920 -921-999 error codes?????? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 19 Old 07-14-2005, 12:57 AM Thread Starter
sharphome
sharphome's Avatar
Does anybody know what error code 920, code 921 means on my Dodge Ram(99). It will just quit running and I get these messages in the odometer window. It will sit and cool down awhile then start back up until it gets hot again. Any help friends?
sharphome is offline
post #2 of 19 Old 07-14-2005, 05:47 AM
RAM MAN
Originating Member
RAM MAN's Avatar
hmm
sorry, I had a code list, but dont see those on there
anyone else ?
Good luck on your project.
RAM MAN is offline
post #3 of 19 Old 07-15-2005, 05:38 PM
crazys182003
Quoted: 5 Post(s)
P0920 Gear Shift Forward Actuator Circuit/Open
P0921 Gear Shift Forward Actuator Circuit Range/Performance
Not sure if that is exactly what you are looking for but found them at
http://www.obdii.com/codes.asp
crazys182003 is offline
post #4 of 19 Old 07-16-2005, 07:32 AM
RAM MAN
Originating Member
RAM MAN's Avatar
nice link
thanks
I'll add it to my "favorites"
RAM MAN is offline
post #5 of 19 Old 07-16-2005, 08:03 AM
Tech_John
Tech_John's Avatar
Quoted: 3 Post(s)
It looks like the Self Diagnostic Codes from the cluster
Here is a list for a 99 Ram
INSTRUMENT CLUSTER FAILURE MESSAGES
Message Description Correction
110 A failure has been identified in the cluster CPU, RAM, or EEPROM.
1. Replace the faulty cluster.
900 The CCD data bus is not operational.
1. Check the CCD data bus connections at the cluster. 2. Check the cluster fuses.
3. Check the CCD data bus bias.
4. Check the CCD data bus voltage.
5. Check the CCD data bus terminations.
920 The cluster is not receiving a vehicle speed message from the PCM.
1. Check the PCM software level and reflash if required.
2. Use a DRB scan tool to verify that the vehicle speed message is being sent by the PCM.
921 The cluster is not receiving a distance pulse message from the PCM.
2. Use a DRB scan tool to verify that the distance pulse message is being sent by the PCM.
940 The cluster is not receiving an airbag lamp-on message from the ACM.
1. Check the CCD data bus connections at the ACM.
2. Check the ACM fuse.
950 The cluster is not receiving an ABS lamp-on message from the CAB.
1. Check the CCD data bus connections at the CAB.
2. Check the CAB fuse.
999 An error has been discovered.
1. Record the failure message.
2. Depress the trip odometer reset button to continue the Self-Diagnostic Test.
MOPAR 2014 Top Tech
There are 27 TOP TECH's out of 22,000+ Mopar technicians in the USA
21+ years MOPAR experience
Tech_John is offline
post #6 of 19 Old 07-21-2005, 09:40 PM Thread Starter
sharphome
sharphome's Avatar
Well problem ended up being the gosh darn computer......Tempature problem with it. The No BuS message was telling me the computer shut down and would not even get a signal from it. Had a shop hook it up and make sure.......Now I get to buy a new PCM.
post #7 of 19 Old 07-22-2005, 05:34 AM
RAM MAN
Originating Member
RAM MAN's Avatar
well glad you got that figured out, and thanks for posting the outcome, it may help someone else with this same problem some time
RAM MAN is offline
post #8 of 19 Old 07-22-2005, 05:58 AM
RAM MAN
Originating Member
RAM MAN's Avatar
I bought a performance one from http://www.garyhardy.com/en_US/
and it was the cheapest I could find, either locally OR on the internet ...
RAM MAN is offline
post #9 of 19 Old 07-22-2005, 11:54 PM Thread Starter
sharphome
sharphome's Avatar
Was the performance PCM already programmed or did you have to have it programmed? I am getting told that the dealer is the only place I can get a new one that is programmed right.
post #10 of 19 Old 07-23-2005, 06:31 AM
RAM MAN
Originating Member
RAM MAN's Avatar
Most places you can buy from now are able to go ahead and put your VIN number in the computer, so all you have to do is unplug your old one, and plug in the new one ....
RAM MAN is offline
post #11 of 19 Old 07-23-2005, 11:51 AM Thread Starter
sharphome
sharphome's Avatar
Thanks for the Gary Hardy website info. They are only about a hour drive away from me here in Kansas. Appreciate your help. I alos found one at Autozone for 296.00 think they are any good?
Rick
99' Dodge Ram QC Sport 4x4
http://sharptruck.tripod.com/my_dodge_album
post #12 of 19 Old 07-23-2005, 06:37 PM
RAM MAN
Originating Member
RAM MAN's Avatar
should be fine
RAM MAN is offline
post #13 of 19 Old 07-28-2005, 12:20 PM Thread Starter
sharphome
sharphome's Avatar
Got my new computer from Autozone. Took the 3 bolts out unplugged it, plugged in the new one and bolted it up.... Started up and runs like a champ again. Sure saved me alot of money by not taking it to a dealer. AND IT WAS EVEN EASY TO DO...LOL. Thanks for all the help and input.
YEEEHAWWW my truck will finally run for more than 20 minutes at a time again.
I also put a set of new premium champion plugs in after 62000 miles. the old ones were a little burnt off. It idles alot smoother now.
Rick
post #14 of 19 Old 07-28-2005, 07:13 PM
RAM MAN
Originating Member
RAM MAN's Avatar
did they put your VIN number in for you ?
RAM MAN is offline
post #15 of 19 Old 07-28-2005, 10:06 PM Thread Starter
sharphome
sharphome's Avatar
No, I guess it didn't need to be done. They said it was all ready to go. It runs fine without that being done...... I guess..LOL>>??? Should it be done? I really don't know much about PCM's.
Rick
post #16 of 19 Old 07-29-2005, 08:18 AM
RAM MAN
Originating Member
RAM MAN's Avatar
you bought a MOPAR Performance one ?
RAM MAN is offline
post #17 of 19 Old 07-29-2005, 03:48 PM Thread Starter
sharphome
sharphome's Avatar
No actually it is a remanufactured PCM.
Rick
post #18 of 19 Old 07-30-2005, 10:21 AM Thread Starter
sharphome
sharphome's Avatar
Do you think it needs the vin flashed in it Ram Man? I think someone told me O'Reileys can reflash a PCM now.
Rick
post #19 of 19 Old 07-30-2005, 10:37 AM
RAM MAN
Originating Member
RAM MAN's Avatar
I'm confused, but I guess if its running OK and you have no codes, let her rip !!
RAM MAN is offline
