Go Back   Dodge Talk Community Forum > Dodge Vehicle Forums > Caravan Talk
swsteve
  Question 1999 Grand Caravan Fan Relay? - Posted: 01-13-2003, 09:24 AM
State: KY
Post #1
I have a 1999 Grand Caravan 3.3L V6. The service engine soon light came on about 90,000. I went to Autozone and had them check for codes. The code of "1491" came up which is the radiator fan relay. My question is where is the relay located? Is it is the fuse box or is it located near the radiator? What does the relay look like?
Thanks,
Steve
daltman
 Posted: 01-13-2003, 11:06 PM
City: N.O.E. Ohio
State: OH
Post #2
it's screwed to the frame rail, approx under your air filter.... box
in that area..
drivers side, looking up from the underside of the van, see the air cleaner housing, look towards the ft bumper, and possibly behind the air deflector for the raidator...
either 3 or 4 wires running to it, 1/4" thick, 2" tall, 1" wide.
six pack
 Posted: 01-19-2003, 07:24 PM
six pack's Avatar
State: AB
Post #3
This is a solid state item, not your typical relay.
I would double check the rad fan fuses first. if you have a blown fuse try replacing it and do a battery disconnect. You should check your rad fan motors too to make sure they are OK.
1970 Challenger R/T convertible
1972 383 Swinger
Cummins 6.7L MegaCab owner member#1.
See Pics Here!
My Challenger
My Gallery
Don't forget to nominate and vote for the vehicle of the month categories, it couldn't be any easier with the following links.Vote Here
Nominate Here
Car of the Month Award!:  - Issue reason: Dec 04 Car of the Month Winner!Vintage Mopar of the Month Award!:  - Issue reason: Mar 07 Vintage Mopar of the Month Winner!Car of the Month Award!:  - Issue reason: Jan 04 Car of the Month Winner!
jandgreg
  Radiator fan relay - Posted: 03-01-2003, 06:06 PM
City: seffner
State: FL
Post #4
I have a 98 Caravan 3.0 eng., and experienced the same problem. I changed the relay 2 weeks ago and it worked fine until about 3 days ago. Fuses are good and fans work when you bypass the relay. Any ideas why it keeps going out would be great!
98 Caravan, radiator fan relay jandgreg Caravan Talk 12 05-07-2004 04:02 AM
Fan Clutch Help!!! FastDak47 2G Dakota Performance Talk 21 03-09-2004 07:01 AM
Malfunction codes Gentleman 3G RAM - General Talk 2 02-15-2004 09:18 PM
Engine Light on at 21,100 miles ColoradoQuadCab 2G Dakota Performance Talk 6 11-17-2003 03:25 AM
