Looking to make my75d100 handle better. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 04-27-2013, 03:53 PM Thread Starter
moparmanintn
Hey guys I want to make my 75 handle better dose anyone make a perfomance suspention kit for these truck? If not what are the best/stifest shocks or coilovers I can get for it? I would like to drop in an ince or two up font.
moparmanintn is offline
post #2 of 18 Old 04-27-2013, 07:57 PM
rockabull
J.Qualls90
rockabull's Avatar
You could try calling Hotchkis or other similar companys. There is also a stickied thread at the top of the 72-87 forum page that talks about lowering it. For stiffer springs you could use some from a higher rated truck. IE, if you have a 100/150, use 250/350 springs. I wouldn't put any 1 ton springs in the back though, as it is light enough for the springs you have. Air shocks get pretty stiff, unfortunately the raise the truck as you add air. I would stay away from Ebay lowering kits/ coilover kits as well. They may be fine for my current 3100lb camry, but a 4500-5000lb truck, I'd get something with a name behind it.
Forgive me Dodgetalk, for I have sinned!
I am now driving a 95 f-150, and the worst part is I let a shop do some work on it!
rockabull is offline
post #3 of 18 Old 04-27-2013, 09:16 PM
Warlock's Dad
Quoted: 17 Post(s)
Wanda is a '78 with a 360. I added HD springs and all new joints. She rides like a bronco/jackrabbit on bouncy city streets which is what we have in Houston. Fine on smooth roads.
I have new Monroe-Matics (cheap) front and rear shocks. The Monroes are OK (for what they are). I tried replacing them.
The ride - sorry - sucks if the roads is rough. I'd like to know if better (i.e. more expensive) shocks help.
Grady
Wanda - 1978 Shortbed Warlock clone
1972 318 w/ lock-up 727 (not the 360 advertised)
In her 2-3 life - too many new parts to list
Poly steering "rag joint" and steering box braced
Poly mounts/bushings, springs & suspension parts
Upgraded cooling & fans
Front Sway Bar added
Warlock's Dad is offline
post #4 of 18 Old 04-27-2013, 10:27 PM
crazzywolfie
Quoted: 1 Post(s)
if you got old springs in the front i would not touch them. you could possibly get van lower control arms to bring the front end down even more. lowering the front end should help it handle better. i know the front end on my 81 is lower than it came stock and i can barrel around corners at 25mph if i want.
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
93 ramcharger 318 FI 2wd
crazzywolfie is offline
post #5 of 18 Old 04-28-2013, 01:03 AM
Warlock's Dad
Quoted: 17 Post(s)
When I took my front suspension apart I found a broken spring (top ring and 1/2 ) that no one had diagnosed and which no doubt caused the left front oscillations I was complained about. I'm sure the HD springs have made the front end a bit higher. The problem is not going around corners but jack rabbiting over road bumps.
I wish someone would put in some good shocks and tell the rest of us it worth it.
post #6 of 18 Old 04-28-2013, 03:25 AM
Dart270Sleeper
Dart270Sleeper's Avatar
I'd like to up-grade my trucks handling as well. What would be the best brand to use as far as a good ride and decent price? My '79 truck is for cruising only my '95 is for daily driver and hauling. Would a rear sway bar help as well?(note: I'm just asking for my '79 my '95 is just fine.)
Owns :68 Dart 270 318 2bbl auto 4dr, 1979 Dodge D-150 318 4bbl Auto, And 95 Ram 1500 5.9 360 v8 Auto ext cab Laramie.
Dart270Sleeper is offline
post #7 of 18 Old 04-28-2013, 06:34 AM
bookworm
bookworm's Avatar
Years ago I put a front sway bar on an 85 that I had. Made an enormous difference in the handling. I would recommend that upgrade, after replacing the Monroe-Matics with something heavier. Even just moving up the Monroe line would help a lot. Get the Monroe shocks designed for trucks/vans, they work much better than the cheapo Monroe-matics.
" A man and his truck; it's a beautiful thing. "
I said to my wife:"All my mods aim at efficiency & durability. The added horsepower is an unintended side effect." She snickered in disbelief.
2005 2500 QC 2wd CTD, Charcoal Metallic
Banks PowerPack, FluiDampr balancer, ATS 2-piece exhaust manifold, Banks 3-Disc Billet Torque Conv., Transtar Billet flexplate, Transgo shift kit with some Sonnax billet goodies, Dorman steel trans pan w/drain plug, DieselSite external trans filter, Hellwig rear anti-sway bar, GDP MK-2 fuel filter kit
Tinted, mostly de-badged, some other stuff too.
My truck is exactly the way I want it...except there's a few things I want to change.
bookworm is offline
post #8 of 18 Old 04-28-2013, 07:43 AM
Dart270Sleeper
How low would the van control arms lower the front end?
post #9 of 18 Old 04-28-2013, 09:40 AM
rockabull
J.Qualls90
rockabull's Avatar
Read this: FAQ: Lowering 72-93 Dodge D-series Trucks
post #10 of 18 Old 04-30-2013, 07:13 PM Thread Starter
moparmanintn
post #11 of 18 Old 04-30-2013, 07:29 PM
crazzywolfie
Quoted: 1 Post(s)
i haven't used then but i think you can get them cheaper at rockauto. if you use discount code 141714509024656 in the "How Did You Hear About Us?" box you can save 5% on your ordered from rock auto.
post #12 of 18 Old 05-01-2013, 12:47 PM
B-300
4 Wheel Power Disc Brakes
Use KYB gas adjust shocks. They work wonders on vans.
Monroe senstrac's are not meant for lowered vehicles and are softer near the factory ride height range.
Ram Van/Wagon Club Member #4
B-300
B-300 is offline
post #13 of 18 Old 05-01-2013, 04:35 PM
Warlock's Dad
Quoted: 17 Post(s)
I've had good luck with KYBs on cars and Edelbrocks on my Suburban. And when I wore out all 4 Edelbrochs, they promptly replaced them under warranty with no fuss.
IIRC, it's recommended to add a front anti-roll (sway) bar first. Check out the Addco web site which has a PDF on the subject.
You will need an after-market bar as the rear bracket for a OEM front bar (if you could find an OEM bar) are non-existent. Addco always made good kits but I haven't bought one in years so I can't say now. Grady
post #14 of 18 Old 05-02-2013, 01:42 AM
B-300
I used performance suspension technology urethane bushings on my B-300 van. I got the rebuild kit and added KYB shocks to the kit. When I bought mine, the asked for sway-bar sizes and end link lengths so they could add these bushings in urethane at no additional charge.
I have front and rear sway bars on my van. They help handling and improve tire life when driven on a windy mountain road to/from work.
B-300
B-300 is offline
post #15 of 18 Old 05-02-2013, 01:55 AM
Warlock's Dad
Quoted: 17 Post(s)
But if you have an OEM bar(s) and mounts, it's not so much of a problem as the rubber bushings themselves are available. Grady
post #16 of 18 Old 05-02-2013, 09:41 PM Thread Starter
moparmanintn
Thanks for the info guys. Yeah I already got the poly bushings just havnt put them on yet will do that along with the shocks.
post #17 of 18 Old 05-02-2013, 10:52 PM
DodgeAddict
Lifetime MoparMan
DodgeAddict's Avatar
Quoted: 11 Post(s)
You can lower it with Belltech 2605 spindles as well as Van or 4000# truck LCA's or both
You can adapt a F body GM sway bar in the front & a rear bar from a R/T Dakota
Handling goes way up when you lower
I have the CC DD chromosome in my DNA!
DodgeAddict is offline
post #18 of 18 Old 05-13-2013, 10:18 PM
d100clubcab
http://roadstershop.com/649/
these guys may be a bit extreme for what you're asking but they get the job done
Pics of my truck:
Video of my truck:
d100clubcab is offline
    Lets make her Handle Goodolboy 3G Dodge RAM - 4X4 Talk 2 11-25-2012 07:46 PM
    How to make a 04 4x4 handle Goodolboy 3G Dodge RAM - 4X4 Talk 10 06-30-2009 06:35 PM
    How to make a truck handle better? L_A_Hemi 3G Dodge RAM - Sport Truck Talk 41 10-23-2008 02:38 AM
