1990 Dodge D150 vacuum problems - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 01-16-2014, 12:51 PM Thread Starter
paulbutler
Smile 1990 Dodge D150 vacuum problems
I have just got my hands on a 1990 dodge d150 with a 318. One of the vacuum hoses off the power brake booster is not connected. the vacuum off the air pump (small vacuum line) is not hooked up. Would like to get some help if possible. Thanks
paulbutler is offline
post #2 of 3 Old 01-16-2014, 12:55 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
The other hose coming off might be for the cruise control. At least that's how it's set up on the older trucks
Sent from AutoGuide.com Free App
1987 Dodge W-150 "The Beast"
some sort of lift
33" AT's
LA 360 bored .030 over, EQ Magnum heads, Hooker Headers, true dual exhaust, Holley 4160 w/Truck Avenger parts, Edelbrock Performer dual plane intake, StreetFire ignition box & MSD coil
208 t-case/727A trans w/3.23 gears
maachine is offline
post #3 of 3 Old 01-29-2014, 11:46 PM
MossyOak
MossyOak's Avatar
Yeah that other line off the booster is for cruise. If you don't have cruise cap it. That little hose goes in a t on the passenger side firewall. Should be near the valve cover.
87 RamCharger 2x4
318 bored .30 over, flat top pistons 9.4-1 comp, webcam towing roller cam, mid length headers, modified flowmaster 50 series, 3.55 gears, A904 trans with mild shift kit and lockup converter, factory esa, and pieced together lift kit,
Modified 17"x9" HELO wheels running 32"x10" in front and 33"x12.50" in rear
MossyOak is offline
    87 dodge d150 vacuum scampdude 1972-1987 Dodge Ram Trucks (D, W-series) 3 06-19-2013 01:48 PM
    1990 Dodge D150 Runs out of gear Schatvet Dodge Ram Truck 1st Gen (88 - 93) Forum 4 03-30-2012 02:30 AM
    1990 dodge w150 camber allignment problems elmoand Dodge Ram Truck 1st Gen (88 - 93) Forum 0 06-08-2011 05:24 PM
    1990 Dodge D150 Engine Swap mbonifield04 Dodge Ram Truck 1st Gen (88 - 93) Forum 0 07-19-2005 02:16 AM
    1990 Dodge Spirit Stalling--vacuum lines IES99 Vintage Dodge Car Forum 1 04-10-2005 12:21 PM
