Oil on spark plug
- Posted: 07-07-2005, 05:23 PM
Post #1
New to the site and glad to find it. I was looking for performance upgrades for a 4 door 2000 Stratus with the 2.0 engine, but am about to give up and just accept the lack of acceleration.
I recently did the first spark plug change (36,000 miles) and found a little oil on the first plug on the pax side. This was on the ceramic part, not on the working end of the plug, that looked fine. My mechanic said it is not a real issue but would cost about $200 to repair. Is this a possible fix for a DIY with reasonable mechanical skills? What is involved? TIA |
| Sponsored Links |
Posted: 08-13-2005, 09:53 AM
Post #2
I have the same issue with mine. Any info would help!!
Posted: 08-14-2005, 09:26 AM
Post #3
if i remember the 2.0 head correctly they have deeply recessed plugs. The problem is that there are sleals around the tubes that go thru the head, the seals on them can either go bad or were not installed properly, my guess would be to take off the valve cover and check the ones there and if there ok, then they are the seals at the bottom of the tube. bout a couple undred bucks to have your mechanic do.
Jim PROUD MEMBER WCPW (the origional thread) Silver Truck club member #5 Cloudcars.org 1955 1/2 Dodge Town Panel Truck Buildup happeneing The Green Reaper Click HERE to view the complete signature... |
Posted: 10-16-2005, 10:20 AM
Post #4
I had the same problem on my 2000 Stratus SE, 2.4. I had a little oil in two of the recessed spark plug holes. If you replace the valve cover gasket (which comes with the new seals around the spark plugs), you will be fine. Let me know if you have any more probs.
| Sponsored Links |
Posted: 01-23-2006, 02:05 AM
Post #5
I just changed my valve cover gasket for the same problem....2000 stratus 2.4....I work at an auto shop so if your mechanic is charging you 200 bucks you should ask him to provide vaseline....it takes 0.7 hours labor and about 20-30 bucks for the gasket....
| Thread Tools | |
| Plugs and Mileage????? | Derbydriver13 | 2.5L, 3.9L, 5.2L, 5.9L, V10 Tech | 3 | 04-19-2005 09:45 AM |
| bosch or autolite? | kwicsand | 1G Durango Performance Talk | 11 | 11-16-2004 08:28 PM |
| Autolite 3923 Plugs | BigJohn82 | 1G Durango Performance Talk | 13 | 08-20-2004 10:20 AM |
| Anyone have feedback on Bosch +4? | huh? | 1G Durango General Talk | 19 | 06-16-2004 01:19 PM |
| How About some Q&A | Tazz411 | 3G RAM - General Talk | 7 | 12-29-2002 07:21 AM |
| Sponsored Links |
