Bent Rear Axle - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 06-03-2005, 05:34 PM Thread Starter
WillSing4ACure
Question Bent Rear Axle
I just found out that I have a slightly bent rear right axle. How long can I drive my B2500 before it becomes dangerous?
I don't have much money for repairs, so I am hoping that I can stretch it out a bit.
Thanks.
WillSing4ACure is offline
post #2 of 9 Old 06-03-2005, 05:40 PM
v10sport
Built Not Bought
v10sport's Avatar
How did it get bent? Who told you it was bent. Thats a very hard t hing to do. If its the rear axle, it make track funny.
2000 Dodge 2500 Quad Cab LB V10 with many many mods.
7500 pounds
1/8th 10.193
67MPH
1/4 16.024
84.01 MPH
05 610 CTD QC 4x4 Needs some mods
02 Jeep Grand Cherokee 4x4
v10sport is offline
post #3 of 9 Old 06-03-2005, 06:35 PM Thread Starter
WillSing4ACure
Rear Axle
I had a new set of tires put on today. When the tech turned the right rear tire, there was a bit of a wobble. He pulled the tire off and checked the balance again, and that was fine. He also turned the hub that the wheel fits on and there was a wobble on that.
He told me that he thought that the axle may be slightly bent.
Any advise or suggestions?
Thanks.
post #4 of 9 Old 06-03-2005, 07:57 PM
v10sport
Built Not Bought
v10sport's Avatar
What rear axle to do have? If its a Full float axle, sounds like loose/bad hub bearings.
7500 pounds
1/8th 10.193
67MPH
1/4 16.024
84.01 MPH
v10sport is offline
post #5 of 9 Old 06-03-2005, 08:36 PM
gray bear
gray bear's Avatar
If it is bent outside the bearing area or at the hub, you can stretch it out for a while, but it will cause some funky tire wear. We had one bent on an old 74 powerwagon and drove it that way for years, before replacing the axle. It may also cause some bearing wear, but usually only if it is bent in that area of the bearing or inside the axle shaft housing.
gray bear is offline
post #6 of 9 Old 06-03-2005, 09:08 PM
Nodak213
U.S. Registered EMT-B
I always thought that bending an axle was nearly impossible. At least not without doing some sort of massive damage to your truck. ie - Car accident, serious 4wd action, stuff like that
I would have the bearings checked out first...
2005 Ram 2500
Turbo Cummins Diesle
Manual Trans.
Metalic Gray
" in memory of my "94", You were no match for a drunk"
Nodak213 is offline
post #7 of 9 Old 06-04-2005, 04:37 AM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
You can always go the junkyard and buy a used axle and have it installed. Since this isn't a common problem, using a used part won't bite you.
I wouldn't drive too long on a bent axle. Just my opinion.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #8 of 9 Old 08-06-2005, 10:18 AM
bocephus
I have bent axles pulling holeshots in my GS...they will bend before they snap...how your van did it I dont know...has it a HEMI ?...hehehe
bocephus is offline
post #9 of 9 Old 08-12-2005, 11:01 PM
chigato
I have a 96 b2500 with the exact same problem. right rear vibration starting at 40 mph , as if you were under a bridge with a run-away freight train overhead, and eventually smoothing out at 70-75 mph. After being stone-walled by the !@#$%^&*() dealer 6 times from whom I bought it, I finally said !@# %^, and went through the most simple obvious items first,i.e. tread,balancing, and finally, jacking up the back end, putting it in gear and watch that wheel spin like a paint shaker. That infamous day was March of 2003. I am still driving it. I'm debating whether to go to a boneyard and swap it out, rebuild it, or go to a merciless, motherless, satan's-pride-and-joy,!@#%%&*()+ dealer and "RAM" it right back up his merciless, motherless, coldblooded,satan's-pride-and-joy,where the sun don't shine,looks-just-like-a-salesman's lips, !@#. By the way,it was a ford dealer.
chigato is offline
    Need Help On Rear End Axle ?'s charger_2fast4u Mopar Muscle Talk 6 05-29-2005 09:19 PM
    Axle fluid change HEMANGO 2G Dodge Durango - Drivetrain Talk 2 02-14-2005 11:01 AM
    2005 Dodge Ram Power Wagon Specifications RAM MAN Rumor Mill & Gossip Talk 0 10-01-2004 07:12 PM
    Rear axle oil L.D.P. 3G Dodge Ram Performance Talk 11 02-01-2004 11:12 PM
    2004 Dodge Truck Highlights RAM MAN Rumor Mill & Gossip Talk 2 08-06-2003 12:46 PM
