Need Help Asap Pleas 82 5.9l Ignition Coil Wiring - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 12-03-2013, 12:40 AM Thread Starter
V8 addiction
Green Horn rebuilder
I need to know the wiring for my 5.9L LA engine ignition coil. i have a green and a red wire coming from a plug in the firewall, a black wire coming from distributor and a black wire with a resistor (I think) on the end going to ground.
V8 addiction is offline
post #2 of 5 Old 12-03-2013, 09:09 AM
lucas.lundgren
Gumby1
lucas.lundgren's Avatar
Quoted: 4 Post(s)
Maybe this will help. The top one is for a vehicle with the spark control computer and the bottom is for one without. As for the thingy with the black wire on it. That is the condensor or suppresor depending on what each person calls it. I don't see it in the schematics, but I do believe that it should go on the negative side of the coil. It is there to reduce radio noise interferance.
lucas.lundgren is offline
post #3 of 5 Old 12-05-2013, 09:05 AM
lucas.lundgren
Gumby1
Quoted: 4 Post(s)
Did you get it back together?
post #4 of 5 Old 12-08-2013, 01:51 PM
farmboy345
farmboy345's Avatar
Quoted: 6 Post(s)
might help
farmboy345 is offline
post #5 of 5 Old 12-10-2013, 11:27 AM Thread Starter
V8 addiction
Thanks guys! I think the bottom one you posted should be helpfull! the coil has a red wire, a green wire, and two black ones going to it!
    Ignition coil greenweenie For Sale - Truck Parts 4 07-31-2011 04:06 PM
    new ignition coil spun360 2G Dodge RAM - General Talk 7 12-25-2010 01:50 PM
    4.7L - Ignition Coil The DEUCE 3G Dodge Ram Performance Talk 5 08-15-2009 12:10 PM
    Ignition coil King Z-ster 2G Dodge RAM - General Talk 12 11-27-2007 09:06 PM
    ignition coil phahengpro 1G Dodge Durango Performance Talk 3 11-02-2005 07:41 AM
