Go Back   Dodge Talk Community Forum > Dodge Vehicle Forums > Caravan Talk
angldrkns9
  transmission fluid - Posted: 11-08-2002, 06:18 AM
Caravan driver =)
City: New York
State: OTHER
Post #1
I was interested in using redline oil products to change my transmission fluid. I couldn't figure out which one of their fluids would work with my 2000 Dodge Grand Caravan Sport SE (2wheel drive). So I wrote an e-mail to redline and they replied I should use: "In your Dodge Caravan automatic transaxle I would recommend the Red Line C+ATF." Does that sounds right? Wouldn't want to put the wrong fluids in my transmission. Thanks.
2000 Dodge Grand Caravan SE FWD
Mods: APC Exhaust, Altezza Euro Tail lights, 5% Tints Front, 5% Limo Tints Back, Eibach Pro-Kit Lowering Springs, Rear entertainment System, Bosch 4+ Plugs, Carbon Fiber Dash Kit, Blue Underbody Kit Lights, Custom K/N Cold Air Intake, Tornado Air Product, Focal Utopia 136 W, JL Audio XR-570, JL Audio VR-690, 2 JL Audio 12W6 V2 in Customer Sealed Enclosure, MTX Thunder 8100D Amp, MTX Thunder 6304 Amp, Alpine IVA-801, Alpine CHA-S634, Alpine DHA-S680, 5.6'' Headrest LCD Screens, APC Side Markers, Flowmaster 40 Series, Viper Alarm System 500 Series w/ Glass Breakage Sensor, StarTech DE Projection Headlights, Eagle Ultra-Grip Winter Tires, Silver Grill, Magnecor 8.5mm Spark Plug Wires, Hella Micro-De HID Fog Lights, 7000K Hella HID H7 Driving Lights.
Future Mods: Alpine Navigation System, 18' Tenzo Racing Rims & Performance Tires, Turn Signal Mirrors, Brembo Brake System, Hood Scoop, 56mm TB, Koni Shocks and struts.
McClane
 Posted: 11-08-2002, 11:30 AM
McClane's Avatar
City: Calgary, Alberta
State: OTHER
Post #2
I got this info from allpar.com (somewhat paraphrased) :
They recommend using nothing but Mopar ATF (+3/+4, depending on what the tranny dipstick says and what your manual says) fluid. It appears that Chrysler transmissions are very sensitive to the type of fluids used, and anything else may shorten the lifespan of the transmission.
1995 Dakota 4x4 Club Cab
5.2L, 3:55 rear end, 46RH tranny
Mods : M1, NGK zfr6f11s, 180 t-stat, Bilstein shocks, Roadmaster Active Suspension, Mopar Valve Covers, Mopar 3 inch cat back, relocated IAT, FMS/Bosch Design 2 #21 injectors, TransGo Shift kit (tfod-hd2), 8mm Taylor Spiro Pro wires
McClane
 Posted: 11-08-2002, 11:34 AM
McClane's Avatar
State: OTHER
Post #3
http://allpar.com/fix/trans.html
angldrkns9
 Posted: 11-09-2002, 11:54 PM
Caravan driver =)
City: New York
State: OTHER
Post #4
thanks, i'll check that out...
Rearend Diff Gear Lube 2Hottie 1G Durango General Talk 14 11-03-2003 10:55 AM
Transmission Full Fluid Change ?? PigIron 3G RAM - Drivetrain Talk 3 10-03-2003 11:54 PM
power steering fluid level.... uk94ram 2G RAM - General Talk 1 09-15-2003 09:15 AM
TOTAL fluid change - need help with amounts and torque #'s and procedure REALM 3G RAM - Drivetrain Talk 6 08-09-2003 08:40 PM
Mopar ATF +3 type 7176 tranny fluid Bryanh23 2G RAM - Drivetrain Talk 5 05-07-2003 09:51 AM
