94 ram 1500 5.2L Cranks but wont start - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 14 Old 05-19-2013, 01:51 PM Thread Starter
Cinda
Smile 94 ram 1500 5.2L Cranks but wont start
Ok I have a 94 Dodge Ram 1500 5.2L That was left to me from my Step-Father when he passed so it is very special to me!! Has been sitting for awhile but over the last couple weeks i have been driving it after replacing
water pump & intake hose. Intake manifold gasket, changed oil, flushed radiator & hoses.And replaced radiator hoses. Has been driving fine & i turned it off a couple days ago & went to start it & it cranks fine but will not start. Tried starter fluid to see if it was gas issue but still wouldnt start. Replaced rotor in distributor cap & coil and still wont start. There is no fire at the coil. Not sure what to do next other than try pick up coil in distributor cap or crank sensor? Just praying someone can give me some light on this matter so i dont have to just keep guessing and putting money on parts that is not fixing the problem. Would so appreciate it, more than anyone can imagine. Hope to hear back from someone soon. Thank you all in advance.
Cinda is offline
post #2 of 14 Old 05-20-2013, 07:55 AM
Moparite
Moparite's Avatar
Quoted: 302 Post(s)
Do you have any fault codes?
Moparite is offline
post #3 of 14 Old 05-20-2013, 08:53 AM
chizzle1
REDNECK SPACESTATION
chizzle1's Avatar
Quoted: 18 Post(s)
no fire could be the coil, crank sensor, cam sensor (inside the dist) or the ASD (shutdown relay).
When my crank position sensor was going bad, it would start but run like crap.
I don't like the idea of just throwing parts at it either, but you have replaced most of the ignition system already. I would try the cam position sensor, followed by the crank sensor. But first check the auto shutdown relay, which is located in the fuse box.
edit: are you getting fuel to the rail? If the ASD is triggered, the fuel pump will not run.
01 Ram 5.9 Sport QC 4x4 - 175k, current build project - SCT Stage1 custom tune via Hemifever, Harland Sharp 1.7:1 roller rockers, Modded Kegger, Edelbrock ProFlow,52mm TB,180* t-stat,e-fans, pacesetter long tube headers, true duals with spun cats, Jones full-boar mufflers, 34x11 Falken ATs on 3rd gen Dodge 20"s, 3"TC lift, rebuilt 46RE w/HD internals, PML Deep Pan,SunPro Tranny Temp gauge,Rebuilt 231D,TSC Diamond Box, Sony head unit
10 Dodge Challenger R/T in Brilliant black - 392 cam,AFR shaker, MyGig 730N w/ navi,dvd,HD,u-connect & rear cam, 6 spd, Track Pak, SRT8 shorties & mids, DS Predator, Jet 180*, BBK 85mm tb, SLP line locks, de-badged, resonators removed, DRL enabled, skip shift eliminator, mopar hood struts, functional hood vents, 392 chin spoiler
09 Suzuki 1255S Bandit Metallic Blue on black, 1255cc I-4, 6 spd, Yoshi can, Givi screen, K&N, Bags Connection tank bag, TPX fuzz buster, Techmount GPS holder, Suzuki center stand, World Performance Seat
2013 Dart Limited Pitch black, fully loaded, hers
SOLD 06 Hemi Durango 4x4 Limited in Atlantic Blue Pearl
SOLD 97 Ram 1500 SLT Laramie in DuPont Frost White Pearl
chizzle1 is offline
post #4 of 14 Old 05-20-2013, 12:28 PM Thread Starter
Cinda
Well they sprayed starter fluid in it and it still wouldnt even try to start. So from that, they assumed it wasnt a gas issue. On the auto shut off relay, isnt thier another relay i can switch it out with to see it that is it? Thank you so much for taking out the time to reply.
Cinda is offline
post #5 of 14 Old 05-20-2013, 01:13 PM
chizzle1
chizzle1's Avatar
Quoted: 18 Post(s)
not sure about swapping the relays. i know some are interchangeable. i didn't drive my truck to work or I'd go look.
does the rotor button in the dist turn when you crank the engine? could be the timing chain went or the cam sensor is bad.
chizzle1 is offline
post #6 of 14 Old 05-20-2013, 11:16 PM Thread Starter
Cinda
Not sure how to check for the codes
Cinda is offline
post #7 of 14 Old 05-21-2013, 06:06 AM
ladale
ladale's Avatar
Quoted: 1 Post(s)
now,spraying starter fluid is this carborated? if you spray starter fluid into a carborated motor yes it will fire and run, a fuel injected motor will not, if you spray starter flued into an injected motor, and the fuel injector have no pressure it will not fire or run, even without spark if you use fuild it will rotate the engine faster and not fire as well, i would insure that the pump does run
2002 RAM 1500 4.7L 4x1 quad cab ST
Prev. 2004.5 RAM 2500 325/600 5.9L
Prev. 2003 ram 1500 quad cab 1x4 slt 5.9l 360
BEWARE I POST FOR THE F@^& OF IT!
if ur not cum'in ur try'in too hard
100,000K+ club member #21
Quad Cab Club #666
Don't TOUCH my truck Club!!!! Member #36
DT MIssissippi Chapter Member # 1
ladale is offline
post #8 of 14 Old 05-21-2013, 07:40 AM
Moparite
Moparite's Avatar
Quoted: 302 Post(s)
Our rams will fire up with starting fluid but will not stay running if there is a fuel issue.
The ASD relay is on whenever the motor is starting/running. It supplies positive power to the coil fuel injectors and 02 sensors. The fuel pump runs off another relay. Both are controlled by the PCM. You can switch it to another one of the relays but they rarely ever go bad. Is you CEL (check engine light) on? If so you have a fault code/s. I'd start there rather than replacing things that might not be bad.
Moparite is offline
post #9 of 14 Old 05-21-2013, 07:59 AM
ladale
ladale's Avatar
Quoted: 1 Post(s)
[QUOTE=Moparite;4534817]Our rams will fire up with starting fluid but will not stay running if there is a fuel issue.
thats what i said our ram FI will not start and run on starter fluid, i never said they will not fire, no fuel injected vehicle will
Quad Cab Club #666
ladale is offline
post #10 of 14 Old 05-21-2013, 08:01 AM
ladale
ladale's Avatar
Quoted: 1 Post(s)
or to lower the confusion, they will not run on it, but will crank
Quad Cab Club #666
ladale is offline
post #11 of 14 Old 09-02-2013, 12:25 AM
Psycho7506
I would like to know if u found the problem with your truck? I have a 94 with a 5.2 and 2 weeks ago it just died on me at a red light. Had to get it towed home I thought the coil or crank position sensor or cam sensor went out. I have the Haynes book for the truck and every thing checked out fine on that. So I poured gas in the intake and it started. Replaced the fuel pump and it run for 3 days and started running like crap on my way home from work. The next morn it would not start. This time my fuel pump was not working and the coil was not firing. I pulled the relay for the fuel pump and straight wired it and it started pulled the wire and put the relay back in and it run for a week and a half. But in that time I noticed it would not run any thing over 2500 rpm. Thursday night I went to town and going down the road it tried to die about 5 times in 20 miles. When I started home I started up t mountin and took it out of od and it did not wont to run because it was around 2500 to 3000 rpm's got to the top And it died. I made it home after it died bout every 100 feet or so. It would diesel every time it died. Friday morn it would not start same thing as the last time. This time the fuel pump would not work even if it was straight wired put a new fuel pump in started it and it run for 5 min and cut off just like someone cut it off. No fire this time and fuel pump not pumping. Put new coil on today because I checked it it was checking bad this time. Still would not start strat wired the fuel pump it started put the realy back in and it run till it run out off gas. So I swaped the realy from the starter to the fuel pump. Straight wired the pump put that relay in and it run. So I drove it down the road and back and now it will do 3500 rpm's and not miss a beat. So that's where I am with mine going to put all new relays in it in the next week or two.
Psycho7506 is offline
post #12 of 14 Old 09-02-2013, 12:26 AM
Psycho7506
Don't know why it posted that 3 times I'm on my phone sorry.
post #13 of 14 Old 09-02-2013, 07:40 AM
Moparite
Moparite's Avatar
Quoted: 302 Post(s)
Moparite is offline
post #14 of 14 Old 09-10-2013, 10:30 PM
abe
To Cinda
My money's on the fuel pump. Rather than drop the tank, I changed mine very easily by undoing the 6 capscrews holding the bed to the frame, then using a come-along, lifting on the left side of the bed, and tilting the bed off of the frame. Once the bed is up and out of the way, the top of the gas tank is in plain sight. I bought my fuel pump at napa. Not cheap. I recall $310
abe
abe is offline
    87 Power Ram w100 cranks but wont start NiteCreature 1972-1987 Dodge Ram Trucks (D, W-series) 4 09-02-2011 08:31 PM
    Cranks wont start Kalypsoue 2G Dodge RAM - General Talk 10 02-08-2011 12:57 AM
    98 Ram 1500 cranks a lot to start when warm jkkd 2G Dodge RAM - General Talk 4 09-01-2008 09:41 PM
    95 Dodge Ram w/ 5.2 V8 cranks but wont start -Help Sevensecondsuv 2G Dodge RAM - General Talk 6 09-02-2007 09:18 AM
