Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Vintage Dodge Truck Forums > 1972-1987 Ram Trucks (D, W-series)
donster
  Unhappy Flooding carburator - Posted: 04-29-2005, 09:06 PM
Post #1
I have a 1980 D50 2.6 that I replaced the fuel pump. Now the engine will start but run only for a minute or two and then the carburator floods out and the engine dies. Its so wet thereafter that it will not stop. Its mainly the passenger side of the two barrels. Could the fuel pump be defective? It wasn't doing this prior to the new fuel pump. Any help will be greatly appreciated!! Thanks in advance!
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
GHS
 Posted: 04-29-2005, 10:38 PM
Post #2
The needle valve in your carb is probably worn or sticking. The new fuel pump might be putting out a bit more pressure which the needle valve is unable to close off. It could also be a sticking or mis-adjusted float.
Chump
 Posted: 04-30-2005, 05:00 PM
Chump's Avatar
State: CO
Post #3
Time to rebuild the carb.
Speed Dragon
 Posted: 05-01-2005, 10:05 AM
Speed Dragon's Avatar
Aka Force Fed Mopar
City: Campobello, SC
Post #4
haha, those carbs are almost impossible to rebuild properly. The best advice I can give anybody who has a D50 and plans to keep it, is to dump the stock carb and buy a Weber conversion kit. The weber carb is 10 times better than the stock carb, better response, better milige, better reliability. Yeah it's a lot of money to spend on a D50, but you won't have near the problems(the stock carbs are noturious for screwing up) and you're gonna spend 230 buck if you buy a stock replacement anyway.
Another route you could take is to just get the adapter plate for the Weber, and then get a 2bbl carb off an early 2.3 Ford, like a Mustang or a Pinto. Same pattern, and they were actually made by Weber too, and they are cheaper to come across.
'72 D100 Reg Cab long bed, 318, 5-spd swap
'73 D100 Club Cab short bed, in limbo, could be for sale
'80 D150 short bed stepside, S6 4-spd OD
'93 D150 short bed, 5.2 Magnum, 5-spd
FS: '72 318 block, bored .030 over, new freeze plugs, Cheap
Chump
 Posted: 05-01-2005, 10:25 AM
Chump's Avatar
State: CO
Post #5
Speed Dragon? Is that one of those Asian type carbs with all the vacuum diaphrams and attachments that you dont get parts for in the rebuild kits?
Speed Dragon
 Posted: 05-01-2005, 01:43 PM
Aka Force Fed Mopar
Post #6
The stock one is, yeah. I swapped out 3 of them on mine when i had it(one of which looked like a brand new one), all 3 were bad, so I finally bought the adapter plate for the Weber, and put an old Weber 32/30 I found on an old Datsun in the junkyard on it, and never had anymore carb problems.
88 dodge flooding ? Crazz 2.5L, 3.9L, 5.2L, 5.9L, V10 Tech 1 03-07-2005 05:11 AM
