Stratus stumbles on acceleration
- Posted: 06-02-2005, 03:04 PM
Post #1
Hi
I have a 2000 dodge stratus v6 engine. I just had the spark plugs, wires and distributor cap, and rotor replaced and the seals on the spark plug tub. Because it was jerking really badly. The next morning it didn't want to stay running and once It finally leveled it would stumble on acceleration. Does any one have any ideals? thanks alot. ![]() |
| Sponsored Links |
Posted: 06-02-2005, 08:18 PM
Post #2
How does it run once you get rolling?
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Click HERE to view the complete signature... |
Posted: 06-03-2005, 11:29 AM
Post #3
Once it gets rolling it runs beautifully, yesterday. But it still has a little jerk when it idles.
Posted: 06-04-2005, 05:10 PM
Post #4
This car is driving me crazy. Every morning I crank it up it stumbles and want to cut off. If you put her in drive she shuts off. But crank right up and has a ruff idle. And after it warms up it runs fine. What could possibly be the problem. We checked all the vacuum lines and wires. Nothing, I took it back to the mechanic and the car" ran fine" No nothing. Can someone please help.
Posted: 06-28-2005, 09:32 PM
Post #5
I hope someone can help me, well this morning after about two weeks of the problem my car has finally stop cranking. I would have to let it warm up for at least 10 minutes before it would run without stalling. It acts as if it wants to crank but it just rotate.
Posted: 06-30-2005, 09:58 PM
Post #6
Hmm...I'm sure your mechanic checked the alternator voltage. The Mass Airflow Sensor (MAS) in these cars is a P.I.T.A. I'd make sure that is checked out as well. The only other things I can think of are the MAP sensor going out on the top of the intake plenum. Not very common though.
Does your speedo or tac jump around at all during stumbling? I forgot to connect my main ground to the firewall once and the car ran like total crap. Stumbled, hesitated, stalled...the works. That's the braided wire from the intake plenum to the firewall. Wish I knew what else to check. Hopefully you find it quick. Assuming it's a 3.0 v6? I know nothing about the 2.7's.
2001 Stratus R/T 3.0L Autostick Stage 1 Supercharger 272whp 232wtq Link to my car |
Posted: 06-30-2005, 10:45 PM
Post #7
Thanks for the imput. Find out it was the disturbutor.
| Sponsored Links |
Posted: 06-30-2005, 11:43 PM
Post #8
the 2000 is the 1gsedan and its the 2.5L V6 and its a mitsu motor
2001 Dodge Stratus ES 4Dr. 2.7L Magnum DOHC V6. |
| Thread Tools | |
| Should i get a stratus??? | BuddhamanJB | 2G Stratus - General Talk | 4 | 06-27-2005 08:55 PM |
| Dodge/Chrysler Stratus? | panzerjohn | Stratus 1st Gen (95 - 00) | 6 | 06-19-2005 04:26 PM |
| installing amp - 98 stratus 2.4 | nomoreGMforme | Mobile Audio & Electronics Talk | 3 | 07-08-2004 11:12 AM |
| 2004 Dodge Car Highlights | RAM MAN | Chrysler LLC Press Releases | 0 | 08-01-2003 03:38 PM |
| 2003 Dodge Stratus Coupe and Sedan | RAM MAN | Other Dodge Vehicle Talk | 8 | 11-23-2002 09:36 PM |
| Sponsored Links |
