Set timing on 98/5.9 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 06-26-2005, 03:38 PM Thread Starter
1Ram98
I inherited a 98 Ram 5.9 after the previous owner tried changing the distributor cap and ran into problems that snowballed into bigger ones (destroyed distributor base, moved distributor out of timing).
To make a long story short I bought and installed a new distributor (first one I seen without a drive gear on it). I installed it in exactly the same spot as the old one and would now like to manually time the engine with a timing light.
Where is the connector or pigtail located that I would have to disconnect before setting timing? The engine is at TDC, and the rotor isn’t pointing at the number one firing piston (3 o’clock from # 1 piston. Thanks in advance for your help.
1Ram98 is offline
post #2 of 4 Old 06-28-2005, 06:46 AM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
You cannot set the timing via the distributor anymore. It's controlled by the ECM. The only thing the distributor does now is supply spark of course, but it has a cam sensor inside that controls injector timing.
TDC (comp. stroke) on no. 1 cylinder on a smallblock Mopar the rotor should be facing about the 1 o'clock position. After this is acheived, there is a notch in the distributor housing that needs to be lined up with the rotor. This is called "indexing" the distributor. The distributor on a Mopar Magnum engine should never be turned to try and adjust timing....it doesn't work that way anymore.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #3 of 4 Old 06-28-2005, 11:25 AM Thread Starter
1Ram98
Thanks for the reply Nate, I will let you know how I make out.
1Ram98 is offline
post #4 of 4 Old 06-28-2005, 09:43 PM
BVRmonger
Yes. The distributor has to be set correctly to time the fuel injectors. Turning the dist will not effectively adjust the ignition timing.
BVRmonger is offline
    What are symptoms of loose timing chain?? 2shus Dodge Ram Truck 1st Gen (88 - 93) Forum 8 03-12-2005 08:33 AM
    Question about using a timing light on a 88 model 2shus Dodge Ram Truck 1st Gen (88 - 93) Forum 5 02-17-2005 07:19 AM
    Erector Set helps design engineer RAM MAN Rumor Mill & Gossip Talk 1 01-05-2004 10:00 AM
    You may not post new threads
    You may not post replies
