2003 Dodge Ram oil pan removal - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 25 Old 02-09-2005, 06:49 PM Thread Starter
trapp40
Hello,
I am trying to remove the oil pan on my 2003 Dodge Ram and have removed all the bolts and the torque converter cover and the oil pan will not come off. There is something inside holding it and I am lost as to what it is or how to get it loose. Help! I need my truck in the morning and need to get the pan off tonight. Thanks in advance for any help.
Tim
trapp40 is offline
post #2 of 25 Old 02-09-2005, 06:52 PM
hemi1569
All Around Great Guy
hemi1569's Avatar
The pan wont budge at all?
Names' Kevin
9/26/09 htc rally, best run 4880lbs, full street trim minus tailgate
14.31 @ 93.52
6.1 cam and pushrods
Ramhammer intake
Doug's headers(mids) with factory cats
catback
My 6500rpm superchip shift 0 to 60mph video
Knock retard limitations by the pcm on a stock tune, it can pull:
15.0 degrees at low RPM's
5.0 degrees at 6000 RPM
9.0 degrees at 4800 RPM's.
hemi1569 is offline
post #3 of 25 Old 02-09-2005, 06:56 PM Thread Starter
trapp40
It will drop down a quarter to half inch and will move from side to side but will not come out.
trapp40 is offline
post #4 of 25 Old 02-09-2005, 07:00 PM
Hemi5spd
Hemi5spd's Avatar
are you hitting the pickup screen/tube?
Hemi5spd is offline
post #5 of 25 Old 02-09-2005, 07:01 PM
hemi1569
hemi1569's Avatar
Haven't had the pan off of that model but previous experience would say you might have the pickup tube hanging up on the bottom of the sump.
Names' Kevin
14.31 @ 93.52
Ramhammer intake
catback
hemi1569 is offline
post #6 of 25 Old 02-09-2005, 07:02 PM
scapegoat047
Scapegoat047
scapegoat047's Avatar
What engine do you have (I'm trying to locate it on my Service Manual CD)
2004 Dodge RAM 2500 ST 4x4 HEMI
K&N Drop-In/NGK V-Power Plugs/
Behind The Grill Fogs/Mopar Ventshades/Lund X-Terminator/DeeZee BedCaps/Toolbox
95k+ miles and counting...
UNITED BROTHERHOOD OF CARPENTERS AND JOINERS
LOCAL 136 DAYTON, OH
scapegoat047 is offline
post #7 of 25 Old 02-09-2005, 07:06 PM
scapegoat047
Scapegoat047
If you have a 4.7, the manual is calling for special tool #8534 to raise the engine to clear the oil pan. DO NOT Pry on the Oil Pan, the gasket is part of the windage tray and isnt part of the oil pan.
post #8 of 25 Old 02-09-2005, 07:10 PM Thread Starter
trapp40
It is a 4.7. So I can't remove the pan myself?
trapp40 is offline
post #9 of 25 Old 02-09-2005, 07:15 PM Thread Starter
trapp40
Oh yea, I already pryed it. Did I mess up bad?
trapp40 is offline
post #10 of 25 Old 02-09-2005, 07:15 PM
scapegoat047
Scapegoat047
You just need a special tool. The dealer probably sells it. You have to unbolt the engine mounts and crossmember to lower the pan. I would put everything back together, and wait till the weekend, or day off. The manual says to put the bolts back in the same holes (tighten to 105 in.-lbs).
post #11 of 25 Old 02-09-2005, 07:22 PM
scapegoat047
Scapegoat047
oil pan removal
Here is an attached file from the CD Manual.
post #12 of 25 Old 02-09-2005, 07:24 PM Thread Starter
trapp40
Thanks for the help!
trapp40 is offline
post #13 of 25 Old 02-09-2005, 07:25 PM
BadAzzRam
BadAzzRam
The pan is that tough to remove
[FONT=Comic Sans MS]Bad Azz Out !!![/FONT]undefined
BadAzzRam is offline
post #14 of 25 Old 02-09-2005, 07:28 PM
scapegoat047
Scapegoat047
Haven't tried it myself, but it don't make sense to have to raise the engine a little to drop a simple pan. I guess that's how DC make$ more $$ at the $tealership!
post #15 of 25 Old 02-09-2005, 07:56 PM Thread Starter
trapp40
I will find out shortly and let you know.
Thanks again!
trapp40 is offline
post #16 of 25 Old 02-09-2005, 07:58 PM
Josh Brown
Josh Brown's Avatar
What are you doing on itthat requires pan removal
06 2500 QC SB 4x4 CTD Auto Mineral Gray Big Horn.
295/70/18 Nitto Trail Grapplers on Ultra Predators on stock suspension. A few performance mods.
Josh Brown is offline
post #17 of 25 Old 02-09-2005, 09:03 PM
wombie
wombie's Avatar
The SRT needs to have the engine unbolted and jacked up to remove the pan too....
Wombie
________________________________
Current Toys...
[B]04 SRT-10 Silver #406 of 3,057 -Built, blown, lowered and more
02 Custom Midnight Star
wombie is offline
post #18 of 25 Old 02-10-2005, 04:40 AM Thread Starter
trapp40
Thanks so much for the help. I got it done and you don't have to raise the engine. Seperating the pan from the windage tray was tough but once that was done, the pan came out easy.
Thanks again!
trapp40 is offline
post #19 of 25 Old 02-10-2005, 05:15 AM
milo55
SRT-10, Regular Cab
milo55's Avatar
Thanks again!
Tim, why are you doing this?
2004 Ram SRT-10
Built 4/13/04, a Tuesday, # 1658 of 3057
RB4 Nav. system with a NEO direct connect for IPOD
Retrax, roll up bed cover, custom made to allow for my spolier
Magnaflow S.S. catback
To Come: K&N C.A.I.
Custom made shifter
Custom lowering kit 1 front 2 rear
coin holders association member # 41 s.n.a.t.c.h. emt driver
PROUD MEMBER OF WCPW
milo55 is offline
post #20 of 25 Old 02-10-2005, 11:31 PM Thread Starter
trapp40
120k miles and some sludge in the oil pan that needed cleaning.
trapp40 is offline
