2017 Ram 2500 Power Wagon Review - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 1 Old 02-06-2017, 11:30 AM Thread Starter
AutoGuide.com
Senior Moderator
Quoted: 1 Post(s)
As the 2017 Ram 2500 Power Wagon climbed the jagged rocks I’m not sure I could climb with my own two feet, it seemed an unstoppable force.
Seeing any truck make this climb would be impressive, but there is something about the massive 6,996-pound heavy duty pickup scaling the rocks that truly seems to defy physics.
For 2017, the Power Wagon is all grown up, offering new looks and a few small tweaks to make it even better. Up front, the truck borrows the grille from its little brother the Ram Rebel and rids itself of the childish graphics that were offered on the previous truck, offering a much cleaner 'Power Wagon' graphic on the sides of the box. A new powder coated front bumper has also been added to protect it from the scraping of the winch cable.
Besides these small upgrades, the recipe for this big brute hasn’t changed. Powering the wheels is a 6.4-liter V8 good for 410 horsepower and 429 lb-ft of torque, sent through a six-speed automatic transmission. A total of 14.3 inches of ground clearance helps to clear everything on the ground along with a 33.6-degree approach angle, 26.2-degree departure angle and 23.5-degree breakover angle.
But the real off-road wizardry comes from a few special systems and components, not the least of which is a disconnecting sway bar. This allows the truck a massive 26 inches of wheel articulation, making sure that all four wheels stay in contact with the ground, despite undulating terrain. A BorgWarner 44-47 transfer case helps with crawling duties, allowing the truck to run in two-wheel drive, four-wheel drive high and four-wheel drive low, with a crawl ratio of 2.64. Best of all, there is still a manual transfer case handle in the cab, allowing the driver the satisfaction of pulling the truck into four-wheel low with a great ka-thunk of the lever.
Read more about the 2017 Ram Power Wagon Review at AutoGuide.com.
AutoGuide.com is offline
Quote Quick Reply
    I'm back! Member since 2002! 2017 Ram 1500 Laramie Grant211 4G Dodge RAM - General Talk 3 02-05-2017 10:51 AM
    New 2017 Ram Tradesmen Express owner Ramseyfosho 4G Dodge RAM - General Talk 2 02-01-2017 08:06 PM
    Power Ram vs Power Wagon Bruce Koukalaka 1972-1987 Dodge Ram Trucks (D, W-series) 6 12-27-2016 09:18 AM
    2016 Power Wagon Tow Rating Clayx 4G Ram Power Wagon Talk 5 12-22-2016 11:19 AM
    2003 dodge ram 2500 suspention on a 1997 dodge ram 2500 builtnotbought1 2G Dodge RAM - General Talk 3 11-14-2016 01:54 AM
    You may not post new threads
    HTML code is On
