Aftermarket overdrive
- Posted: 04-25-2005, 10:34 PM
Post #1
I recently purchased a 1974 D200. I am trying to locate a bolt on overdrive for the 3 speed automatic.... any ideas ???
| Sponsored Links |
Posted: 04-26-2005, 09:42 PM
Post #2
Posted: 04-28-2005, 08:26 AM
Post #3
$2600!? wow...
Posted: 04-28-2005, 11:48 AM
Post #4
It might be easier, and cheaper, to swap in the A-518 Torqueflite. You'd want the A-518 built prior to '96 or '97 because those are electronic controlled.
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Click HERE to view the complete signature... |
Posted: 04-29-2005, 01:52 AM
Post #5
are there any options for taller gearing/overdrive in the 4 spd. manual (225)?
thank you |
Posted: 04-29-2005, 04:50 AM
Post #6
Technically the 4spd. is an OD transmission. What rear end gearing are you running now?
Posted: 04-29-2005, 02:33 PM
Post #7
I don't know that- she's an '85 W150 with the "granny" first gear. I'm planning on driving cross-country with her and was hoping to prep for 75mph speeds.
Posted: 05-01-2005, 10:08 AM
Post #8
Find you a 3.23 geared rear end to swap in. You'll need a new speedo gear to go with it so your speedo reads right. I got about 18mpg on the highway in my 72 with a 318 3-spd manual.
'72 D100 Reg Cab long bed, 318, 5-spd swap '73 D100 Club Cab short bed, in limbo, could be for sale ![]() '80 D150 short bed stepside, S6 4-spd OD '93 D150 short bed, 5.2 Magnum, 5-spd FS: '72 318 block, bored .030 over, new freeze plugs, Cheap ![]() ![]() |
Posted: 05-02-2005, 08:56 AM
Post #9
Is this the same for me? I have a full time 4x4, I'd need the front and rear gears right?
Posted: 05-02-2005, 05:26 PM
Post #10
yeah if you are 4x4 you'll need the front and rear. Gattboy, same for you since you are 4x4.
| Thread Tools | |
| Those with 4.56 gears, I've got a question... | Villains | 3G Ram Performance Talk | 105 | 07-26-2005 11:08 PM |
| Overdrive Problems... | Ubergamer | 2G RAM - Drivetrain Talk | 3 | 10-30-2004 10:54 PM |
| backfire 45 to 50 mph only in overdrive | raysthevolume | 2G RAM - General Talk | 3 | 09-06-2004 04:15 PM |
| '99 Durango Overdrive Issues! | reward | 1G Durango - Drivetrain Talk | 2 | 06-16-2004 08:45 AM |
| overdrive OFF button? and louder horn | Bryanh23 | 2G RAM - General Talk | 12 | 01-05-2003 05:07 PM |
| Sponsored Links |
