1987 D-100 lug pattern diameter - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 07-19-2005, 07:42 PM Thread Starter
jdhaines32
jdhaines32
jdhaines32's Avatar
Quoted: 5 Post(s)
I have a 1987 D-100 Series truck with 15 inch wheels and hub caps on, and I want to put a set of new wheels on my truck and eliminate the hub caps. I was told that i can only get a wheel with a lug pattern of 5" or 5 1/2". I measured the wheels on the truck now and they are a 5 1/4" lug pattern. Can anyone tell me if i may have measure from the wrong area of the lug, because i found a website on the net that lists my as having a 5 1/2" diameter. I also read a thread on here the other day that said dodge only had wheels with a 4 1/2" or a 5 1/2' lug pattern.
jdhaines32 is offline
post #2 of 2 Old 07-19-2005, 10:13 PM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
Your truck has has a 5 1/2" lug pattern. Previous to 1985, the lug pattern was 4 1/2"
If you order custom wheels you will need to get wheels with a 5 on 5 1/2" pattern...and Ford wheels won't fit your Dodge eventhough the lug patterns are the same, it's the center hole that's different.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
    Lug Pattern Change Huck_fer 2G Dodge Dakota - Tire/Wheel/Susp Talk 2 06-23-2005 09:57 PM
    SEMA SHOW Info :Nov 4-7th RAM MAN Show and Event Talk 5 10-31-2003 10:41 PM
    Lug pattern for an 01' D??? DavidRo 1G Dodge Durango General Talk 2 09-16-2003 03:11 PM
    Lug pattern on Dakota? Helevitia 2G Dodge Dakota General Talk 8 09-11-2003 08:13 AM
    Lug pattern on an 2002-2003 1500 ram? Toe 3G Dodge RAM - General Talk 3 01-28-2003 09:45 PM
