2003 stratus heater problem - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 12-14-2004, 08:06 PM Thread Starter
Tmkus
I have a 2003 Stratus Coupe 2.7 with the following problem: It only blows hot air when its turning over 2000 RPM. The minute I rev to that magic 2000 I get hot air otherwise only cold. this goes for defrost or floor settings. Any thoughts?
Tmkus is offline
post #2 of 5 Old 12-15-2004, 07:33 PM
LB3711
Moose
LB3711's Avatar
Quoted: 68 Post(s)
coupe doesnt have the 2.7. you either have the 2.4 or the 3.0
2011 Dodge Ram 1500 Hemi QC 4x4
2001 Dodge Stratus ES 4Dr. 2.7L Magnum DOHC V6. SOLD
2002 Dodge Durango SLT 4Dr. 4.7L Magnum V8. SOLD
Proud Member of The Original WCPW
LB3711 is offline
post #3 of 5 Old 12-16-2004, 02:58 PM
vin_in_boston
Have you checked your anti-freeze level? Could be that not enough anti-freeze is circulating through the system. Make sure you are topped off to the recommended level. Hopefully that is all it is. Good luck.
vin_in_boston is offline
post #4 of 5 Old 12-17-2004, 05:35 PM Thread Starter
Tmkus
LB3711 and Vin in Boston. Thanks for the replies, LB yea it's not a coupe it's a sedan just like yours (ES 2.7 mag). Vin, Added some antifreeze and it cured the problem. Why is it that I never think of the easy fixes first? I always assume its a major problem. thanks for the help[.
Tmkus is offline
post #5 of 5 Old 12-18-2004, 01:01 AM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
Check to see why you were low on coolant. That stuff doesn't just evaporate. You might have a slow leak somewhere.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
