How to reset computer 99 Dodge Ram - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 16 Old 01-30-2005, 04:32 PM Thread Starter
99 Dodge Elec B
Can anyone tell me how to do this? Thanks
99 Dodge Elec B is offline
post #2 of 16 Old 01-30-2005, 04:44 PM
RAM MAN
Originating Member
RAM MAN's Avatar
Welcome to the forum
to answer you question:
Disconnect NEG Battery Terminal
Turn the ignition key to the START position and hold for 15-20 seconds
Release key (OFF) and reconnect the battery
that will do it
Good luck on your project.
RAM MAN is offline
post #3 of 16 Old 01-30-2005, 04:50 PM Thread Starter
99 Dodge Elec B
Check Engine Codes
How do you obtain the codes with the ignition thingy? Thanks for the other quick reply...
post #4 of 16 Old 01-30-2005, 04:54 PM
RAM MAN
Originating Member
RAM MAN's Avatar
1. Ignition switch off
2. Press and hold the trip reset knob
3. Turn the ignition switch to on but do not start.
4. Hold the reset knob for approx 10 seconds or until the word CHEC appears in the display then release.
RAM MAN is offline
post #5 of 16 Old 01-30-2005, 05:50 PM Thread Starter
99 Dodge Elec B
Thanks
I have a 99 Dodge Ram 318 engine that will not start. I have tried reseting the computer as mentioned above, no check engine codes show up with test shown above and I have tried jumping the battery.
When the truck ignition key is turned you can hear the fuel pump engage and then I try to start it and it will not start. It sounds like it wants to, but just won't start. Anyone have any ideas?
post #6 of 16 Old 01-30-2005, 08:18 PM
RAM MAN
Originating Member
RAM MAN's Avatar
hmm
are you sure the starter is OK ?
and when you turn the key, what is the reading on the battery ? (Is it constantly over 14 ?)
RAM MAN is offline
post #7 of 16 Old 01-30-2005, 08:39 PM Thread Starter
99 Dodge Elec B
Battery
Nope, the battery is under 14. But when I was trying to jump it from my Jeep Cherokee it did go up to 14. If it was the starter wouldn't it make some type of clicking noise? Everything sounds right except it won't start.
post #8 of 16 Old 01-30-2005, 09:18 PM
RAM MAN
Originating Member
RAM MAN's Avatar
ok
now it makes me think its your battery
I park my RAM in the winter here in Michigan
with a next to dead battery one winter, when I went out to turn the key, it did just what you said
the reading stayed under 14 on the battery
no starter noise
you could hear the pump engaged
just for the heck of it, take your battery to a place with a tester, and ask them to check it
maybe it just needs a few hours on a trickle charger
maybe the battery is going
either way, it should be well under $10 if it even needs a trickle charger and it will definately rule the battery out one way or another ....
keep us posted
RAM MAN is offline
post #9 of 16 Old 01-31-2005, 10:55 PM
Silver_DodgeRam
Mmmmmmmmm, beer.
Silver_DodgeRam's Avatar
Quoted: 2 Post(s)
What would be the advantage of reseting the computer? Is it necessary to do every once in a whole?
Silver_DodgeRam is offline
post #10 of 16 Old 01-31-2005, 11:05 PM Thread Starter
99 Dodge Elec B
? Stunned
I went out this morning and was going to switch batteries, but got called in to work. Left the positive and negative battery connection off and when I got home for lunch, 8hrs later put the connections back on and the truck fired right up. Man, what the heck is goin on. i had my fiance drive it to Advance and they checked the battery and alternator and both were in excellent shape. I am stunned and don't know what to do next.
post #11 of 16 Old 01-31-2005, 11:09 PM
JamesJ2525
Hotty Toddy Gosh Almighty
JamesJ2525's Avatar
Maybe there was some corossion that came off? Perhaps your ground is not that good? Check it out for any dirt or corrossion. Although, corrosion is generally on the positive terminal.
2003 Ram 1500 SLT Regular Cab, 360 V8, 3.92 Limited Slip, 4X4 Offroad Package, 1.5" Torsion Bar Crank, Rancho RS 5000 Shocks, LT 275/70R17 Cooper Discoverer S/Ts, K&N Airfilter, Mopar (Borla) Performance Exhaust, Mopar Running Boards, Mopar Slush Mats, Sirius Satellite Radio, Coin Holder
JamesJ2525 is offline
post #12 of 16 Old 02-01-2005, 05:40 AM
RAM MAN
Originating Member
RAM MAN's Avatar
anytime you do any modifications to your truck (i.e. add performance parts) and you want your engines computer to learn and adjust to those parts, you can reset it by doing this
Those computers are built so they learn the way you drive, so even if you didn't - it would eventually learn (I think someone once told me, every 300+ miles or so)
but if you want the changes to go into effect immediately, you reset it
kinda get the full bang for the buck that way
RAM MAN is offline
post #13 of 16 Old 02-01-2005, 05:41 AM
RAM MAN
Originating Member
RAM MAN's Avatar
ok that is weird
just for the heck of it - I'd have the battery tested anyway
doesnt cost anything
RAM MAN is offline
post #14 of 16 Old 02-01-2005, 10:02 AM
cmh2007
Beware the Underbite!!!
cmh2007's Avatar
my 99 did something weird yesterday morning. it turned over for 5-7 seconds, cought then idled really low and died. it did this for four cranks and finally i held on the gas for a little and it kept runing and after about 30 seconds to a minute it stayed running. does anybody know what is going on. i also think it has the origional spark plugs and it has been raining for the past 4 days. ill check the plugs when it drys up.
2009 Ram 2500 CTD 4x4 SLT Lone Star, Patriot Blue. H&S XRT Pro 120hp tune with OD tuning. Full delete on the exhaust, waiting on the EGR.
Big Country Nerf Bars, Frontier Grill Guard
Blue Truck Club Member 251
*DodgeTalk.com 318 Enthusiast Member Number 3* (For the old truck)
4x4 Club #18
"I'm as sober as a field mice...mouces...mouce" - Anonymous
cmh2007 is offline
post #15 of 16 Old 02-01-2005, 10:46 AM
JamesJ2525
JamesJ2525's Avatar
Sounds like some moisure got into the distributor cap.
post #16 of 16 Old 02-01-2005, 11:49 AM
cmh2007
cmh2007's Avatar
thanks that confirmedmy suspictions
i think ill go and do a full tune up soon as it dries up here on galvatraz
4x4 Club #18
cmh2007 is offline
