91 dynasty backfiring through intake manifold/doesnt stay on - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 03-04-2005, 06:01 AM Thread Starter
IKEAGUIRRE14
91 3.3 dynasty starts right up then dies.new fuel pump. I did change out fuel press regulator.I tested coil,I tested relay both good, has fuel pressure .It starts right away then dies if I leave key on and crank it fires but wont run.If I turn key off and on again it starts right up then dies.I can keep it running(very rough)by pumping gas pedal. one thing was noticed is that it is backfiring from the air intake manifold what up with the backfiring
IKEAGUIRRE14 is offline
post #2 of 3 Old 03-05-2005, 06:16 PM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
You may have an ignition module or one (or more) coil packs going bad.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #3 of 3 Old 03-08-2005, 08:43 AM
1986turboz
91 3.3 dynasty
try a new fuel rail
1986turboz is offline
