dodge Durango Performance Talk 7 06-11-2004 12:33 AM
