02 ram ignition switch replace for third time - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - General Talk
cdesero
  Angry 02 ram ignition switch replace for third time - Posted: 12-26-2004, 04:55 PM
cdesero's Avatar
DES
City: Port Huron,Mi
State: MI
Post #1
I can't Be the only one that has a bad ignition I'am ready to have it fixed again this will be number 4. You have to wiggle the key to get chimmes or the lights on the radio to work??????????????
FreeLantz
 Posted: 12-26-2004, 09:50 PM
FreeLantz's Avatar
Administrator
City: Meadows Place
View Member's FaceBook Profile
Post #2
Wow, that's actually not common as far as I know... perhaps someone else will have had the same problem but I sure havent with my '02!
David Lantz
DodgeTalk Administrator
FreeLantz@DodgeTalk.com
2007 Ram 1500 Regular Cab 4x4 LWB HEMI
2007 JK Wrangler
Previous: '93 Dakota, '96 Ram 1500, '99 Ram 2500 4x4, '02 Ram 1500 4x4, '05 Dakota 4x4, '08 Magnum R/T, '08 Jeep Patriot
Forum RulesSupport Our SponsorsDodgeTalk on YouTubeDodgeTalk Facebook Group
DodgeTalk Decals For SaleVote in our Monthly Chop Challenge!
thekingofpain
 Posted: 12-26-2004, 09:59 PM
thekingofpain's Avatar
Ultimate member
City: Laguna Beach Ca
State: CA
Post #3
4th one?
Something must be wrong, do you park regularly on a hill with the wheels turned and have to "jiggle" the steering wheel to get the key to turn?
Praise the lowered...
cdesero
 Posted: 12-26-2004, 10:07 PM
cdesero's Avatar
DES
City: Port Huron,Mi
State: MI
Post #4
No I never park on hills. the dealer tells me it is not the ignition it self but the switch behind the ignition. I think it is not getting replaced but repaired some how every time it is in the shop??????
JamesJ2525
 Posted: 12-26-2004, 10:18 PM
JamesJ2525's Avatar
Hotty Toddy Gosh Almighty
City: Ridgeland
State: MS
Post #5
Highly unlikely that you have had four bad switches. There is probably something else that is causing the switch to fail. No idea what it might be though. Rather than just replace the switch for the fourth time, I would have them check for other problems that may be causing it.
2003 Ram 1500 SLT Regular Cab, 360 V8, 3.92 Limited Slip, 4X4 Offroad Package, 1.5" Torsion Bar Crank, Rancho RS 5000 Shocks, LT 275/70R17 Cooper Discoverer S/Ts, K&N Airfilter, Mopar (Borla) Performance Exhaust, Mopar Running Boards, Mopar Slush Mats, Sirius Satellite Radio, Coin Holder
warp
 Posted: 12-27-2004, 05:14 PM
City: Austex
Post #6
How much stuff do you have hanging on your key chain, too much weight?
Common problem for many
cdesero
 Posted: 12-27-2004, 05:16 PM
cdesero's Avatar
DES
City: Port Huron,Mi
State: MI
Post #7
Just the door fob and one key???
hemi_power87
 Posted: 12-27-2004, 05:55 PM
hemi_power87's Avatar
Hemi Chi will enlighten u
State: CA
Post #8
Thats the dealers fault then. Anything that you bring in three times on the fourth time they have to replace the vehicle or do a buy back. Its lemon law. You may have yourself a new Hemi or better yet wait until the powerwagan and get taht instead, your payments may go up a little but hey, you'll be the talk of the town.
JamesJ2525
 Posted: 12-27-2004, 09:44 PM
JamesJ2525's Avatar
City: Ridgeland
State: MS
Post #9
I don't think improper installation or failure of one part due to another will be covered under lemon law, its also more complicated than just a part failing multiple times. It varies by state and has multiple criteria that has to be met. Something else must be causing the problem. There's less than a 1% chance that a part will fail 4 times in a row.
pad79
 Posted: 06-10-2005, 02:52 PM
Post #10
I have a 2002 Dodge Ram and today when I took the key out the AC kept going. I haven't tried it with the radio on but I attempted to turn it off and on several times before I realized that I had to wiggle the ignition switch to turn it off. Does anyone know what might cause that and what I should do to fix it. I do not have much on my key chain and have kept great car of my truck.
tarbaby
 Posted: 06-10-2005, 04:08 PM
Old F@rt
City: Tijeras, New Mexico
State: NM
Post #11
Interesting. My o4 has a problem with the radio staying on, door chime still working for several seconds after the key is removed. I'm hesitant to take it to the dealer because they will want to keep it for 3 or 4 days to do an oil change. Might be two weeks for this problem! I'm hoping the problem will just go away as it is intermittent.
spharis
 Posted: 06-10-2005, 04:16 PM
spharis's Avatar
FSCK STOCK
City: deep south
State: LA
Post #12
I like the fact that I can pull my key out a little, and the chime stops.
Chauncy
 Posted: 06-10-2005, 05:25 PM
Chauncy's Avatar
I'm Not A Post Whore! :(
City: Onalaska
Post #13
yeah, same here Spharis
with it turned back, in the off position, or turned forward, with the door open, if I barely touch the key the chime will stop
in fact I usually have to push the key in to get the chime to start, and I love it
Current: 2002 Ram 1500 4.7/5spd leveling kit on 34's.
Gone: 2003 Dodge Ram 2500 4x4 5.7 Hemi 6" Superlift on 35's.
