NEED help PLLZZZZZZZZZ!
- Posted: 06-18-2005, 12:41 AM
Post #1
what 5 speed transmission willl fit on my 2.4L dodge strartus!!!! and how hard of a swap is it
| Sponsored Links |
Posted: 06-18-2005, 01:06 AM
Post #2
PT Cruisers have a 2.4L engine and have a 5spd manual option. This trans. would probably bolt right up, BUT not sure about linkages and mounts.
Didn't Stratus' have a manual transmission option?
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Click HERE to view the complete signature... |
Posted: 06-18-2005, 07:25 AM
Post #3
Well it all depends on which years you mean, if youmean the 95-00 ie 1st gen then there are 5spd strats you can get the tranny and pcm from or get a neon tranny and pcm, however with the neon you will lose a little bit of speed due to a dif gearing. If you have a 2nd gen 01-current, you will have to either find the PT or the strat with it, i dont think that the new neons willfit the new strats.
Jim PROUD MEMBER WCPW (the origional thread) Silver Truck club member #5 Cloudcars.org 1955 1/2 Dodge Town Panel Truck Buildup happeneing The Green Reaper Click HERE to view the complete signature... |
| Sponsored Links |
hi
- Posted: 06-24-2005, 01:13 AM
Post #4
will the 95 dodge stratus 2.0l soch 5 speed transmission. fit on my 98 2.4l dohc. plz tell em
Posted: 06-27-2005, 09:30 PM
Post #5
take a look on stratusphere.org. there has been plenty members that have the 2.4 that have done the swap. I have read that they use the Neon RTs 5 speed
2001 Dodge Stratus ES 4Dr. 2.7L Magnum DOHC V6. |
Posted: 06-27-2005, 11:28 PM
Post #6
yera but with the neon rt tranny i will lose power instead of gaining it
Posted: 06-28-2005, 06:59 AM
Post #7
Why not try and find a 5spd out of an SRT-4? They have the 2.4L engine and I'm sure the trans. is geared aggressively.
Posted: 06-28-2005, 10:38 PM
Post #8
I think the final drive is just as high in the RT tranny than the SRT4 tranny.
Posted: 06-30-2005, 09:53 PM
Post #9
I'm pretty sure the 2.4 in the '01+ Stratus' are Mitsu motors, whereas the 2.4's in the PT's and SRT-4's are Chrysler motors. I'd be browsing the boards at 2gStratus.org or eclipseforums.org or Club3g.com.
There's lots of good feedback there. FYI, be sure to do a thorough search on each before asking that question. You'll be flame target #1 otherwise. :p Good luck.
2001 Stratus R/T 3.0L Autostick Stage 1 Supercharger 272whp 232wtq Link to my car |
Posted: 06-30-2005, 11:40 PM
Post #10
Posted: 06-30-2005, 11:43 PM
Post #11
My bad then. I dunno nuthin' about that motor. If it is the same as the SRT-4, I'd be looking at that trans too. DCM put a lot on technology into that from what I hear. While you're at it, swap the head and bolt up that turbo! ![]()
| Thread Tools | |
| Sponsored Links |
