Heating Problems, Blows hot sometimes - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 11-04-2013, 10:25 PM Thread Starter
Rambronco
I have a 06 Power Wagon and having some heating issues. It wasn't really getting very hot inside. It has pas/driver heat controls but they seem to work as they should. Figured it was thermostat, changed that, still same issues. When I go to work in the morning, about a 45 min. drive, never gets very warm at all. When truck sits for awhile, then drive it, it gets hot as it's supposed to. A/C doesn't blow as cold as it should either. Temperature guage is where it is supposed to be and rad hoses get hot. Rad cap seems kinda cold. I put the oem thermostat in. Could it be a air lock? Heater core maybe plugged a bit? Truck has alot of miles, 215k but has no other issues and runs great.
2003 Ram 2500, Hemi, 35's
Power Wagon Conversion Project
Rambronco is offline
post #2 of 7 Old 11-04-2013, 11:10 PM
orvtenn
+ Hemi Addict +
orvtenn's Avatar
Quoted: 9 Post(s)
If all the hoses get hot and the temp comes up where it should be then it is most likely the heater core.
2004 1500 SLT RC/SB 4x4 Hemi 5.7
2001 Jeep Cherokee Sport 4.0HO
orvtenn is offline
post #3 of 7 Old 11-04-2013, 11:13 PM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 235 Post(s)
Sounds like the level is low.
dmcelhannon is offline
post #4 of 7 Old 11-05-2013, 09:05 PM Thread Starter
Rambronco
Fluid level is good. I noticed last night that passenger side was blowing hot, drivers side wasn't always hot. Problem seems to be on drivers side, it has dual heat controls for driver passenger. Can this be a vacuum problem? Passenger side seems to work fine
post #5 of 7 Old 11-05-2013, 09:11 PM
nh5
nh5's Avatar
Quoted: 1 Post(s)
Vacuum does not play a role in the system, I've had this problem for a while, took apart my heater box confirmed all my doors were functioning normally and still have had a bit of a issue. However it has improved drastically since I had my timing cover gasket replaced as I was loosing a small amount of coolant through it.
02 Ram 1500 QC 4X4 Sport 5.9L Magnum, EQ Iron RAM Heads, 52mm Fastman TB, ebay Shorty Headers, Magnaflow 12576, SRT Hood, 180deg Stat, Superchips 3815, Taylor Thundervolt Wires, E-Cutout, SUPERSHAFTS Rearend, Detroit Tru Trac & 3.92's, rvinyl'd tail lights, led's all over, leds in tow mirrors, switchbacks, 6k HID's Hi/low + fogs, RE XXX components (front doors), Skar 5.25 components rear doors, Sundown audio SAX 125.4, Kenwood X995, DC Audio M3 8, DC 1.2k, RAAMMat throughout the cab and doors, blue led dash, new carpet, moog joints, Bilstein HD's.
Next, 17rr's 2200 stall TC
nh5 is offline
post #6 of 7 Old 11-05-2013, 11:00 PM
Ram_Wagon
Ram_Wagon's Avatar
Need to pressure check your cooling system. No more than 16 psi! But see if there is a leak.
2nd, you need to make absolutely sure the blend doors and/or mode doors in the HVAC box are working properly. I've never experienced this myself (knocks vigorously on wood!) but I seem to recall a few threads here & CumminsForum that mention Ram's and their blend door issues.
Be worth searching for....? :thumbsup:
2007 DODGE CHARGER R/T A.W.D.
Ram_Wagon is offline
post #7 of 7 Old 11-05-2013, 11:12 PM
dmcelhannon
Admin - David Mack
Quoted: 235 Post(s)
Do a search on the Blend Door.
File Type: jpg Bottom half of the Blend Door System - Heater core is sandwiched in-between.jpg (34.9 KB, 1 views)
    Heat only blows hot for a few seconds racer190 Dodge Dakota 1st Gen (87 -96) Forum 5 01-23-2009 05:17 PM
    AC Blows Hot ruprectgern 3G Dodge RAM - General Talk 4 11-13-2008 10:26 PM
    Rear A/C Blows Hot parkerbowman Dodge Caravan General Talk 8 06-02-2008 06:28 PM
    AC blows hot at idle seandotson 3G Dodge RAM - General Talk 7 09-17-2007 05:04 PM
    a/c on passenger side only blows hot 3blackram 3G Dodge RAM - General Talk 6 04-02-2007 09:41 PM
