Amp gauge bypass - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 57 Old 12-03-2013, 02:12 PM Thread Starter
76d100318
Joey Johnson
76d100318's Avatar
Amp gauge bypass
On my 76', i replaced the alternator with a rebuilt 65 amp, voltage regulator is new, and battery is new. when the truck is running and electric fan is on when i check voltage at the battery its at 12.6 or so. when the fans off its at 13.2 or so. fan only pulls 13 amps. But im thinking about doing the ammeter bypass. Buying the kit from madelectric. Can one of you break it down to baby steps for me? lol sounds dumb but ive read their site multiple times and got lost at some points. thanks everyone.
1976 Dodge D100 regular cab short bed, 318 2 barrel New carter BBD, np435 four speed 91/4 3.21 gears. Headers, dual 2.5 exhaust, into 2 Flowmasters super 44's. Custom
1972 Dodge Dart swinger special. 366 small block chrysler (360), 727 torqueflight, 8 3/4 4.10's spool. 450 horse. Street/strip car
76d100318 is offline
post #2 of 57 Old 12-03-2013, 06:39 PM
76 Powerwagon
76 Powerwagon's Avatar
Quoted: 4 Post(s)
I know how you feel, I want to do the same thing to my 76 W100. I got lucky, my amp gauge crashed about a month ago. Started smoking and took out some of my other gauges and my radio. I got a replacement gauge, but now I need to do the bypass.
76 Powerwagon is offline
post #3 of 57 Old 12-03-2013, 08:43 PM Thread Starter
76d100318
Joey Johnson
76d100318's Avatar
Oh dang man. It's just the wiring isn't up the task of having all the power going through it. I get how to do the wiring but when mad electrical says to put a large size wire from the alt to the starter relay what happens to the voltage regulator? Do you unhook the old wiring and take it out so the new wire is the only one sending power to the battery or what?
post #4 of 57 Old 12-03-2013, 09:23 PM
crazzywolfie
Quoted: 1 Post(s)
just add a wire from the output on the alternator to the battery with a fusible link inline and you should be good. leave the old wiring there. the way the old wiring is is good because power does not have to travel as far to get to everything but all the power goes through the amp gauge on its way to charge the battery which is bad.
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
93 ramcharger 318 FI 2wd
crazzywolfie is offline
post #5 of 57 Old 12-03-2013, 10:59 PM Thread Starter
76d100318
Joey Johnson
76d100318's Avatar
Ah now I see. What's better to do for the terminals on the ammeter, to solder them together and crimp them or bolt them together or put one wire on the other terminal?
post #6 of 57 Old 12-03-2013, 11:31 PM
crazzywolfie
Quoted: 1 Post(s)
i would not worry about bypaasing the amp gauge inside the truck. running a wire from the alternator output to the battery should do the same and is a lot easier to do.
post #7 of 57 Old 12-04-2013, 12:34 AM Thread Starter
76d100318
Joey Johnson
76d100318's Avatar
Dumb question but how do I wire in fusible link? Probably going to use 8 gauge wire with 12 gauge fusible link.
post #8 of 57 Old 12-04-2013, 01:58 AM
farmboy345
farmboy345's Avatar
Quoted: 6 Post(s)
IT just goes in series with your wire your running. should be ok to solder and shrink wrap
farmboy345 is offline
post #9 of 57 Old 12-04-2013, 08:38 PM
dodge dude94
That Weird Guy
dodge dude94's Avatar
Quoted: 2 Post(s)
I did what crazzy posted.
Disabled my amp gauge but everything works.
To 76d100, got any pictures you're willing to post of your truck? Looks nice.
1998 Ram 1500 4x4, QCSB, 360, ebay plenum, catch can, new cat, Thrush Turbo, full factory build sheet, other random stuff -- 1976 Dodge D200, CCLB, 400, 850 cfm (440ci) 4BBL carb, 727, D60, 4.10, open diff, 2.25in true duals, Dynomax Super Turbos, mostly black and an aggressive driver
dodge dude94 is offline
post #10 of 57 Old 12-04-2013, 11:16 PM Thread Starter
76d100318
Joey Johnson
76d100318's Avatar
Ah interesting. I'll think about keeping the gauge. Hey thanks man. Yeah sure I'll try my best.
post #11 of 57 Old 12-04-2013, 11:18 PM Thread Starter
76d100318
Joey Johnson
76d100318's Avatar
Pretty much on the restored road
post #12 of 57 Old 12-04-2013, 11:24 PM
crazzywolfie
Quoted: 1 Post(s)
well if you would like to keep the gauge then you want to upgrade the wire that run between the alternator output and the amp gauge and then upgrade the other wire that runs between the amp gauge and the battery. the bulkhead connector is one of the weak spots on older vehicles.
http://www.allpar.com/history/mopar/electrical.html
post #13 of 57 Old 12-04-2013, 11:30 PM Thread Starter
76d100318
Joey Johnson
76d100318's Avatar
So there's the wire on the amp gauge where does that go to? The wire from the alternator, where does that go to? And do they plug into the bulkhead or what?
post #14 of 57 Old 12-05-2013, 03:15 AM
dodge dude94
That Weird Guy
Quoted: 2 Post(s)
The alternator wiring snakes from the alt., through the voltage regulator then through either the battery or the amp gauge, I dunno which. Crazzy should be able to elaborate on that. All I know is that stock, it has WAY too much current driving through it. lol
And AWESOME looking truck 76! Mine won't look near as good as yours! Keep up the good work.
post #15 of 57 Old 12-05-2013, 09:03 AM
lucas.lundgren
Gumby1
lucas.lundgren's Avatar
Quoted: 4 Post(s)
Here is the engine schematic. Hopefully you can read how it all goes.
lucas.lundgren is offline
post #16 of 57 Old 12-05-2013, 09:23 AM
crazzywolfie
Quoted: 1 Post(s)
well if you read the article i linked to you would see that the wires that run though the bulk head connector have a tendency to corrode and overheat over time which is what causes issues. the amp gauges them self do not usually fail.
post #17 of 57 Old 12-05-2013, 11:47 AM Thread Starter
76d100318
Joey Johnson
76d100318's Avatar
Yeah I've read that link like 4 times. I'll take a look at the wiring diagram. Thanks everyone. Should I just run a wire through the bulkhead instead of putting connectors on it right?
post #18 of 57 Old 12-05-2013, 01:19 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
Yes. You can drill a hole and install rubber grommets. You can find those at the parts store
Sent from AutoGuide.com Free App
1987 Dodge W-150 "The Beast"
some sort of lift
33" AT's
LA 360 bored .030 over, EQ Magnum heads, Hooker Headers, true dual exhaust, Holley 4160 w/Truck Avenger parts, Edelbrock Performer dual plane intake, StreetFire ignition box & MSD coil
208 t-case/727A trans w/3.23 gears
maachine is offline
post #19 of 57 Old 12-05-2013, 03:04 PM
crazzywolfie
Quoted: 1 Post(s)
i have no issue just bypassing the amp gauge but i guess if i would going to keep the amp gauge i would bypass the bulkhead connector and just run wires through a grommet just like the heavy duty vehicle would have had from the factory.
post #20 of 57 Old 12-06-2013, 01:15 AM Thread Starter
76d100318
Joey Johnson
76d100318's Avatar
Might just drill through the firewall instead of the bulkhead and add a grommet. Thanks Guys
    Triple gauge center dash bezel mount & Oil Pressure Gauge 05DaytonaHemi For Sale - Truck Parts 4 04-27-2012 10:54 PM
    WTB: Triple Gauge Pod & Air/Fuel Gauge Mythic Wanted - Dodge Truck Parts 1 09-29-2009 12:19 PM
    block heater(temp gauge) & sparatic amp gauge wyocummins 3G Dodge RAM Diesel Talk 2 01-24-2007 12:15 PM
    Amp Bypass sweetgino 1G Dodge Durango - Interior/Exterior 0 05-13-2006 09:16 PM
    How to Bypass Amp kevno6 3G Dodge RAM - Interior/Exterior Talk 1 08-02-2004 11:29 PM
