Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Vintage Dodge Truck Forums > 1972-1987 Ram Trucks (D, W-series)
jmg86w150
  Brake Question - Please Help! - Posted: 04-16-2005, 08:24 PM
Post #1
I have a 1986 Dodge W150 with a 318 and I need some help on a brake problem I am having. Hopefully someone can assist me. When stopping, the truck pulls to the right real hard and I can not figure out why it is doing that. Here is what I have attempted so far to fix the problem.
1. Replaced both right and left side rotors.
2. Replaced both calipers.
3. New brake pads.
4. Replaced both right and left brake hoses from caliper to hard lines.
5. made sure hard lines were not clogged or damaged all the way up to the proportioning valve.
6. Bled all four brakes, starting at the passenger side rear, drivers side rear then passenger side front and finally driver side.
7. Installed new brakes on the rear and adjusted them accordingly.
I do not think it is in the brake booster because it is a single line that is then split off to both sides.
Please help if you have any suggestions.
jmg86w150
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
Chump
  Lightbulb  Posted: 04-18-2005, 02:24 AM
Chump's Avatar
State: CO
Post #2
Did you rebuild the rear wheel cylinders or replace them?
Also are the rear drums cut oversize and are both sides cut the same amount..may be time for new drums? If the rear drums are cut uneven than one side will grab faster then the other. You also need to go through your front end and check ball joints, tie rod ends, etc, some shops will do this for free, just dont commit to having the work done.
When you replaced the front calipers did you lube all the sliding surfaces with a very thin coating of hi temp disc brake grease and/or did you replace the caliper mounting hardware kits?
Does the red brake warning light come on when you brake?
Banfiadh
 Posted: 04-21-2005, 06:25 PM
Banfiadh's Avatar
Banfiadh
City: St Cloud
State: MN
Post #3
This might sound stupid, I know you replaced the calipers, but is one of the pistons in backwards or wedged?
A pull to either side is generally a front brake problem.
BanFiadh....save the world-eat a chevy for breakfast
D.O.D.G.E. drips oil drops grease everywhere
Bowties, meant to be worn, not driven.
IH, the second choice for Smart people.
Everyone should own a Ford, theyre good for towing chevies.
Personal Responsibility, NOT Social Responsibility
My Truck(s) http://www.cardomain.com/memberpage/570923
jmg86w150
  RE: Brake Question - Plase Help! - Posted: 04-21-2005, 11:36 PM
Post #4
1. I did replace the rear wheel cylinders on the truck.
2. I did hve the rear drums turned, but I have not confirmed that they are the same size. I will check that to see if they are within tollerance.
3. Your right about the ball joints, tie rod ends, etc it is probally tme to go through those as well.
4. I did lube all the sliding parts and also replaced the retaining hardware with the new ones that were supplied with the calipers. The calipers are OEM pieces from dodge and they came with everything I needed.
5. The brake light does not come on when I apply the brakes and they do not feel spongy or anything like that.
Thanks for all the tips. I will let you know what I find.
jmg86w150
jmg86w150
  Re: Brake question - Please Help! - Posted: 04-21-2005, 11:41 PM
Post #5
I do not believe the caliper piston is jammed or install backwards. I have pressed the brake with the caliper uninstalled and the piston moves freely through it's full travel.
Thanks
ram_225
 Posted: 04-22-2005, 01:45 PM
ram_225's Avatar
^ dont we all wish ^
Post #6
if the brakes feel spungy and the brake lights dont come on it sounds like u might not have bled the brakes enough, and there could still be an air bubble, im not shure if that would cause ur pull to one side or not though.
1984 dodge D100 long box
225 slant six
3 spd auto
2wd
31X10.5r15 meats
15X8 rims
home made stario system
jmg86w150
  Re: - Posted: 04-23-2005, 03:53 PM
Post #7
I thought I had bled the brakes enough. I started in the far rear of the truck then moved to the driver side rear then to the passanger front and finally the driverside front. I will run through them again today to see if that helps and clears up the problem. Thanks.
Robbie
  brake problem - Posted: 04-26-2005, 05:15 PM
Post #8
Thats a lot of work. I've owned Dodge trucks all my life and have had brake problems, but what you did should have worked.
Check tie rods and drag link also (unlikely steering box) lift front end, center steering wheel turn each back and forth, is the resistence the same? I, at one time had deffective ball joints that made steering sticky in spots but not your problem.
Good Luck
brake question njbiggdogg 2G RAM - General Talk 11 04-17-2005 07:14 PM
Quick Brake Question Tomex23 2G RAM - General Talk 7 01-30-2005 10:49 AM
front brake question from newbie to forum fingers588 1G Durango General Talk 7 10-18-2004 05:22 PM
Stopping Tests on Bendix brake parts with 3500 wheel cylinders HankL 2G RAM - Drivetrain Talk 1 10-25-2002 07:52 AM
