serious octane
- Posted: 04-13-2005, 07:56 PM
Post #1
I just bought and used Accelerator from lonewolfperformance.com. It raised 5 gallons of 91 to 105 octane, I added 5 additional degrees of spark advance and 25 psi boost and no knock was recorded on the scanner, All that from a quart can. It was just about 79.00 per 6 can case. Nice to have a can in the trunk just in case I wanna get heavy footed.
| Sponsored Links |
Posted: 04-17-2005, 08:15 PM
Post #2
dose the can say whats is in it because that seems a little outrageous that quart would have to have an octane of 385 to give you those results i know they use toluene and xylene in most octane boosters and they only have an octane rating of 114 and 117 respectively. if it dose what it claim thats amazing but I'm skeptical
Posted: 04-17-2005, 09:04 PM
Post #3
the octane booster that i see on the self only raises 1 octane level, 93 to 94. it says will raise 10 points, one point being equal to .1 octane. is this the level it raises "points" not actual octane. It should say in the fine print. The one i am talking about is 0-60 octane booster. I think that is the name.
Brad
1995 Avenger ES SOLD 2003 Silverado SS Mods 03 Silverado SS Volant ram air CAI with ram air tube, ASP underdrive pulley, Zippy PCM tuning, FLP stage 5 trans with sonnax 2nd and 4th gear servo's and billet input/output shafts, TCS 3800 stall, magnaflow dual in dual out muffler, MSD wires, and SS brake lines, TEA stage 2.5 heads, Revolution Raceworks custom ground comp cam, OBX long tubes, centerline rims, dual scan gauge, HPM electric fans, Meziere electric water pump, comp cams tensioner, .040 cometic head gasket, gmpp cts-vr lifters, comp cams push rods, yella terra rockers, 180 SBC stat., hughes flexplate, rear air bags, beltech front shocks, victor jr intake, custom elbow, green top injectors, aeromotive fuel rails, magna fuel reg. x-link, 90mm tbss TB. 12.828 et, best 60' 1.633. dyno'd 464.9 RWHP, waiting on new et for 42 RWHP increase 2000 Dakota 4.7L 4x4 15.28 ET sold Mods Intense performance intake, poweraid TB spacer, HO cams, 69mm fastman, 180 stat, gibson 3" ss single pipe, JBA headers, ASP underdrive, Kennebell PCM, Bilstein shocks, power slot rotors, 2400 stall Fastman converter, HO intake, Optima red top battery. Click HERE to view the complete signature... |
Posted: 04-17-2005, 10:32 PM
Post #4
Ive used this product for 2 years. It raises 91 pump gas to 105 motor octane. I run it in my turbo car at 25 psi with 16 degrees advance at 25 psi and the data logger has NO knock and no spark retard.
The off the self boosters are junk and you are correct about the 1 point = .1 in octane. This is esentially a concentrate of the additive package they use to bring up octane in unleaded race gas. Its also available in leaded formula as well. I got mine from lonewolfperformance.com, if it didnt work I wouldnt run it iun my car, esepcially at 25 psi boost. |
Posted: 04-18-2005, 06:21 PM
Post #5
hmmmmm, going to have to look into this.
Thanks for the info! Brad
There are other
- Posted: 04-27-2005, 01:27 PM
Post #6
race gas concentrates on the market too. 16oz cans that raise octane to 100+. Guys on the NASIOC board (Subaru wrx and STi) forums use. I'll get the name of the product. In the long run it's more expensive than Toulene but alot less hassle.
It's called
- Posted: 04-27-2005, 01:29 PM
Post #7
TORCO Race Fuel Concentrate
Posted: 04-28-2005, 09:07 AM
Post #8
If you say make 5 gallons of 105 Octane, the Torco is less expensive, safe for the fuel system and has a better burn than Tolulene as well as being more convienient.
It would take 3 gallons of Tolulene and 2 gallons of 91 pump gas to make 5 gallons 105. With Torco you use 1 can to 5 gallons, plus you get the benefite listed in the first paragraph. Tolulene doesnt have lubricity agents and its harder on the fuel system. Also the flame tail on the burn is really weird and not good for combustion. |
Posted: 04-28-2005, 09:32 AM
Post #9
Torco is good stuff i used to run it in my modded 99 GTP i was getting 4 degrees of KR on 93 pump when running torco i have 0. could feel a nice difference in the car.
1973 Dodge Challenger- 440 bore .030 TRW pistons,Ported/polished heads with 2.20/1.84 valves Edlebrock high rise dual plenum intake with a Demon 850 on top. That's being pushed through a Mopar 2000 stall sitting in a TCI race trans. 8 3/4 rear with 4:10 posi putting it to the ground through a set of 275/60/15 and a N.O.S 125 shot for fun
| Sponsored Links |
| Thread Tools | |
| Why the higher Octane? | J_C | 1G Durango General Talk | 5 | 03-19-2005 07:22 AM |
| Octane booster | clava | 2G RAM - General Talk | 3 | 12-06-2004 11:34 PM |
| Question on Octane, and Dodge recommendations. | JQuest64 | 3G RAM - General Talk | 27 | 09-24-2004 06:51 PM |
| Choosing An Octane (03 Ram 4.7L) | 03Ram4.7 | 3G RAM - Drivetrain Talk | 14 | 08-30-2003 09:42 PM |
| Roe Supercharger and Octane | SUN RA KAT | Viper - General Talk | 3 | 02-04-2003 07:58 PM |
| Sponsored Links |
