2004 Dodge Stratus OVERHEATING (Already Replaced Thermostat & Temp. Sensor).. ?? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 1 Old 05-08-2013, 05:07 PM Thread Starter
06RAMMER
I have an 04 stratus with the 2.7 v6.
Problem started in the winter, car had no heat inside no matter how hot the engine got. Driving around in the Spring it started overheating.
A week ago, I flushed out the coolant system, everything seemed fine. Then I changed the Thermostat and The Coolant Temperature Sensor. I thought everything was fine. Now the car is STILL OVERHEATING. The fans ARE kicking on, but not cooling anything and the temp. gage goes all the way to hot and then the coolant starts boiling and sprays out of the side pressure relief (? if that is what that side hole is called) on the overflow tank. Any ideas as to what else I should look at and/or replace?
06RAMMER is offline
    2004 Dodge Stratus P0325 Knock Sensor stevauto 2G Dodge Stratus - General Talk 1 03-10-2012 03:23 PM
    2004 Stratus overheating.... HELP A GIRL OUT! Russelltrt 2G Dodge Stratus - Performance Talk 11 09-17-2009 09:17 PM
    replaced temp sensor! doobie23 2G Dodge RAM - General Talk 0 02-02-2009 08:42 PM
    2004 Dodge Stratus 2.4l DOHC Camshaft Sensor CBAvent 2G Dodge Stratus - General Talk 0 12-29-2007 12:17 PM
    2004 Dodge Stratus Crankshaft Position Sensor CBAvent 2G Dodge Stratus - General Talk 0 12-29-2007 01:45 AM
