High Mileage Transmission Service - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 10-29-2013, 11:24 AM Thread Starter
Darrell976
I took my 2004 Dodge Ram 1500 with 5.7 Hemi and an automatic tranny for a transmission service today. It has just over 190,000 miles. The mechanic asked if I'd ever had it serviced before, which I have. I asked why he asked me. He said that if it had never been performed before he would not want to do it because of the high mileage. He said Dodges are notorious for tranny failures and servicing a tranny with such high mileage could lead to a vehicle not even being able to pull out of the shop after the service. This has me nervous even though I've had it serviced before. I told him I'd come back later. I cannot afford to have a tranny problem. Is there any truth to this? Why would new fluid and filters ruin a perfectly good transmission?
I've heard my brother say this before, years ago, but I never questioned him about it. However, now I'm curious... What do you resident experts have to say about this?
Darrell976 is offline
post #2 of 5 Old 10-29-2013, 11:48 AM
wagntwister
Quoted: 1 Post(s)
It can be bad for any trans. Years of gunk thats holding things together getting cleaned out can lead to a quick death. You can roll the dice and leave it alone and hope for the best or change it and wonder if and when.
08 Mega 1500 HEMI
13 Durango Hemi
98 2500 Cummins 24 Valve
A couple kids and quads.
wagntwister is offline
post #3 of 5 Old 10-29-2013, 03:35 PM
Dozer Mam
its Dozer Man
Dozer Mam's Avatar
im the same way with my 03. im meticulous with the engine service, because ive heard of the 4.7 sludge problems but ive never serviced the tranny. the fluid is showing signs of wear too. wouldnt changing the filters and lost fluid be just as good? was thinking maybe that and changing it soon after again once it went thru the converter. lame thinking??
Dozer Mam is offline
post #4 of 5 Old 10-29-2013, 03:41 PM
ZMBSNPR
ZMBSNPR's Avatar
Quoted: 4 Post(s)
I believe that concern here is whole fluid flush vs drop and drain. Typically the high-mileage vehicles that have the fluid flush (which is the way most shops do it) are the ones that suffer from "shock" and fail. This is why most people elect to just drop the pan, change the filters, and add however much fluid is drained; which is about half. This keeps good or better fluid in the trans but also keeps that 'gunk' in there that is holding things together. At least thats the theory.
2008 Dodge Ram 1500 QCSB 4X4 Hemi
-AIRAID MIT w/ AFE Pro Dry filter
-Superchips 3865 (91 Tune w/ ATT)
-Jetstream Scoop
-Powerwire
-AT3030 + Magnaflow Y-pipe
-180 Stant T-Stat
-Sonnax Line Pressure Booster
-Bilstein 5100s F+R
-Procomp Series 52 17x9
-285/70-17E BFG AT/KOs
ZMBSNPR is offline
post #5 of 5 Old 10-29-2013, 10:08 PM
Dodge4x4810
Quoted: 2 Post(s)
It really depends on whether the garage plans on completely flushing it, using a machine, or just dropping the pan and draining. Completely flushing a high mileage tranny, that has never or rarely been serviced has potential to be catastrophic, however one can also luck out. Flushing a high-mileage (and not regularly serviced) tranny, will cause all the years of crude build-up to get swashed around, and it can all break apart and not all make it out of the tranny. Also, the crude build-up can also also make the old, worn out seals, actually stayed all sealed. If a garage you went to is telling you this, I would definitely keep going back to them (if you don't do the work yourself), especially considering they're basically telling you they do not want to take your money for your own benefit.
2017 Dodge Ram 2500 crew cab 6.4 Hemi 4x4
(sold)2005 Daytona HEMI qc 4x4
True Duals w/ x-pipe, No cats, 2 10 Series dumped, Mopar Cold-Air Intake, 3.92 gears, Removed Body Kit, T-bar crank, Diablo Custom Tune, 35x12.5x20 Pro Comp Xterrains, 3" PA Body Lift, Gibson headers, MSD wires, egr delete
Dodge4x4810 is offline
    High today of 73 Degrees and high mileage of..... Noved 4G Dodge RAM - General Talk 11 02-18-2011 09:30 PM
    Allowable Mileage - High Mileage Trailnut 2G Dodge RAM - General Talk 11 09-15-2008 08:54 AM
    engine service light + mileage ? RAM MAN Dodge B-Series Vans 1971 - 2003 6 03-09-2007 07:29 AM
    High Mileage Help CowboyCummins 2G Dodge RAM - General Talk 11 09-27-2006 08:39 AM
    HIgh mileage D's RAC961 1G Dodge Durango Performance Talk 4 02-13-2006 08:03 AM
