Temp. Gauge not working - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 06-29-2005, 06:04 PM Thread Starter
rwtapp
rwtapp
After doing the intake plenum gasket repair my gauge does not work.
I was very careful with the intake when cleaning it.
Could the manifold be air locked or bad sending unit?
I checked the sending unit with an ohm meter and it seems fine?
rwtapp is offline
post #2 of 4 Old 06-29-2005, 09:53 PM
98QuadCabV10
EPA's Worst Nightmare
98QuadCabV10's Avatar
Which gauge are you talking about? Coolant?
1998 Ram Quad Cab 2500 Short Bed V10 4x4
C.A.I.
Headers.
SCT Tuner
3" SRB Lift
Fast Man TB
GM Push Rods
2" Leveling Kit
1.7 Roller Rockers
Exhaust: No cats, Flowmaster 50
Best Runs
60': 2.27
1/8th: 10.23 @ 68.56 MPH
1/4: 15.93 @ 85.7 MPH
0-60: 7.9sec
V10 Ram Club #1
98QuadCabV10 is offline
post #3 of 4 Old 06-29-2005, 10:54 PM Thread Starter
rwtapp
rwtapp
The coolant gauge.
I replaced the sending unit, checked the connector out and it still doesn't work?
rwtapp is offline
post #4 of 4 Old 06-29-2005, 11:25 PM
98QuadCabV10
Sorry I miss read your topic. Feel like an idiot now.
Turn your ignition key to the "on" position with the engine not running and measure the amount of volts you have at the connector. There should be 5 volts.
You can also measure the Resistance of the sensor. Measure it when the engine is hot and when it is cold. There should be a difference.
Your temp gauge could be working properly and your thermostat could be stuck open making your gauge read cold all the time.
Also make sure the cooling system is full of coolant.
Sometimes there is more than 1 temp sensor. 1 for the computer and 1 for the gauge. Make sure you are checking the right one. If your not sure you can replace both.
C.A.I.
Headers.
SCT Tuner
3" SRB Lift
Fast Man TB
GM Push Rods
2" Leveling Kit
1.7 Roller Rockers
Best Runs
60': 2.27
0-60: 7.9sec
V10 Ram Club #1
    Egt Gauge Not Working wcbcruzer 2G Dodge RAM - General Talk 17 04-17-2005 08:50 PM
    trans cooler and trans temp gauge help bigredtank 2G Dodge Ram Performance Talk 0 03-21-2005 12:05 AM
    SPEEDO and GAZ GAUGE Not working... loowee Dodge B-Series Vans 1971 - 2003 5 02-16-2005 12:17 PM
    Fuel Gauge Not Working ollhippieinsc Dodge Dakota 1st Gen (87 -96) Forum 4 12-24-2004 10:58 AM
