Instrument Cluster Not Working - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 07-23-2005, 08:53 PM Thread Starter
kikin
kikin's Avatar
I HAVE A 1995 DODGE NEON SOHC AND MY INTRUMENT CLUSTER IS NOT WORKING.WHEN I START THE CAR THE TEMPERATURE GAUGE GOES ALL THE WAY UP TO HOT AND THE TACHOMETER IT'S NOT WORKING,SOMETIMES IT MOVES.DOES ANYBODY KNOW WHAT COULD BE CAUSING THIS?
1998 DODGE DURANGO 5.2L 4X4.SUPER 40 SERIES FLOWMASTER EXHAUST SYSTEM.SUPERCHIPS MICRO TUNER.CUSTOM COLD AIR INTAKE.K&N AIR FILTER.20" KMC CONDOR WHEELS.TV AND DVD .
kikin is offline
post #2 of 6 Old 07-24-2005, 04:19 AM
dodgeneonACR98
So whats UR excuse?
BE CHECKING YOUR ALTERNATOR BELT MAN. My 98's guages quit on me and sometimes the speedometer would be sayin like 85 and I was doing 2. To make a long story short, I broke my alt belt on a down shift,raceing some punk. I won! But it didn't take long for me to figure out what my guage prob's were.I drove her home on the battery ( what a damn fine battery it is too) and the weaker the battery got the more my guages went nutz.I made it home some 25 miles later only to have it die as I pulled in the driveway....I put on a new belt and have had no prob since.......
Some do have "cold" solder joints.There is a how-to on what to look for and how to fix it yourself im not sure where its at but I have seen one......GOOD LUCK!
Squad member #53 [/url]
04 Neon SRT-4
98 Neon ACR-2.4 swaped with goodies
dodgeneonACR98 is offline
post #3 of 6 Old 07-24-2005, 09:31 AM Thread Starter
kikin
kikin's Avatar
Thank you for the advice.I will check the belt maybe that is the problem like you said.
kikin is offline
post #4 of 6 Old 07-26-2005, 12:44 AM
RadarLove
The connectors into the instrument cluster are kind hokey. They don't snap/lock into place, so they move around a lot. Could be coming disconnected or otherwise losing the normal connection. There are also problems with the solder points on the cluster side, but that tends to be the speedo. On the 1st gens, the J2 (right side) conector comes in at a particularly bad angle. My '95 has issues with the speedo wire getting a bit over extended (not a problem now, dash removed...)
Best of luck!
RadarLove is offline
post #5 of 6 Old 07-26-2005, 01:16 PM
EZ4U2CHere
EZ4U2CHere's Avatar
Clusters in 1st gen neons are infamous for going bad. I've had to replace mine. I think I paid about $30 at a bone yard with a guarantee it would work when I got home.
2003 Dodge RAM 1500 QuadCab HEMI SLT Sport Flame Red! : Work in progress
22" KMC SS Wheels / Gaylords X2000 Tonneau w/ SpeedSturr Wing / Ground Force Drop / SuperChips Programmer / Magnaflow 14589 Muffler / K&N FIPK / Alpine CDA-9853 Head Unit / 1/2 DIN DVD player in dash / 7" Monitors in Headrests / EGR Fender Flares / Mopar Fender Shields / Rumble Bee Lower Valence / Bumper grill insert to match the stock grill / WestSideVinyl bed stripes and matching hood stripe / WeatherTech In-Channel Wind Deflectors / Clear Corner Lens / Billet Alluminum Gas Lid (painted to match) / Taylor Shorty Wires / PIAA fog light bulbs /SilverStar Headlight Bulbs / Titanium Chrome turn signal bulbs / Billet Shorty Antenna / Rear Wheel Well Liners / LED's in cup holders and dash cubby / Painted to match door handles, brake calipers, and lots of stuff painted to match under the hood
'96 Plymouth Neon Expresso DOHC MTX: Fast, but not Furious
KONI Yellows / Mopar X-High Rate Springs / 15x7" Rota Slipstreams / 205/50/15 Azenis / Mopar Peformance Computer / Ceramic Coated Pacesetter Short Tube Header / MPx UDP / 3.0 CAI / 22mm Front Sway Bar / 22mm Adjustable Rear Sway Bar / Deyemme Racing Motor Mounts / Prothane Motion Control Suspension Bushings / Booger Shifter Bushings / Hawk HP Plus Brake Pads / PT Cruiser Valve Train
EZ4U2CHere is offline
post #6 of 6 Old 10-25-2005, 04:08 PM
98NeonR/T2.0
98NeonR/T2.0's Avatar
In my 98 R/T Neon once in a while I'll drive down the road and all my gauges will shut off. All I do is give my dash a good tap on the left side of the instrument panel and boom! Your gauges are working.
98NeonR/T2.0 is offline
    Died at idle penguinsluvme 1G Dodge Durango General Talk 19 05-13-2005 06:11 AM
    Instrument Cluster Swap Possible?? ruswilliams 1G Dodge Durango General Talk 5 08-23-2004 10:52 AM
    Instrument cluster failure katrina Vintage Dodge Car Forum 0 08-21-2004 10:07 AM
    DC to Repair Durango Instrument Cluster Circuit Board RAM MAN Rumor Mill & Gossip Talk 0 12-14-2003 10:16 PM
    Air Bag light Came On TEXAS DODGE 3G Dodge RAM - General Talk 3 02-20-2003 01:18 PM
