Air bleed in Cooling system - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 11-05-2013, 10:52 AM Thread Starter
jarheadX2
Guys help needed here. 2002 Ram 1500 4.7. Replaced lower radiator hose and Thermostat gasket because it was leaking right at the housing. Fixed it, no leaks. Now truck is overheating.
Let it cool, pulled the cap and let it run for a good 15 minutes. No fluid came to the top or spilled out and the temp gauge was climbing way above normal again before I shut it off. Going to try and get the front end up on an uphill slant and find the bleeder valve. Wasn't exactly sure where it was? I did turn the heat on full just before I shut the truck off and it was blowing good heat. But, wondering if that was from the motor being so hot or the thermostat actually opened and normal heat was flowing through.
Thanks guys. New here but plan on sticking around for awhile.
jarheadX2 is offline
post #2 of 18 Old 11-05-2013, 12:53 PM
MonsoonMike
Site Administrator
MonsoonMike's Avatar
Quoted: 231 Post(s)
What you should do is drill a tiny hole in your Thermostat.
What is happening is when you fill it up - the air from the rest of the system/block fill us behind the thermostat and creating a HUGE pocket of air. You think it's full cause the fluid is at the cap.
The tiny hole in the T-Stat will allow the air to purge up!
Old School hot rod tip there!
::2014 Ram 2500 CTD Crew Cab Granite Crystal Metallic::
My Vehicle Build =
MonsoonMike is offline
post #3 of 18 Old 11-05-2013, 12:56 PM
MonsoonMike
Site Administrator
Quoted: 231 Post(s)
My Vehicle Build =
post #4 of 18 Old 11-05-2013, 01:06 PM Thread Starter
jarheadX2
Isn't that what the little brass fitting deal is for on the thermostat?
post #5 of 18 Old 11-05-2013, 02:55 PM
MonsoonMike
Site Administrator
Quoted: 231 Post(s)
Ah, so you did get one with the tear drop brass plug..
My Vehicle Build =
post #6 of 18 Old 11-05-2013, 04:18 PM
devans
devans's Avatar
Quoted: 1 Post(s)
The bleeder valve as you called it is on the drivers side and looks like a set screw. You will need an allen wrench to remove it. Oh and the vent that's built into the thermostat should be in the 12 o'clock position.
Don Evans
Black '02 QC 4x4
4.7 auto
04 Jeep Grand Cherokee TCM mod
Vent visors over the windows
Stainless Nerf Bars salvaged from scrap yard and modified to fit.
Lockable billet fuel door.
K&N air filter
Painted grille (had a chrome one)
Color matched headlights (black)
Factory fog lights
Headache rack with LED lighting
Looking to do,
Tonneau cover
Cab lights (waiting on warm weather)
Tow mirrors
And the list goes on.
Other than that mostly stock.
devans is offline
post #7 of 18 Old 11-05-2013, 04:25 PM
btg0002
War Eagle!
btg0002's Avatar
Quoted: 14 Post(s)
I had a similar issue with my truck when I swapped the tstat out. I ended up having to fill the system with coolant at the bleeder valve as the air was not allowing the coolant in the radiator to get into the engine block. you might want to open up the bleeder valve (it will be, as said above, an allen wrench screw on the inlet for the radiator hose coming out of the drivers' side of the engine and top of the radiator and see if you have fluid in there. when I pulled my bleeder screw there was none in there and like I said I had to fill it up from this opening
TRUCK: 2007 RC/SB 1500 ST with the 3.7 v6
PERFORMANCE: l jba shortie headers l hypertech max power programmer l Jet 180 tstat l e3 spark plugs l K&N CAI l magnaflow cat back dual exhaust l fastman ported TB l RP engine oil and rear diff fluid l bluetooth ODBII adapter for Torque app l
SUSPENSION: l 3 inch lift spindles l 2 inch coil spacer l bilstein 4600 shocks front l monroe load leveling shocks rear l TGC 1.5" rear lift blocks l 5" total lift front, 2.5" total lift rear l
APPEARANCE: l rhino lined bed l tonnomax tri fold bed cover l bed lined fender flares, rockers, bumpers l big mouth rivet grille l led tail lights l lamin-x tails and 3rd l led everything l HID heads and fogs l HID reverse lights l led reverse flood lights l debadged l hood spears l tinted windows l audio system l black headlights l black billet 15" stubby antenna l daytona tail light covers l
WHEELS/TIRES:l 285/70/17 Nitto Terra Grappler l OEM 17s plastidipped black l
btg0002 is offline
post #8 of 18 Old 11-05-2013, 05:07 PM Thread Starter
jarheadX2
Okay. I'll give it a try. Very frustrating. Upper hose is hot, lower hose is cold when idiling. Blows hot air. But with overflow/radiator cap off, there is not a gurgling or rise and fall of the fluid. It's moving through the overflow. Stays at the same level constantly, but continues to overheat.
post #9 of 18 Old 11-05-2013, 05:30 PM
MonsoonMike
Site Administrator
Quoted: 231 Post(s)
That sounds like an air pocket for sure!
My Vehicle Build =
post #10 of 18 Old 11-05-2013, 07:38 PM Thread Starter
jarheadX2
Okay guys, unscrewed the bleeder valve and fluid came pouring out like a fountain. Had overflow/radiator cap off also. Drained 1/2 the overflow out before putting the bleeder valve back on. Any suggestions?
Very frustrated. Went from just fixing a small leak with t'stat gasket repair to overheating issues that weren't there before.
post #11 of 18 Old 11-05-2013, 08:51 PM
Ram_Wagon
Ram_Wagon's Avatar
Go to parts store (NAPA, AutoZone, Advanced Auto, wherever!) And get yourself one of these....
http://shop.advanceautoparts.com/web...ntent=22970131
Worht it's weight in GOLD!!! Especially for Mopar products. And well, I've used it on every vehicle I added coolant to!
Get one! Not that expensive, Reall!!
2007 DODGE CHARGER R/T A.W.D.
Ram_Wagon is offline
post #12 of 18 Old 11-05-2013, 09:12 PM Thread Starter
jarheadX2
That's great for capturing the fluid but how does
that solve my air bleed problem? Or did the trapped air just
push fluid out of bleeder. I capped it thinking the whole
system was going to drain out
post #13 of 18 Old 11-05-2013, 10:08 PM
Ram_Wagon
Ram_Wagon's Avatar
You attach this funnel to the radiator, where the cap goes. Fill the funnel about halfway then start the engine. You may have to put the "stick" inside the funnel in order to build a little pressure (BE CAREFUL with this step!!!) and therefore create some heat. If the engine is already warm, the thermostat (assuming it works) will open slowly at that point. Just let her idle for some time. Not sure how long to tell you, but you'll see air escape out the funnel.
The funnel, being HIGHER than anything else in the radiator/engine/cooling system will creat some Head Pressure to basically allow gravity to do it's thing. Any air will be forced by that head pressure thru the system. The trapped air will escape to the highest point, in this case, the funnel.
Once all air has been bled, insert the "stick" back in to plug the funnel (With the engine OFF!) and unscrew the funnel from the Rad. Pour the rest of coolant into overflow, by removing stick in funnel over the overflow tank, and top off tank to HOT mark.
I really shouod do a "How To" with pics, but this isn't that hard. Again, the funnel is the highest point, much higher than Rad, Engine and Heater Core with this set-up.
post #14 of 18 Old 11-05-2013, 10:15 PM
Ram_Wagon
Ram_Wagon's Avatar
Try this video. Not mine, but EXACTLY what you need to do!!
post #15 of 18 Old 11-05-2013, 10:34 PM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 250 Post(s)
Get the nose of the up while it's at idle. If you don't, you run the risk of trapping air in the heater core or the top of the cylinder heads.
Are you sure the t-stat is in right?
dmcelhannon is offline
post #16 of 18 Old 11-06-2013, 07:36 AM Thread Starter
jarheadX2
Thanks for the help guys. I think I'm going to start over and drain it and make sure I did get that brass plug on the t'stat at the 12 o'çlock position and reburb the system again. Not sure what esle it could be at this point besides possibly bad t'stat positioning or bad t'stat in general.
post #17 of 18 Old 11-06-2013, 08:01 AM
d_layne
d_layne's Avatar
Quoted: 5 Post(s)
If you use the funnel you can squeeze the upper radiator hose to try to get some air pockets out.
2013 Dodge Challenger R/T 5.7
2007 RAM 1500 4x4 4.7... Gone but not forgotten!!!
d_layne is offline
post #18 of 18 Old 11-06-2013, 10:17 AM
MonsoonMike
Site Administrator
Quoted: 231 Post(s)
The Spill Free Funnel is a great tool. I've always wanted one. Adding it to my Christmas list now!
My Vehicle Build =
    Cooling system issues, How to purge air? Hughes 3G Dodge RAM - General Talk 13 05-30-2011 10:04 AM
    Air in cooling system keith1 2G Dodge RAM - General Talk 3 04-15-2010 02:49 PM
    Cooling system bleed valve anthony361 Dodge Intrepid 1st Gen (93 - 97) 2 02-04-2010 06:02 AM
    Bleed air from fuel system 93 W250 DodgeTalk New Member Welcome 3 03-01-2008 07:26 AM
    How do I purge the air in the cooling system? dcmluce 2G Dodge RAM - General Talk 1 09-25-2006 11:31 PM
