Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Vintage Dodge Truck Forums > 1972-1987 Ram Trucks (D, W-series)
milspece6
  1986 Dodge Ram W150 engine check light - Posted: 03-28-2005, 09:58 PM
Post #1
undefinedundefinedundefined
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
milspece6
 Posted: 03-28-2005, 10:01 PM
Post #2
I need to know how to clear the "check engine light" from my instrument panel. I have checked erg, pcv and all other guages and all are okay. I don't want to have to pay $75.00 just to short out a plug.
Thanks,
<milspec@telpage.net>
Chump
 Posted: 03-28-2005, 10:47 PM
Chump's Avatar
State: CO
Post #3
Try pulling the negative battery cable off for a few minutes and see if the light stays off.
mpr_ldy
 Posted: 04-01-2005, 07:07 AM
Dodge Fan
State: WV
Post #4
How many miles are on it? My 85 Ramcharger's light came on it there is a box behind the glove compartment that you have to replace a 9V battery & use a pen to reset the button. It's set up to go off like every 50K miles or so.
Dodgevanman
 Posted: 04-01-2005, 11:50 AM
Dodgevanman's Avatar
Do It In A Van
City: Baltimore Hon!
State: MD
Post #5
I thought that was some kind of emissions "timer"????
Nate the skate
5.2L Magnum
1972 B200 Royal Sportsman Maxiwagon
318/2bbl.
1985 B150
318/2bbl.
Click HERE to view the complete signature...
Chump
 Posted: 04-01-2005, 01:20 PM
Chump's Avatar
State: CO
Post #6
Oooops...86 doesnt have a computer.
Try this...
On 1983-86 Pick up Trucks and Ramcharger, the module is located to the right of the steering column. On 1987 Pick up trucks and Ramcharger, the module is located to the right of the glove compartment.
Slide module from bracket.
Insert a small screwdriver into small hole on module case and close switch.
Remove module battery cover and install a replacement 9 volt battery.
Position module on mounting bracket.
Jimal Temus
 Posted: 02-27-2006, 09:14 PM
Jimal Temus's Avatar
Hi-O Silver, Away!
City: Bristol, CT
Post #7
This is great. I didn't even have to post my question and I found my answer. I had this exact issue with the '87 D-100 I picked up last weekend. I pulled the box, but the only hole I found in the box had the battery immediately behind it. I unplugged the box, removed the battery, waited a few seconds, and put everything back together. The light is now out. Will need to get a new 9 volt, that can wait.
Thanks,
Jim
2006 Charger Daytona R/T (DCX press release) FreeLantz Chrysler LLC Press Releases 41 04-16-2005 10:16 AM
"Excuse Me Officer..." RAM MAN Chrysler LLC Press Releases 9 04-03-2005 12:30 PM
2004 and Select 2005 New Vehicle Pricing RAM MAN Chrysler LLC Press Releases 0 03-21-2004 10:42 AM
Dodge Ram Heavy Duty Cummins "600" RAM MAN Chrysler LLC Press Releases 6 03-18-2004 03:43 PM
2005 Dodge Magnum Engineering Press Releases RAM MAN Chrysler LLC Press Releases 0 03-03-2004 09:55 AM
