P1757 Code - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 01-11-2005, 11:08 PM Thread Starter
pallen_001
P1757 Code
I got a checkengine light on my 98 1500 ram. Code was P1757 gov pressure. Is this a normal problem? reset the code and it has not returned for the last couple of days. Mabey a sensor problem? Any Ideas?
Thanks
Pete
pallen_001 is offline
post #2 of 4 Old 01-12-2005, 10:54 PM
DODGEIT
DODGEIT's Avatar
Quoted: 1 Post(s)
It could be the governor pressure sensor, governor, or both that can trigger the light. Watch for erratic shifting. If you take off from a dead stop and it feels liek it doesn't move well and then all of a sudden it feels liek it catches and goes then that is what is wrong with it. Cost me aound $450.00 when it happened to me. What it is doing as decribed above is starting out in 3rd gear.
2012 Dodge Ram 1500 Big Horn QC 4x4
DODGEIT is offline
post #3 of 4 Old 01-12-2005, 10:55 PM
DODGEIT
DODGEIT's Avatar
Quoted: 1 Post(s)
It could be the governor pressure sensor, governor, or both that can trigger the light. Watch for erratic shifting. If you take off from a dead stop and it feels like it doesn't move well and then all of a sudden it feels liek it catches and goes then that is what is wrong with it. Cost me around $450.00 when it happened to me. What it is doing as decribed above is starting out in 3rd gear.
DODGEIT is offline
post #4 of 4 Old 01-13-2005, 11:20 AM
Rammin360
8E P1757 MALF
Requested pressure and actual pressure are not within a tolerance band
for the Governor Control System which is used to regulate governor
pressure to control shifts for 1st, 2nd, and 3rd gear (zero-pressure
Rammin360 is offline
