1987 w250 with odd engine setup - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 08-22-2013, 07:15 PM Thread Starter
swingingwheel
hi looking for info on an unexpected find
I have had my w250 for 4 years and its never missed a beat
When I inherited truck I was told the original engine blew up and was replaced and I never asked more
Yesterday I decided to id the engine to find out exactly what I had and wow was I supprised to find the date stamp on the block clearly said 1995 and the build number consistant with a magnum 5.9 engine.
The heads and all accessories look to be from the original LA 360 engine and it has the mechanical fuel pump too
How did someone manage this and how is my engine able to run if these heads appearently don't work on magnum engines
Should I not be running LA 360 plugs and oil filter in this engine ?
1987 dodge blue W250 Ex sno commander with 104,000 on the panel
blew up original 360 now has as follows
1995 dodge 360 aka 5.9L magnum engine 4 barrel 1406 edelbrock carb setup
dana 44 up front with chrysler 9 1/4HD 3.55 in the rear NP 208 transfercase Loadflite 3 speed auto 727
Has 3 core heavy duty radiator, trans cooler cab lights, bumper pads
I am the third owner
Truck is fully functional ..... for the moment
swingingwheel is offline
post #2 of 11 Old 08-22-2013, 07:50 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
you can run the old LA pulley setup on a magnum series engine and the magnum blocks do have a place for a mechanical fuel pump. i'm guessing the spark plugs and oil filter are the same. if they've worked well thus far it should be fine. are you sure you have the old LA heads? magnums have aluminum heads. so if they are iron then most likely LA heads.
1987 Dodge W-150 "The Beast"
some sort of lift
33" AT's
LA 360 bored .030 over, EQ Magnum heads, Hooker Headers, true dual exhaust, Holley 4160 w/Truck Avenger parts, Edelbrock Performer dual plane intake, StreetFire ignition box & MSD coil
208 t-case/727A trans w/3.23 gears
maachine is offline
post #3 of 11 Old 08-22-2013, 08:00 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
correction.........you can use a timing chain cover from an LA block on a magnum block to use a mechanical pump
some sort of lift
33" AT's
maachine is offline
post #4 of 11 Old 08-22-2013, 10:27 PM Thread Starter
swingingwheel
Yeah I took a long hard look at the heads and they are not aluminum plus magnum heads have 10 bolt valve covers and mine only has 5
What bothers me is the difference in the way these two head setups oil the valve train
When I look down into the inside of valve covers with engine running there is not any visible oil flow if any
post #5 of 11 Old 08-22-2013, 10:35 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
ahhh i see what you're saying. magnums oil through the push rods. LA's dont. i cant remember how to setup LA heads on a magnum engine. i've read an article about it somewhere. cant remember. all i remember is that it takes a little machine work and you can use LA heads on a magnum block......for oiling purposes
some sort of lift
33" AT's
maachine is offline
post #6 of 11 Old 08-23-2013, 12:31 AM
DodgeAddict
Lifetime MoparMan
DodgeAddict's Avatar
Quoted: 11 Post(s)
The only machine work is to open up the pushrod holes in the head with a burr bit
You can use any aftermarket lifter or if you want to be specific any V8 AMC lifter & 7.625-7.650 hollow pushrod lengths depend on deck heights & head gasket thickness
No Magnum 318 or 360 ever came factory with aluminum heads
I have the CC DD chromosome in my DNA!
DodgeAddict is offline
post #7 of 11 Old 08-24-2013, 01:06 AM Thread Starter
swingingwheel
Thanks for all the info
looks like I will have to pull a valve cover and see exactly how this engine is setup and if its done right
post #8 of 11 Old 08-24-2013, 04:02 AM
maachine
maachine's Avatar
Quoted: 45 Post(s)
Really? I thought they had aluminum heads and were prone to cracking......my bad. Sorry for the misinformation
some sort of lift
33" AT's
maachine is offline
post #9 of 11 Old 08-24-2013, 10:35 AM
Ram3500Dually
Administrator
Ram3500Dually's Avatar
Quoted: 38 Post(s)
You have been driving it for 4 years so its probably done right LOL
2013 Ram 3500 CTD 6.7L 6 Speed Aisin, 4:10 LSD
2005 Jeep Liberty Sport
1991 Shadow ES Turbo Convertible
1984 Mini-Ram Van (Show Van) **TOTM April 2007** In museum now
73 Pro Street Duster.**VOTM July 2008/ April 2011**
1951 Dodge 3 Window Business Coupe **VOTM Feb 2011**
1992 Custom Built Harley FXSTC Show Bike
2008 Harley FLHTCU Ultra Classic
DodgeTalk Administrator
Names Carl, if you cut me I bleed Mopar Blue
Past Trucks: 90 CC Dually CTD, 94 RC LB CTD, 95 CC SB 5.2L gas, 98 QC Dually CTD, 00 QC Dually CTD, 01 QC Off Road, 03 QC Dually CTD, 05 QC Dually CTD, 08 Dually CTD **ROTM April 2008**,10 CC Dually CTD,
Ram3500Dually is offline
post #10 of 11 Old 08-24-2013, 02:12 PM
maachine
maachine's Avatar
Quoted: 45 Post(s)
What I just realized, good way to tell the difference between heads would be LA has shaft rockers, magnum has pedestal mounted rockers.......at least stock anyway
Sent from AutoGuide.com Free App
some sort of lift
33" AT's
maachine is offline
post #11 of 11 Old 08-24-2013, 04:22 PM
duval67
Quoted: 2 Post(s)
Exactly what I was going to say. I'd still be curious as go what exactly what done, but you wouldn't have driven it without problem for 4 years if it wasn't working.
1980 Dodge D150 -- Slant Six
Accident recovery:
duval67 is offline
    4x4 light won't turn off 1987 w250, hubs? mstarcj Dodge Ram Truck 1st Gen (88 - 93) Forum 1 04-28-2012 09:11 PM
    1993 W250 5.9 Magnum Needs new Engine bstopek Dodge Ram Truck 1st Gen (88 - 93) Forum 4 03-23-2010 10:49 PM
    looking for 1987 w250 parts Commish425 1972-1987 Dodge Ram Trucks (D, W-series) 2 03-18-2008 03:43 PM
    '90 W250 Engine Change DanAKAL Dodge Ram Truck 1st Gen (88 - 93) Forum 3 02-17-2008 03:35 AM
    1987 W250 4x4 Commish425 1972-1987 Dodge Ram Trucks (D, W-series) 15 12-27-2007 03:50 PM
