Go Back   Dodge Talk Community Forum > Dodge Vehicle Forums > Caravan Talk
ga.ram
  Blinking lights - Posted: 10-10-2002, 11:49 PM
City: Cumming, GA.
State: GA
Post #1
Help!!!
My wifes 98 Grand Caravan had a dead battery today. I guess 4 years is not too bad for an OEM battery. After I replaced it , it started up fine but the little lights on the A/c, air flow, rear wiper and intermitent rear wiper are all blinking. Does anyone know how to shut these stupid things off?? I really don't want to take it to the dealer if possible.
Georgia Ram
1999 Ram 1500 ST Club Cab 318 2WD, Mopar PCM, JBA shorties, Flowmaster Force II cat. back exhaust, Trac-Loc LSD, MSD 6A, Steelhorse billet grill & bumper inserts, Leer fiberglass tonneau cover, Bell Tech 2" drop shackles, 180* thermostat, Brass cap & Rotor
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
McClane
 Posted: 10-11-2002, 04:25 PM
McClane's Avatar
City: Calgary, Alberta
State: OTHER
Post #2
Only thing I can think of is disconnect the battery, then reconnect it again.
Make sure that before you reconnect the battery again, turn all accessories off.
1995 Dakota 4x4 Club Cab
5.2L, 3:55 rear end, 46RH tranny
Mods : M1, NGK zfr6f11s, 180 t-stat, Bilstein shocks, Roadmaster Active Suspension, Mopar Valve Covers, Mopar 3 inch cat back, relocated IAT, FMS/Bosch Design 2 #21 injectors, TransGo Shift kit (tfod-hd2), 8mm Taylor Spiro Pro wires
ga.ram
 Posted: 10-11-2002, 08:31 PM
City: Cumming, GA.
State: GA
Post #3
I tried that.. All accessories off disconected "new" battery then reconnected, still have the blinking lights. I really hate to think I'm gonna have to take it to the dealer pay $50-100 to have them push or flip a switch.
Georgia Ram
McClane
 Posted: 10-15-2002, 11:42 AM
McClane's Avatar
State: OTHER
Post #4
What about any fuses ? Have you checked the fuses ?
ga.ram
 Posted: 10-15-2002, 07:10 PM
City: Cumming, GA.
State: GA
Post #5
Yeah, Checked the fuses etc. A friend of mine said his wifes did the same thing, only way to get them off is by dealer. Something about the OBDII scanner reader thingy.
Thanks anyway.
Georgia Ram
DGERAM
 Posted: 10-15-2002, 08:28 PM
DGERAM's Avatar
City: Anchorage
State: AK
Post #6
Did you try turning the key in the ignition to "start" for 15 seconds while the battery is disconnected? That is how you reset the computer in the Rams.
2003 Dodge Neon SXT
Basically stock
2001 Dodge Ram 1500 4X4 Off-Road/Sport 5.9L
Sold
1998 Dodge Dakota Club Cab 4X4 Sport 3.9L
SS Cal-Vu Mirrors, SS GenII Roll Pan, Clear Corners, Intake, and Trailmaster SSV shocks so far. (girl's ride)
carguy2
 Posted: 10-15-2002, 08:32 PM
City: Greenville
State: NC
Post #7
dgeram is sort of correct. When you disconnected the battery, you "killed" your computer. It has to relearn itself, then the lights should go off.
DGERAM
 Posted: 10-15-2002, 08:57 PM
DGERAM's Avatar
City: Anchorage
State: AK
Post #8
Just curious - if just disconnecting the battery "kills" the computer, then wouldn't the lights not come back on until it detect a problem, not the other way around? In the Rams (and Dakotas, Durangos, etc.) to reset the PCM and make it forget everything it learned from the sensors, you have to disconnect the battery and turn the key in the ignition for 10-15 seconds. Just disconnecting the battery will not clear any warning lights like the check engine or whatever.
2003 Dodge Neon SXT
Basically stock
Sold
McClane
 Posted: 10-16-2002, 03:15 PM
McClane's Avatar
State: OTHER
Post #9
I don't know if that "disconnect the battery, then turn ignition on for 15 second" trick works for the Caravans.
When I shorted a fuse in my mom's Caravan, I did the the same thing and I didn't notice any difference.
DGERAM
 Posted: 10-16-2002, 03:24 PM
DGERAM's Avatar
City: Anchorage
State: AK
Post #10
Oh - OK, I though it would be worth a try since it works for other vehicles of the same make. In that case, I would say that you should take it to the dealer.
2003 Dodge Neon SXT
Basically stock
Sold
ga.ram
 Posted: 10-16-2002, 04:41 PM
City: Cumming, GA.
State: GA
Post #11
Thanks guys I was afraid of that.
Thanks anyway
Georgia Ram
ga.ram
 Posted: 10-28-2002, 05:06 PM
City: Cumming, GA.
State: GA
Post #12
Finally got it to the dealer, $30.00 to reset the A/C memory when battery went dead.
Thanks to all who tried to help...
Chris
Georgia Ram
blackram40
 Posted: 10-28-2002, 06:15 PM
City: cobleskill
State: NY
Post #13
you shoulda e-mailed me, i coulda told ya how to reset (actually go through control head function test)....
keep it in mind next time....
Ruprect
 Posted: 10-28-2002, 07:17 PM
Ruprect's Avatar
Goonies ARE good enough
City: San Antonio
Post #14
blackram40
tell us how
tell us please...........
pleeeeeeeeeeeeaaaaaaaaaaaaaaaaaaseeeeeeeeeeeeeeeee e
Ruprect
"septic with unappeasable anger"
02 Ram Sport Quad Cab
BLAAAAAAAACK
4.7 auto
Limited slip 3:92
Infinty factory system
OEM running boards and accent kit
Tri-Glass fiberglass tonneau
Click HERE to view the complete signature...
McClane
 Posted: 11-05-2002, 03:51 PM
McClane's Avatar
State: OTHER
Post #15
That was the first thing I thought of when I blew the fuse in my mom's Caravan. I thought to myself "if it works for Daks/Rams, it should work for Caravans". I guess Chrysler must design Caravans differently.
yamamike
  blinking light problem - Posted: 03-10-2005, 11:21 PM
Post #16
Hi ,just wondering if you could share with me, how to fix the blinking light problem he's talking about ?
I to am experiencing it and would like to not take it in !!
thanks, Mike
gas28man
 Posted: 03-11-2005, 10:26 AM
City: Smyrna, TN
State: TN
Post #17
Start the engine, setting temp control to cold, with fan on high, and pushing the rear wash and rear wiper buttons at the same time until a bunch of the lights on the head unit start to flash.
It'll run the calibration/diagnostic test (2 lights flashing) then the cooldown test (2 other lights flashing). If all passes the rear wiper switch will flash alone. Push it to exit tests, and you're done.
Rick
progress
  WOW! Ive been registered for a few minutes now... - Posted: 05-17-2005, 02:54 PM
Post #18
...and I found the answer to what I was looking for all ready!!! Now that was cool! Thanks for posting that control head function test gas28man. We just got my 97 Grand Caravan Sport back up and running after 6 months of it sitting around. Changed the battery and all of a sudden these lights start flashing and wouldn't stop! Glad I found this site! Now I've got all my Honda CRX sites and this site to look through while I'm at work! Thanks!
yamamike
 Posted: 05-17-2005, 10:06 PM
Post #19
That worked great, Thanks, very much !!!!!!
progress
 Posted: 05-18-2005, 08:11 AM
Post #20
Ok, so I tried out this little diagnostic test thing and after doing it several times, I get the A/C and recirc lights simultaneously blinking three times followed by one blink of the rear wiper LED. Is it safe to assume I have a problem with my A/C and/or recirc? I'm gonna go try it again...
Ok, tried it again but waited longer before I shut the van off. How long are you supposed to wait, or better yet, how long should this test take? I read somewhere that the recirc needs to be on prior to doing this test but if the damn lights are blinking, how do I know if it's on or off? I also read there may be a second test that needs to be done as well. Is this true? What needs to be done to get these two remaining blinking lights to stop? Or do I need to make the dreaded trip to the dealer to have them fix something? Thanks again!
lights going crazy peppe1 3G RAM - General Talk 8 01-01-2004 08:22 AM
2004 Ram Missing Fog Lights jda1500hemi 3G RAM - Interior/Exterior Talk 3 09-04-2003 09:11 PM
Aftermarket Fog Lights wired into Parking Lights? Possible? RiPPEDTiDE 2G RAM - General Talk 6 07-11-2003 01:54 PM
Lights out! need help! AP Neon - General Talk 2 02-25-2003 04:45 PM
