Vacuum Leak Locations - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 07-18-2005, 12:32 PM Thread Starter
Silver_DodgeRam
Mmmmmmmmm, beer.
Silver_DodgeRam's Avatar
Quoted: 2 Post(s)
Hey all,
I noticed a lot of people post about there vacuum leak issues, such as the ac/fan switching to the defrost under load. To help people locate there vaccum leaks easier, I thought we could all post where we found our leak at. Perhaps there are some common areas where leaks develop, and by documenting them in a single thread, other folks who have this issue can start with those areas when searching for their leak. Maybe we can make this a sticky thread at the top of this forum or something.
For me, it was a tiny hole in the vacuum line that runs next to the passenger side frame rail next to the exhaust. The exhaust had burned a tiny hole in the line. New vacuum line cost me about $30, and it took less then 20 minutes to change. Symptoms were the usual blower switching to defrost under load, and also the 4x4 not disengaging very quickly (also vacum operated).
2009 Dodge Ram 1500 4x4, 5.7 Hemi, Crew - work in progress
2008 Chrysler Aspen 4x4, 5.7 Hemi, Loaded
Silver_DodgeRam is offline
post #2 of 10 Old 07-18-2005, 04:44 PM
Futon Type R
The R is for RELAX...
Futon Type R's Avatar
Q...do I have a Vacuum line problem if: When I accelerate the a/c stops coming through the vents, but rather the defrost; and then after I decelerate, there is a loud *very noticeable* popping sound that ensues, followed by my air coming back on?
Hate for this to be my first post, but it's something that's been buggin me for years.
Futon Type R is offline
post #3 of 10 Old 07-18-2005, 05:18 PM
Futon Type R
My "noobness" has already shone through my rough exterior, I found the thread dedicated to this *exact* problem. Will post where the leak is coming from as soon as I find it and fix it.
post #4 of 10 Old 07-18-2005, 07:05 PM
VABLKRAM
There is a check valve on the pass side intake manifold, they tend to go bad
it is located under the line for the PVC valve .
This is a common problem for the AC switching from vents to defrost
cost $ 3.50
Not sure about the popping you are getting
VABLKRAM is offline
post #5 of 10 Old 07-18-2005, 07:11 PM
RAM MAN
Originating Member
RAM MAN's Avatar
hmm
good to know info, as I have this problem with my Ram VAN right now ...
I'll just have to try and locate the check valve
THANKS
Good luck on your project.
RAM MAN is offline
post #6 of 10 Old 07-18-2005, 11:21 PM
dtracymoto
dtracymoto's Avatar
Quoted: 2 Post(s)
Under the intake manifold the bolt on plate was where mine was. The thing would ping, a/c would change, brakes sucked, tranny shifted odd, would jump in and out of overdrive, all fixed with 4 or 5 hours of my time and a new gasket with sealer this time.
dtracymoto is offline
post #7 of 10 Old 07-19-2005, 04:29 PM
Futon Type R
Took it my local dealer today, turns out it was a blown Plenum pan gasket, which means I'm going to have to reseal and replace the intake gasket, and go ahead and replace the bypass hose that runs from the intake to the water pump. They quoted me about $500 out the door...but a local guy I trust told me now more than $300. Damn dealer still got my $80 from the diagnostics! Oh well, saving at least a hundred bucks, not to mention a headache from having to work with the dealer.
Oh yeah, and it should also fix this insane whistling sound that was the pan actually sucking air, and not pressurizing properly. 6 mechanics in 1 month and none of them had ever heard anything like it. I'm going to try and post the video I made of it on here, assuming it's not too large...
post #8 of 10 Old 07-19-2005, 05:34 PM
VABLKRAM
The belly pan gasket is a BIG problem with our trucks, Be sure you are using the right repair kit or you will end up redoing the entire job over.
I got my replacement kit from http://www.hughesengines.com/general...enum_cover_kit
and did the job myself. this was 4 months ago and so far so good. I would recomend this to anybody who dose not want to replace the intake manifold with the M1 intake.
VABLKRAM is offline
post #9 of 10 Old 07-20-2005, 08:33 PM
DODGEIT
DODGEIT's Avatar
Quoted: 1 Post(s)
I have had my plenum gasket replaced once last November. It has blown again. I have a MP 1 intake going on in a few days. Also had problems with the cruise control servo.
Mine is located under the battery on the drivers side. Battery dripped acid and ate a hole in the plastic vacumm line going to the servo. Cut out the bad spot and replaced it with a rubber hose and that fixed the problem.
2012 Dodge Ram 1500 Big Horn QC 4x4
DODGEIT is offline
post #10 of 10 Old 07-21-2005, 09:42 AM
Mickey95-5.9
Vaccum leak? AC stops when accelerating
My 1995 5.9 does the same thing....I did not see that anyone really gave you the answer or solution... Did you find out where the problem is?
Thanks....
Mickey95-5.9 is offline
    Computer Codes 2nd Gen OBDII Afterfx Dodge Neon - General Talk 2 08-14-2005 08:58 PM
    Code P0203-HELP rudegirl 1G Dodge Durango General Talk 3 03-31-2005 01:07 PM
    00-02 Codes dvgRT Dodge Neon - General Talk 0 06-13-2004 02:25 PM
