Codes P1684 and P0300 99 Intrepid - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 02-16-2005, 08:50 PM Thread Starter
SCRIGS
My check enging light came on and when I did the on off on off on thing... the check engine light didn't flash at all, but where the digital odometer is, it flashed code P1684 and then blinked off and flashed code P0300 then flashed ------ then said done.... Does anyone know what these two codes mean? I have been having some problems with the engine cutting out at low rpms up to about 2100 rpms, and also my gas mileage has decreased. Any help or ideas would be appreciated..!!! Thanks
SCRIGS is offline
post #2 of 5 Old 02-17-2005, 11:23 PM
pgr1940
1684 The battery has been disconnected within the last 50 starts.
300 Misfire detected in multiple cylinders.
301 Misfire detected in cylinder #1.
302 Misfire detected in cylinder #2.
303 Misfire detected in cylinder #3.
304 Misfire detected in cylinder #4.
305 Misfire detected in cylinder #5.
306 Misfire detected in cylinder #6.
pgr1940 is offline
post #3 of 5 Old 08-12-2005, 07:00 AM
johndmcintyre
p0300 p1684 whats the cause???
pgr 1940, I am having same problem had car to dealer unable to find trouble but they would like to try replacing fuel pump to see if it solves the problem LOL only costs 900 dollars, (can't see it happening anytime soon.
p.s. if anyone has any info on cause and resouloution please email me
Thank You
johndmcintyre is offline
post #4 of 5 Old 08-14-2005, 09:54 AM
pgr1940
Any of those missfire codes are ambiguous. I had a 301 code once. I thought it was electrical. It turned out to be a problem with a fuel injector. I had stopped at a no-name gas station for a few of gallons of gas and ended up with water in my gas tank.
Added dry gas to tank and has the injectors cleaned. Needless to say I only use Mobil/Exxon, Amoco/BP or Hess gas now.
pgr1940 is offline
post #5 of 5 Old 08-14-2005, 10:52 PM
pgr1940
I forgot to mention this in my prior reply:
I checked the plug it was fouled, checked the coil pack it was good.
pgr1940 is offline
