Door Chime Won't Shut Up! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 02-28-2005, 05:41 PM Thread Starter
TLubbers
Dakotaguy
I own a 01 Durango and it has been wonderful until about a week ago when it decided to start chiming at me. The door chime only goes off (other than when it's supposed to) when I'm moving (forward or reverse) and will quit only when I stop. It will go off occasionally or frequently. I hate to go to a dealership so I wanted to pose this question to see if anyone has encountered this problem and what they did to fix it.
TLubbers is offline
post #2 of 6 Old 03-01-2005, 08:54 AM
TxMoose
TLubbers,
Welcome! Haven't had that happen, but take a second and fill out your signature it helps us know what your drivin'!
TxMoose
'96 INDY RAM, 5.9L
K&N Filter Charger, Jacobs Plug Wires, KYB Mono Max Shocks
Husky Floor Liners, Cup-Smoothie, Sylvania SilverStars
KC Back-up Lights, Pioneer Head Unit
'09 Austin Tan Pearl w/Pebble Beige/Bark Brown interior SLT CrewCab 5.7L 2WD, Leer 700 tonneau cover
Sold:Patriot Blue '01 Durango, 2WD, 4.7L
K&N Filter Charger, Catch-All Carpet Floor Mats
TxMoose is offline
post #3 of 6 Old 03-02-2005, 12:56 PM Thread Starter
TLubbers
Dakotaguy
I took it to a dealership who told me it was the central timing module (up under the dash). Probably will be $375 to fix. Just to let everyone know if they have the same problem in the future.
2001 Dodge Durango SLT
TLubbers is offline
post #4 of 6 Old 03-02-2005, 01:22 PM
cbrenn71
Hummer Recovery Vehicle
cbrenn71's Avatar
Quoted: 1 Post(s)
are you under warranty?
if not, find a junk yard, and do it yourself.
UNIQUE COATINGS - Sponsor as of 4/9/06
GARAGE SALE!!! Great Prices on New, Used Retrofit Parts and Accessories
PROJECTOR RETROFITS STARTING AT $195!!!!!
WE WILL NOT BE UNDERSOLD ON HID & RETROFIT PARTS AND SERVICES!!!!! GUARANTEED.
cbrenn71 is offline
post #5 of 6 Old 03-02-2005, 01:44 PM
Wheeler Jones
Wheeler Jones's Avatar
Here's some info for you:
Strong electromagnetic fields or devices that transmit signals in the 315 Mhz range may cause the Central Timer Module (CTM) to intermittently lock up. CTM lock-up may cause a variety of customer complaints including:
Remote Keyless Entry Malfunction o Interior Lights Will Not Come On
Intermittent Wipers Will Not Function
Chime Malfunction
Power Door Lock Malfunction
Remote Radio Switch Malfunction (if equipped)
Heated Seat Malfunction (if equipped)
Engine Will Not Start (if equipped with Vehicle Theft Alarm)
No Communication With The DRBIII (No Response from CTM)
Essentially, all CTM controlled devices will not function if the CTM locks-up.
Customers that do experience this condition may:
have their vehicle equipped with after-market accessories that emit strong electromagnetic signals such as high output Citizen Band (CB) radios or Two-Way radios.
be equipped with transmitting devices that operate in the 315 Mhz range such as older analog garage door openers.
live or drive near devices that emit strong electromagnetic signals such as two-way radio communication towers utilized by the military, law enforcement, etc.
Diagnosis:
If the vehicle exhibits one or more of the conditions identified under Symptom/Condition, pull fuse 13 (power door lock fuse) for one (1) minute. Re-insert fuse 13. If the condition is no longer present, perform the Repair Procedure. If the condition still exists, further diagnosis is necessary, Refer to the appropriate Body Diagnostic Procedures Manuali or the service information available in MDS2 for additional information. If the customer indicates that they may have experienced one or more of the above conditions but were able to correct the condition by removing power to the CTM (pull fuse 13 - power door lock fuse or disconnecting the battery) and the condition cannot be duplicated, perform the Repair Procedure. Due to the nature of this issue, it may be difficult to re-create the customer's complaint
Parts Required:
AR (1) 56021861AK Module, Central Timer, Ram Van/Wagon
AR (1) 56045605AC Module, Central Timer, Dakota (Except Quad Cab)
AR (1) 56021223AN Module, Central Timer, Dakota Quad Cab And Durango
AR (1) 56045448AD Module, Central Timer, Ram Truck (Without Heated Seats)
AR (1) 56045999AD Module, Central Timer, Ram Truck Equipped With Heated Seats
Repair Procedure:
This Repair is compatible with DaimlerChrysler's Mobile service program and
does not require hoists or other full service facility special equipment.
1. Remove the CTM. Refer to the appropriate Service Manual, Group 8E, Central Timer Module, or the service information available in MDS2, for information regarding CTM removal procedures.
2. Install the new CTM (see Parts Required section). Refer to the appropriate Service Manual, Group 8E, Central Timer Module, or the service information available in MDS2, for information regarding CTM installation procedures.
Notes:
Policy: Reimbursable within the provisions of the warranty.
Time Allowance:
Labor Operation No: 08-19-22-91 Replace Central Timer Module
AB, AN, DN ................................................. 0.3 Hrs.
BR/BE .................................................. ......... 0.2 Hrs.
Failure Code: P8 - New Part
Black 2003 Durango R/T 5.9 4X4
Brush guard, Euro fronts, Alt backs, auto-vent shades, lighted hitch-cover, all windows tinted, hella 2500 lights front, black billet fuel door, Memphis 12" Sub, Infinity REF5761A amp, JBL C508GTI component speakers, euro 13" antenna, CAI w/ K&N filter, IAT mod, Rear Deflector
8000K HID headlights, Black Flame Guage Face, LED turn signals.
Other Rides: 2004 Kawasaki Vulcan 800 Classic, 2004 Nissan Maxima, 2005 Accent (commute-mobile)
Wheeler Jones is offline
post #6 of 6 Old 03-02-2005, 01:51 PM
Wheeler Jones
Note.. .this info is for:
2000 - 2001 (AB) Ram Van/Wagon
2000 (AN) Dakota
2000 - 2001 (BR/BE) Ram Truck
2000 (DN) Durango
I posted it so you get an idea of what's involved and why.
-WJ
