Trunk light not working - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 01-25-2005, 12:09 PM Thread Starter
Trep Driver
I have a 99 intrepid and recently the trunk light stopped working. I've changed the light bulb and checked all the fuses but it still doesn't work. My last option is the trunk switch that turns on the light but I'm unable to locate it. Does anyone knows where the switch is located. Thanks.
Trep Driver is offline
post #2 of 4 Old 01-25-2005, 12:29 PM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
It's probably a mercury switch located in the lamp unit itself. May have to replace the whole unit.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #3 of 4 Old 01-26-2005, 03:42 PM
Crash459
Therapist Giggity-Giggity
Crash459's Avatar
DECK LID RELEASE
SOLENOID
DIAGNOSIS AND TESTING - DECK LID
RELEASE
For vehicles equipped with electric deck lid release.
(1) Confirm motor lead wire is connected and 10
volts or more are available at solenoid.
(2) Provide proper ground through latch mounting
screws.
(3) Remove latch and examine plunger. Plunger
should spring back when pressed.
(4) Insure that solenoid plunger travel is adequate
approximately 16 mm (5/8 inch).
DT's Resident Psychologist
Hello in there Cliff,........tell me,............What color is the sky in your world?
2005 Dakota Quad Cab V8 SLT
2 inch leveling kit installed
32" (265/75/16) BF Goodrich All Terrain KO's
3 inch body lift installed
Magnaflow dual exhaust (coming soon)
Fastman throttlebody (coming soon)
Airraid cold air intake (coming soon)
"I want rustlers, cut-throats, murderers, bounty hunters, desperados, mugs, pugs, thugs, nitwits, halfwits, dimwits, vipers, snipers, conmen, Indian agents, Mexican bandits, muggers, buggerers, bushwackers, hornswagglers, horse thieves, bull dykes, train robbers, bank robbers, ass kickers, sh*tkickers... and Methodists!"
Crash459 is offline
post #4 of 4 Old 02-02-2005, 10:47 AM
peter_w67401
peter_w67401's Avatar
I had the same issue. It was the wiring harness that goes from the trunk release mechanizim to the harness at the rear left fender well. I guess there was a broken wire in it. I got a new harness off of E-bay for $20.00 and it repaired the issue. The same harness from MOPAR was about $100.00. Good luck..........................Pete
peter_w67401 is offline
