1987 dodge pickup won't start - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 01-26-2014, 03:50 PM Thread Starter
Guard503
Inherited a 1987 dodge pickup 318 auto. Aunts boyfriend broke key in ignition one night and decided the only way to fix was to change out steering column. Now the truck won't start and has been sitting for awhile. New spark plugs, wires, distributor cap, ignition coil, module. It still has original ignition switch and column, so I plugged old ignition switch harness back in...lights come on but nothing happens when trying to start it but there's a click. The new ignition switch won't do anything, not even click. Any suggestions are greatly appreciated!
Guard503 is offline
post #2 of 3 Old 01-27-2014, 01:47 AM
mongoman
mongoman's Avatar
The possibilities seem endless. Do you have a DVOM and a wiring diagram of the Start circuit? Do you know basic DC electricity? Trouble shooting here is what's needed. Some voltage ck's will help to determine and narrow down a course of action.
1973 W-100 O/H 360' engine, w/a Edelbrock :1406 carb,2176 intake manifold, 2177 performer cam/ lift kit, Lokar cables, Dana 44 front axle ,A-727 auto-trans.Np-205 trans-case, Chrysler 8 3/4"SF rear axle ,All drum Brakes. Classic Auto Air-conditioner package.
mongoman is offline
post #3 of 3 Old 01-27-2014, 03:35 PM
MossyOak
MossyOak's Avatar
I know it sounds silly but the collum has 2 plugs. Make sure there both plugged in.
Also check inline fuses under hood.
87 RamCharger 2x4
318 bored .30 over, flat top pistons 9.4-1 comp, webcam towing roller cam, mid length headers, modified flowmaster 50 series, 3.55 gears, A904 trans with mild shift kit and lockup converter, factory esa, and pieced together lift kit,
Modified 17"x9" HELO wheels running 32"x10" in front and 33"x12.50" in rear
MossyOak is offline
    Dodge won't start, then did? Splinterhands 3G Dodge RAM - General Talk 4 02-10-2012 04:40 AM
    New Dodge Won't Start Again scott04 Dodge Caravan General Talk 4 01-05-2012 04:24 PM
    wiring problem with 1987 dogde 150 pickup. farmer.larry 1973-1993 Dodge RamCharger 1 06-23-2009 12:46 PM
    97 dodge won't start peaches7 Dodge Caravan General Talk 0 08-13-2007 06:59 PM
    1990 360 Ram pickup won't start jlwilliams Dodge Ram Truck 1st Gen (88 - 93) Forum 9 11-15-2005 08:36 PM
