Middle leaf removal.... - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 06-13-2005, 09:42 PM Thread Starter
Low1
Slammed1 this is directed to you, although anyone with experience can chime in.
i am wanting to take the middle leaf spring out and acheive a level look, is there a step by step to this procedure somewhere? i have searched and found the overload spring removal but nothing of the middle leaf.....any thing would be great
"Money will buy you a book, but not knowledge."
2006 3500 CTD Quadcab Dually
2004 SRT-4
Low1 is offline
post #2 of 15 Old 06-14-2005, 02:25 PM Thread Starter
Low1
no one has anything?
2004 SRT-4
Low1 is offline
post #3 of 15 Old 06-14-2005, 05:41 PM
slammed1
slammed1's Avatar
I will get you some info when I get home!!!
slammed1 is offline
post #4 of 15 Old 06-15-2005, 09:55 AM
jlhram
Yea It's a Hemi!!!!!
jlhram's Avatar
Slammed did mine, he made it look easy. I do remember he had to shear off the alignment bolt on the leafs to make it fit right, and don't forget to use his shackles. Most important get the truck up high enough to use jack stands and then use your floor jack to take the tension off the spring. I'm sure Brian can explain it better, but I hope this helps.
jlhram is offline
post #5 of 15 Old 06-15-2005, 10:07 AM
slammed1
slammed1's Avatar
the rolled pin needs trimmed.....the center tie bolt can be re-used........I recommend a short bumpstop and either shorter rear shocks or rear shock extensions!!!
slammed1 is offline
post #6 of 15 Old 06-15-2005, 11:52 AM
derekrf
derekrf
derekrf's Avatar
Do you still keep your overload spring after removal of the middle leaf? We're talking three inches from this mod?
derekrf is offline
post #7 of 15 Old 06-15-2005, 12:13 PM
Black05Hemi
Hemi Power
I'll chime in here... I think you do keep the overload. And, the drop is like 3 1/2" I think. If i'm wrong, it wouldn't be the first time...
2005 Ram 1500 SLT QC
12.88 @ 104.96 N/A
Powered by Inertia Motorsports
Black05Hemi is offline
post #8 of 15 Old 06-15-2005, 12:41 PM Thread Starter
Low1
I have access to a lift so the lifting high enough part is taken care of. Slammed1 do you have pics of the rolled pin that need to be trimmed? and also what do i need as far as pinion alignment? and the total amount lowered was 2-7/8" to about 3-1/4" depending on how it settles. i am planning to do this in the very near future(like tonight or tomorrow night) so thanks for the info so far...
2004 SRT-4
Low1 is offline
post #9 of 15 Old 06-15-2005, 12:42 PM Thread Starter
Low1
one other quick thing, if i were to remove the overload and the middle leaf what am i looking at as far as towing ability and ride? long term effects too...
2004 SRT-4
Low1 is offline
post #10 of 15 Old 06-15-2005, 07:26 PM
jlhram
jlhram's Avatar
IMO I would not remove both, with just the middle leaf removed on my quad, it dropped it 3 good inches and it rides real nice, I don't tow but I have had it loaded down with concrete and it did fine. Definately get some better shocks with the drop or it will be too spongey. rolled pin yea that's what that thing was called, don't make me get out my claw hammer Slammed...
LMAO
jlhram is offline
post #11 of 15 Old 06-15-2005, 09:43 PM
LeeR
LeeR's Avatar
What did you guys use to trim the roll pins?
2007 Dodge 1500
Big Horn Edition
5.7 Hemi 2wd
LeeR is offline
post #12 of 15 Old 06-16-2005, 10:51 AM
jlhram
jlhram's Avatar
sawsall
jlhram is offline
post #13 of 15 Old 06-17-2005, 07:45 PM
RAMSLT8
RAMSLT8
RAMSLT8's Avatar
Here's a pic of my truck with S1S shackles and the center leaf removed. Took about 2 hours with a floor jack and stands. Also to make up for the payload loss I installed some Gabriel air shocks. Also removed the bump stops to avoid any bottoming out.
RAMSLT8 is offline
post #14 of 15 Old 06-17-2005, 08:28 PM
LeeR
LeeR's Avatar
Looks great Ramslt8. That is exactly how I'd like my truck to look. When you trimmed the roll pin was it hard? I want to do it, but I'd have to use a hacksaw to trim it.
2007 Dodge 1500
Big Horn Edition
5.7 Hemi 2wd
LeeR is offline
post #15 of 15 Old 06-17-2005, 09:46 PM
RAMSLT8
RAMSLT8
RAMSLT8's Avatar
I just used a cut off wheel to cut mine, but you could do it with a hacksaw.
RAMSLT8 is offline
    02-04 2wd Ram 1500 Leaf Springs Or 4x4 Leaf Springs bigcahunaus 3G Dodge RAM - Sport Truck Talk 2 02-07-2005 09:01 AM
    Leaf spring supports Silver_DodgeRam 2G Dodge RAM - 4X4 Talk 6 02-05-2005 08:14 PM
    Middle Leaf removal...How is the ride?? jeffvb9 3G Dodge RAM - General Talk 3 01-18-2005 06:22 PM
    Helper Spring vs Middle Leaf NoHemi 3G Dodge RAM - Sport Truck Talk 19 12-15-2004 09:54 AM
    Under Middle Seat bdcustoms 3G Dodge RAM - Interior/Exterior Talk 5 09-23-2003 10:15 PM
