Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Vintage Dodge Truck Forums > 1972-1987 Ram Trucks (D, W-series)
Ford_Fan_70
  Fuel pumps keep going - Posted: 03-02-2005, 08:53 PM
Post #1
First of all let me introduce my self, I am, as you can tell by my name, a ford guy. But my brother has a 1984 Dodge 2wd 1/2 ton with a 360 auto in it, and he needs help with something. He keeps going through fuel pumps, about 1 every 6 months. When he first brought it to the mechanic the tried everything, including cleaning out the fuel tank, but it still happens. We brought it to another mechanic and he said that the reluctor in the distributor was hitting the pickup. I don't see how this could ruin a fuel pump. Any ideas would be appreciated as we are stumped.
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
Dodgevanman
 Posted: 03-02-2005, 09:21 PM
Dodgevanman's Avatar
Do It In A Van
City: Baltimore Hon!
State: MD
Post #2
The distributor thing is bullcrap...that has nothing to do with a mechanical fuel pump. What brand fuel pump is he using? And does he keep using the same brand? I've had good luck with MASTER pumps through Advance Auto Parts.
If the fuel lines have rust on the inside, I can see where the rust is coming loose and damaging the pump. One thing is to install a filter before the pump. Also, mounted on the front of the camshaft timing gear is the eccentric that runs the pump. If this is extremely worn (read: grooved) it could be damage the fuel pump arm.
Hopefully this helps.
Nate the skate
5.2L Magnum
1972 B200 Royal Sportsman Maxiwagon
318/2bbl.
1985 B150
318/2bbl.
Click HERE to view the complete signature...
Ford_Fan_70
 Posted: 03-03-2005, 07:13 PM
Post #3
Ya, I figured that the two things are not together, I don't know the brand of fuel pump used but I guess we will try putting a fuel filter before the pump line, and take out it and see if there is damage on the arm.
Thanks for the help
Chump
 Posted: 03-05-2005, 06:00 PM
Chump's Avatar
State: CO
Post #4
Try getting an AC Delco pump or a Carter pump. Some of the aftermarket pumps may have a lifetime warranty but you spend a lifetime replacing them.
guidryrm
 Posted: 03-31-2005, 06:55 PM
Post #5
check the amount of vacume that is being drawn throught the line, and the diamater of the line.
