92 Grand Caravan SE no gauges working - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 07-17-2005, 05:32 PM Thread Starter
jet276
I have a 92 Grand Caravan SE that I was driving to work one morning and it quit. When I looked under the hood I quickly seen the negative cables pulled out of the battery clamp (guess thats what i get for buying cheap replacement clamps last year). I loosened up the bolts that clamp the cables in and reinserted the cables. The van started and ran just fine again but the 3 gauges (speedometer, fuel, and temp) have not worked since this happened. The cruise control works fine and the indicator lights seem to work fine. I have two of these vans and have been swapping parts between the two so i can determine what the problem is. So far I have swapped the computer next to the battery and on the firewall, dash clusters (gauges) and the entire wiring cluster under the hood which included all the fusible links. Is there a relay or some sort of controller that runs the gauges only that may have been affected? Any suggestions would be greatly appreciated. Thanks
jet276 is offline
post #2 of 3 Old 01-28-2006, 12:47 PM
flyingwolf
Do a serch on here ofr IOD fuse and you wil have your answer.
flyingwolf is offline
post #3 of 3 Old 01-30-2006, 03:48 PM
flyingwolf
Well it seems I may ahve been mistaken here, I know on my 92 there seems ot be no IOD fuse present, that or I cannot find the SOB.
    Weekend project completed ... gauges all working and CB install ... mikegronholz 3G Dodge RAM Diesel Talk 24 07-21-2005 03:53 PM
    no bus, no gauges possible solution Aggie Ed 2G Dodge RAM - General Talk 1 06-10-2005 08:32 AM
    SPEEDO and GAZ GAUGE Not working... loowee Dodge B-Series Vans 1971 - 2003 5 02-16-2005 12:17 PM
    Stratus gauges stopped working Wreck 2G Dodge Stratus - General Talk 3 07-26-2002 12:51 AM
